here it is for NEW1 shows the sum of the 3 phases for kWh, VA, W and A
V only phase1
Remote display for 1 phase electricity meter based on DirectLink.
Thanks elmaya! A cool and useful gadget came out.
Very well completed, beautiful.
are you going to put a push button?
Button inside. The device is great and very useful. Thanks again GURU !!!
I am blind as a mole but the advantage of glasses and oleda allows me to see data at 0.96 inches
Hi,
Great project and work fine but...
There is always some but.
I have solar powerplant on my house roof. around 14kW peak.
I would like to add bar graph with can show me graphically where I'm with production/usage of energy. So I will see I'm puling power from grid or push in to.
On main grid I have installed power monitor NA96 with RS-485 interface, so I can grab to supla-cloud interesting me registers and use it to feed bar graph with data.
Is there any chance to get Your project source code (for private use only), where I can make custom build fitting for my needs?
you have a PM since Sep 02 2021, 11:41 am.admiral_25@o2.pl wrote: ↑Thu Sep 02, 2021 6:36 am Hi,
It is in the upper right part of the pages of this forum.
Hi, very interested I read information about your solution. I want to make similar for my Arduino mega board to switch different loads depending on the overall power consumption.
Are you willed to explain how you managed to read the values from the MEW?
Are you willed to send me the code itself or some parts of it?
/Erik
/Erik
source code:
//#define D0 16 //no internal pullup resistor
//#define D1 5
//#define D2 4
//#define D3 0 //must not be pulled low during power on/reset, toggles value during boot
//#define D4 2 //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15 //must not be pulled high during power on/reset
#include <FS.h> // ---- esp board manager 2.5.2
#include <WiFiClientSecure.h>
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <WiFiManager.h> //--------- https://github.com/tzapu/WiFiManager/tree/0.14 -------------
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <Ticker.h> //for LED status
#include "SSD1306Wire.h" //----- 0.96 Oled --- https://github.com/ThingPulse/esp8266-oled-ssd1306
SSD1306Wire display(0x3c, 4, 5); // 4-SDA 5-SCL ----- 0.96 Oled ---
//#include "SH1106Wire.h" //----- 1.3 Oled ---
//SH1106Wire display(0x3c, 4, 5); // 4-SDA 5-SCL ----- 1.3 Oled ---
Ticker ticker;
const char* host = "svr.supla.org";
const int httpsPort = 443;
char Supla_server[41];
char D_Link_1[61];
byte mac[6];
String url = "/direct/xx/xxxxxxxxx/xxx";
bool dimm = false;
unsigned long dimm_milis ;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000; // config delay 10 seconds ------------ opóźnienie konfiguracji 10 sekund
bool shouldSaveConfig = false;
bool initialConfig = false;
unsigned long link_delay = 5000;
#define onboard_led 2 //D4
#define Config_PIN 0 //D3 // wifi config
int timeout = 120; // seconds to run for wifi Manager
const uint8_t logo32_glcd_bmp[] PROGMEM = //logo supla 32
0x00, 0x00, 0x00, 0x00, 0xC0, 0x1F, 0x00, 0x00, 0xE0, 0x7F, 0x00, 0x00,
0xF0, 0x70, 0x00, 0x00, 0x30, 0xE0, 0x00, 0x00, 0x38, 0xC0, 0x00, 0x00,
0x18, 0xC0, 0x01, 0x00, 0x18, 0xC0, 0x01, 0x00, 0x38, 0xC0, 0x00, 0x00,
0x38, 0xE0, 0x01, 0x00, 0x70, 0xF0, 0x07, 0x00, 0xE0, 0x7F, 0x0E, 0x00,
0xC0, 0x3F, 0x38, 0x00, 0x00, 0x1F, 0xE0, 0x0F, 0x00, 0x18, 0xC0, 0x1F,
0x00, 0x18, 0xC0, 0x30, 0x00, 0x18, 0xC0, 0x30, 0x00, 0x30, 0xC0, 0x30,
0x00, 0x30, 0x80, 0x1F, 0x00, 0x30, 0xC0, 0x0F, 0x00, 0x20, 0x60, 0x00,
0x00, 0x60, 0x20, 0x00, 0x00, 0x60, 0x30, 0x00, 0x00, 0x40, 0x18, 0x00,
0x00, 0xC0, 0x0D, 0x00, 0x00, 0xC0, 0x07, 0x00, 0x00, 0x60, 0x04, 0x00,
0x00, 0x20, 0x0C, 0x00, 0x00, 0x20, 0x0C, 0x00, 0x00, 0x60, 0x06, 0x00,
0x00, 0xC0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00
void tick() {
int state = digitalRead(onboard_led);
digitalWrite(onboard_led, !state);
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
void ondemandwifiCallback () {
display.clear();
display.setContrast(100, 241, 64);
display.setTextAlignment(TEXT_ALIGN_CENTER);
display.setFont(ArialMT_Plain_10);
display.drawString(64, 16, "wifi config connect");
display.drawString(64, 28, "to wifi hotspot");
display.setFont(ArialMT_Plain_16);
display.drawString(64, 44, "DirectEM");
display.display();
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 41);
WiFiManagerParameter custom_D_Link_1("Linka", "D_Link On", D_Link_1, 61);
WiFiManager wifiManager;
