thermostat with Oled display
Michal81
Sat Oct 17, 2020 11:18 am
mechatronikaPL wrote:
Tue Jul 14, 2020 7:03 am
elamya You are amazing ! Been working great since yesterday :D Thank You very much !!!
Potwierdzam - ten człowiek - elmaya jest NIESAMOWITY.
MICHAŁ DOM
Thu Oct 29, 2020 7:06 pm
WALDIYO wrote:
Mon Dec 16, 2019 2:09 pm
Wszystko pięknie. Fajnie by było by od tego układu wyrzucić przekaźnik ( stacja np. w pokoju ) a moduł wykonawczy z wemosem i przekaźnikiem przy piecu. Wtedy będzie git :D
czy rozwijałeś ten pomysł aby przekaźniki na kolejnym wemosem zainstalować w innym pomieszczeniu ??
szukam wsparcia przy realizacji sterowania ogrzewaniem
gigilio
Thu Oct 29, 2020 10:46 pm
Hi Elmaya,
I have question - i want to connect buzzer instead relay.
It wants an alarm to go off if the temperature is too low or too high.
Is it possible on your thermostat ?
Prawdopodobienstwo jest zerowe że wygrasz miliona jak nie wyślesz kuponu totolotka...
MICHAŁ DOM
Sat Nov 14, 2020 5:12 pm
michael wrote:
Wed Oct 16, 2019 10:17 am
My visualization of this thermostat,
Cover after the old Sonoff Touch (which doesn't work anyway :D )
Original glass will be replaced with engraving laminate. It promises to be beautiful :)
hello did you manage to design the thermostat ????
michael
Mon Nov 16, 2020 7:56 am
It is true that I abandoned construction, otherwise I had solved it at home, but it was close to implementation :mrgreen:
Sat Nov 21, 2020 8:05 pm
I'm going to make a working thermostat as well but in other way (glass front panel) but I stucked on projecting pcb :) working on progress ...
How is Your project? Is working properly? I'm curious ;)
Sat Nov 21, 2020 8:13 pm
Hi @elmaya
Great respect for the soft :)
I've got question about setting the temperature. Now it is working like seting + and - so if I want to lower the temperature for night by 1,5 grads I need to make timetable that is lowering 3x 0,5 grad. If something go bad and one order will not go through the net then the next day the tempertature will be lower/higher by 0,5C.
Is it possible to change the soft to make just order setting certain value for thermostat? For example 21 grades? Similar like it is with dimmable LED, it is possible to set % of light so I guess Supla supports states with value. Or am I tottaly wrong?
sllawek66@wp.pl
Sat Nov 21, 2020 8:41 pm
Hello
Elmaya, will it work on the ds 18b20 in this thermostat ?.
Sorry i don't know english ds18b20 parasitically.
Sat Nov 21, 2020 9:06 pm
Hello
https://en-forum.supla.org/viewtopic.php?f=10&t=5320
Screenshot_2020-11-21 (1) thermostat with Oled display - supla org.png (12.68 KiB) Viewed 369 times
sllawek66@wp.pl
Sat Nov 21, 2020 9:11 pm
I only have two wires for the sensor, I want to power with two wires parasitically if this soft will do the trick
Post Reply
