Supla universal IR emitter for 8 codes
klimasstudio
elmaya
klimasstudio wrote: Sat Nov 13, 2021 12:28 pm Can i use this?
https://allegro.pl/oferta/modul-czujnik ... 0175030423
you can't use that.
You need an IR receiver such as "TL1838" and an IR Led diode for the transmitter.
klimasstudio
Ok i know. Parts from screen plus IR 940nm transmitancję diode from pilot.
ritual
Is it possible to make something exact opposite to this?
I mean,by this software,the module releases an ir and performs a function.
What if by receiving an ir command it can perform a task,like execution of a direct link?
elmaya
ritual wrote: Wed Nov 17, 2021 3:33 pm Is it possible to make something exact opposite to this?
something like this https://en-forum.supla.org/viewtopic.php?p=83319#p83319
ritual
elmaya wrote: Wed Nov 17, 2021 5:24 pm
As i understand,that software works on the devices connected to same device and not on other devices that can be linked through direct link.
klimasstudio
I have a problem with the operation of the board. The page takes a long time to load, half or not at all. Resetting the board causes it to lose WIFI settings.
elmaya
klimasstudio wrote: Fri Nov 19, 2021 2:10 pm I have a problem with the operation of the board. The page takes a long time to load, half or not at all. Resetting the board causes it to lose WIFI settings.
have you used the version of this post? https://en-forum.supla.org/viewtopic.php?p=90457#p90457
klimasstudio
elmaya wrote: Fri Nov 19, 2021 2:23 pm
I use version from 1st post. I want recive codes from pilot and send codes to tv/amp reciver. Want use only diodes to tx and rx codes ;)
klimasstudio
I testet this:
https://en-forum.supla.org/viewtopic.php?p=66208#p66208
and this...
https://en-forum.supla.org/viewtopic.php?p=66412#p66412
and have same problems. I try flashing with others programs and modes and have same results :cry:
Return to “Ideas and concepts”