wifiManager.setBreakAfterConfig(true);
wifiManager.setSaveConfigCallback(saveConfigCallback);
wifiManager.addParameter(&custom_Supla_server);
wifiManager.addParameter(&custom_D_Link_1);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
wifiManager.setMinimumSignalQuality();
wifiManager.setConfigPortalTimeout(timeout);
if (!wifiManager.startConfigPortal("DirectEM")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
ESP.restart();
delay(5000);
Serial.println("connected...yeey :)");
strcpy(Supla_server, custom_Supla_server.getValue());
strcpy(D_Link_1, custom_D_Link_1.getValue());
ICACHE_RAM_ATTR void no_dimm() {
dimm_milis = millis() + 30000 ;
display.setContrast(200, 241, 60);
dimm = false;
void setup() { //------------------------------------------------ Setup ----------------------------------------------
Serial.begin(115200);
pinMode(Config_PIN, INPUT_PULLUP);
pinMode(onboard_led, OUTPUT);
display.init();
display.flipScreenVertically();
display.clear();
display.setFont(ArialMT_Plain_24);
display.drawString(64, 40, "SUPLA");
display.drawXbm(0, 16, 32, 32, logo32_glcd_bmp );
display.display();
delay(1);
if (WiFi.SSID() == "") {
initialConfig = true;
Serial.println("mounting FS...");
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
Serial.println(jsonBuffer.size());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
strcpy(Supla_server, json["Supla_server"]);
strcpy(D_Link_1, json["D_Link_1"]);
host = Supla_server;
url = D_Link_1;
} else {
Serial.println("failed to load json config");
} else {
Serial.println("failed to mount FS");
WiFi.mode(WIFI_STA);
attachInterrupt(Config_PIN, no_dimm, FALLING);
void loop() {
if (initialConfig) {
ondemandwifiCallback();
int C_W_read = digitalRead(Config_PIN); {
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
Serial.println("Triger sate changed");
C_W_state = C_W_read;
if (C_W_state == LOW) {
ondemandwifiCallback () ;
last_C_W_state = C_W_read;
if (millis() > dimm_milis) {
if (dimm == false) {
display.setContrast(50, 40, 30);
display.display();
dimm = true ;
if ((WiFi.status() == WL_CONNECTED) && (millis() > link_delay)) {
direct_Link();
link_delay = link_delay + 10000;
if (shouldSaveConfig) {
Serial.println("saving config");
display.clear();
display.drawString(64, 0, "saving config");
display.display();
JsonObject& json = jsonBuffer.createObject();
json["Supla_server"] = Supla_server;
json["D_Link_1"] = D_Link_1;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
Serial.println("config saved");
display.clear();
display.drawString(64, 0, "config saved");
display.display();
ticker.detach();
digitalWrite(onboard_led, HIGH);
ESP.restart();
delay(5000);
if (WiFi.status() != WL_CONNECTED) {
display.clear();
display.drawString(64, 0, " conecting wifi ");
display.display();
WiFi_up();
void WiFi_up() {
WiFi.begin();
for (int x = 20; x > 0; x--)
if (WiFi.status() == WL_CONNECTED)
display.clear();
display.drawString(64, 0, " WIFI Connected ");
display.display();
break;
else
Serial.print(".");
delay(500);
display.clear();
display.display();
Serial.println("");
Serial.println("Connected");
Serial.println("Adres IP: ");
Serial.print(WiFi.localIP());
Serial.print(" / ");
Serial.print(WiFi.subnetMask());
long rssi = WiFi.RSSI();
Serial.print("(RSSI): ");
Serial.print(rssi);
Serial.println(" dBm");
else
Serial.println("");
Serial.println("connection failed");
display.clear();
display.drawString(64, 0, "connection failed");
display.display();
void direct_Link() {
WiFiClientSecure client;
client.setInsecure();
Serial.print("connecting to ");
Serial.println(host);
if (!client.connect(host, httpsPort)) {
Serial.println("connection failed -------------------------------------------");
return;
Serial.print("requesting URL: ");
Serial.println(url);
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"User-Agent: ESP8266\r\n" +
"Connection: close\r\n\r\n");
Serial.println("request sent");
while (client.connected()) {
String line = client.readStringUntil('\n');
if (line == "\r") {
Serial.println("headers received");
break;
if (line.indexOf("true") > 0) {
yield();
Serial.println("reply was:"); Serial.println("==========");
Serial.println(line);
Serial.println("=========="); Serial.println("closing connection");
JsonObject& root = jsonBuffer.parseObject(line);
// bool connected = root["connected"]; // true
// int support = root["support"]; // 382
const char* currency = root["currency"]; // "EUR"
float pricePerUnit = root["pricePerUnit"]; // 0.12
