button on D5 = link 1
button on D6 = link 2
button on D1 = link 3
button on D2 = link 4
D3 = configuration
#include <FS.h> // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <WiFiClientSecure.h>
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <Ticker.h> //for LED status
Ticker ticker;
const char* host = "svr.supla.org";
const int httpsPort = 443;
// Use web browser to view and copy
// SHA1 fingerprint of the certificate
const char* fingerprint = "CF 05 98 89 CA FF 8E D8 5E 5C E0 C2 E4 F7 E6 C3 C7 50 DD 5C";
//define your default values here, if there are different values in config.json, they are overwritten.
//length should be max size + 1
char Supla_server[20];
char D_Link_1[40];
char D_Link_2[40];
char D_Link_3[40];
char D_Link_4[40];
byte mac[6];
String url = "/direct/xx/xxxxxxxxx/read";
//flag for saving data
bool initialConfig = false;
#define onboard_led D4
#define TRIGGER_PIN D3 // wifi config
#define Link_1_PIN D5 // triger Link 1
#define Link_2_PIN D6 // triger Link 2
#define Link_3_PIN D1 // triger Link 3
#define Link_4_PIN D2 // triger Link 4
int timeout = 120; // seconds to run for
void tick()
//toggle state
int state = digitalRead(onboard_led); // get the current state of D4 pin
digitalWrite(onboard_led, !state); // set pin to the opposite state
//callback notifying us of the need to save config
void saveConfigCallback () {
shouldSaveConfig = true;
ticker.attach(0.2, tick);
// The extra parameters to be configured (can be either global or just in the setup)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 20);
WiFiManagerParameter custom_D_Link_1("Link 1", "D_Link_1", D_Link_1, 40);
WiFiManagerParameter custom_D_Link_2("Link 2", "D_Link_2", D_Link_2, 40);
WiFiManagerParameter custom_D_Link_3("Link 3", "D_Link_3", D_Link_3, 40);
WiFiManagerParameter custom_D_Link_4("Link 4", "D_Link_4", D_Link_4, 40);
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//set config save notify callback
//add all your parameters here
wifiManager.addParameter(&custom_D_Link_1);
wifiManager.addParameter(&custom_D_Link_2);
wifiManager.addParameter(&custom_D_Link_3);
wifiManager.addParameter(&custom_D_Link_4);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
//set minimu quality of signal so it ignores AP's under that quality
//defaults to 8%
wifiManager.setMinimumSignalQuality();
// set configportal timeout
wifiManager.setConfigPortalTimeout(timeout);
if (!wifiManager.startConfigPortal("DirectLink4")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.restart();
delay(5000);
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
//read updated parameters
strcpy(D_Link_1, custom_D_Link_1.getValue());
strcpy(D_Link_2, custom_D_Link_2.getValue());
strcpy(D_Link_3, custom_D_Link_3.getValue());
strcpy(D_Link_4, custom_D_Link_4.getValue());
void setup() { //------------------------------------------------ Setup ----------------------------------------------
Serial.begin(115200);
//sensors.begin();
pinMode(TRIGGER_PIN, INPUT_PULLUP);
pinMode(Link_1_PIN, INPUT_PULLUP);
pinMode(Link_2_PIN, INPUT_PULLUP);
pinMode(Link_3_PIN, INPUT_PULLUP);
pinMode(Link_4_PIN, INPUT_PULLUP);
pinMode(onboard_led, OUTPUT);
// start ticker with 0.6
ticker.attach(0.6, tick);
if (WiFi.SSID()==""){
initialConfig = true;
//read configuration from FS json
Serial.println("mounting FS...");
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
// Allocate a buffer to store contents of the file.
DynamicJsonBuffer jsonBuffer;
Serial.println(jsonBuffer.size());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
strcpy(D_Link_1, json["D_Link_1"]);
strcpy(D_Link_2, json["D_Link_2"]);
strcpy(D_Link_3, json["D_Link_3"]);
strcpy(D_Link_4, json["D_Link_4"]);
} else {
Serial.println("failed to load json config");
} else {
Serial.println("failed to mount FS");
host = Supla_server;
WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
void loop() {
if ( digitalRead(Link_1_PIN) == LOW ) {
url = D_Link_1;
direct_Link() ;
if ( digitalRead(Link_2_PIN) == LOW) {
url = D_Link_2;
direct_Link() ;
if ( digitalRead(Link_3_PIN) == LOW ) {
url = D_Link_3;
direct_Link() ;
if ( digitalRead(Link_4_PIN) == LOW) {
url = D_Link_4;
direct_Link() ;
// is configuration portal requested?
if ( digitalRead(TRIGGER_PIN) == LOW|| (initialConfig)) {
ondemandwifiCallback () ;
//save the custom parameters to FS
if (shouldSaveConfig) {
Serial.println("saving config");
json["D_Link_1"] = D_Link_1;
json["D_Link_2"] = D_Link_2;
json["D_Link_3"] = D_Link_3;
json["D_Link_4"] = D_Link_4;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
//end save
ticker.detach();
digitalWrite(onboard_led, HIGH);
if (WiFi.status() != WL_CONNECTED)
WiFi_up();
void WiFi_up()
WiFi.begin();
for (int x = 60; x > 0; x--)
if (WiFi.status() == WL_CONNECTED)
break;
else
Serial.print(".");
delay(500);
ticker.detach();
Serial.println("");
Serial.println("Connected");
Serial.println("Adres IP: ");
Serial.print(WiFi.localIP());
Serial.print(" / ");
Serial.print(WiFi.subnetMask());
long rssi = WiFi.RSSI();
Serial.print("(RSSI): ");
Serial.print(rssi);
Serial.println(" dBm");
else
Serial.println("");
Serial.println("connection failed");
void direct_Link() {
// Use WiFiClientSecure class to create TLS connection
WiFiClientSecure client;
Serial.print("connecting to ");
Serial.println(host);
if (!client.connect(host, httpsPort)) {
return;
Serial.print("requesting URL: ");
Serial.println(url);
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"User-Agent: BuildFailureDetectorESP8266\r\n" +
"Connection: close\r\n\r\n");
Serial.println("request sent");
while (client.connected()) {
String line = client.readStringUntil('\n');
if (line == "\r") {
Serial.println("headers received");
break;
String line = client.readStringUntil('}');
line = line + "}";
Serial.println("reply was:");
Serial.println("==========");
Serial.println(line);
Serial.println("closing connection");
EDIT: added 100 milliseconds debounce to improve stability
config = link1 5 seconds
Initial parameters for "ESP Falsh Download Tool":
CreystalFreq 26M
SPI SPEED 40 MHz
SPI MODE DOUT
BAUDRATE 11520
FLASH SIZE 32Mbit (4MByte)