float totalCost = root["totalCost"]; // 380.25
JsonArray& phases = root["phases"];
JsonObject& phases_0 = phases[0];
//int phases_0_number = phases_0["number"]; // 1
float phases_0_frequency = phases_0["frequency"]; // 50
float phases_0_voltage = phases_0["voltage"]; // 234.6
float phases_0_current = phases_0["current"]; // 7.65
float phases_0_powerActive = phases_0["powerActive"]; // 1786
float phases_0_powerReactive = phases_0["powerReactive"]; // 17.63985
float phases_0_powerApparent = phases_0["powerApparent"]; // 1794.6900
double phases_0_powerFactor = phases_0["powerFactor"]; // 0.995
float phases_0_totalForwardActiveEnergy = phases_0["totalForwardActiveEnergy"]; // 3168.79008
JsonObject& phases_1 = phases[1];
float phases_1_current = phases_1["current"];
float phases_1_powerActive = phases_1["powerActive"];
float phases_1_powerReactive = phases_1["powerReactive"];
float phases_1_powerApparent = phases_1["powerApparent"];
double phases_1_powerFactor = phases_1["powerFactor"];
float phases_1_totalForwardActiveEnergy = phases_1["totalForwardActiveEnergy"];
JsonObject& phases_2 = phases[2];
float phases_2_current = phases_2["current"];
float phases_2_powerActive = phases_2["powerActive"];
float phases_2_powerReactive = phases_2["powerReactive"];
float phases_2_powerApparent = phases_2["powerApparent"];
double phases_2_powerFactor = phases_2["powerFactor"];
float phases_2_totalForwardActiveEnergy = phases_2["totalForwardActiveEnergy"];
delay(0);
float total_current = (phases_0_current + phases_1_current + phases_2_current);
float total_powerActive = (phases_0_powerActive + phases_1_powerActive + phases_2_powerActive);
float total_ForwardActiveEnergy = (phases_0_totalForwardActiveEnergy + phases_1_totalForwardActiveEnergy + phases_2_totalForwardActiveEnergy);
float total_powerApparent = (phases_0_powerApparent + phases_1_powerApparent + phases_2_powerApparent);
float total_powerReactive = (phases_0_powerReactive + phases_1_powerReactive + phases_2_powerReactive);
double total_powerFactor = ((phases_0_powerFactor + phases_1_powerFactor + phases_2_powerFactor) / 3);
display.clear();
display.drawString(64, 0, String(total_ForwardActiveEnergy, 1) + " kWh");
display.drawString(64, 13, String(total_powerActive, 1) + " W");
display.drawString(64, 28, String(total_powerApparent, 2) + " VA");
display.drawString(64, 37, String(phases_0_powerReactive, 1) + " W.Reac");
display.drawString(64, 46, String(phases_0_voltage, 1) + " V " + String(total_current, 2) + " A");
display.drawString(64, 54, String(phases_0_frequency, 2) + " Hz " + String(total_powerFactor, 2) + " Pf");
display.display();
Serial.print("pricePerUnit: "); Serial.print(pricePerUnit, 2); Serial.println(currency);
Serial.print("totalCost: "); Serial.print(totalCost, 2); Serial.println(currency);
Serial.print("frequency: "); Serial.println(phases_0_frequency, 2);
Serial.print("voltage: "); Serial.println(phases_0_voltage, 2);
Serial.print("current: "); Serial.println(phases_0_current, 2);
Serial.print("powerActive: "); Serial.println(phases_0_powerActive, 2);
Serial.print("powerReactive: "); Serial.println(phases_0_powerReactive, 2);
Serial.print("powerApparent: "); Serial.println(phases_0_powerApparent, 2);
Serial.print("powerFactor: "); Serial.println(phases_0_powerFactor, 3);
Serial.print("totalForwardActiveEnergy: "); Serial.println(phases_0_totalForwardActiveEnergy, 4);
long support = root["support"]; // 65535
const char* currency = root["currency"]; // "PLN"
float pricePerUnit = root["pricePerUnit"]; // 0.2422
float totalCost = root["totalCost"]; // 361.4
int phases_0_frequency = phases_0["frequency"]; // 50
float phases_0_voltage = phases_0["voltage"]; // 246.63
float phases_0_current = phases_0["current"]; // 2.034
float phases_0_powerActive = phases_0["powerActive"]; // 381.7472
float phases_0_powerReactive = phases_0["powerReactive"]; // 209.59456
float phases_0_powerApparent = phases_0["powerApparent"]; // 472.25728
float phases_0_powerFactor = phases_0["powerFactor"]; // 0.843
float phases_0_phaseAngle = phases_0["phaseAngle"]; // 26.5
float phases_0_totalForwardActiveEnergy = phases_0["totalForwardActiveEnergy"]; // 1492.17718
float phases_0_totalReverseActiveEnergy = phases_0["totalReverseActiveEnergy"]; // 0.01415
float phases_0_totalForwardReactiveEnergy = phases_0["totalForwardReactiveEnergy"]; // 515.63494
float phases_0_totalReverseReactiveEnergy = phases_0["totalReverseReactiveEnergy"]; // 66.79765
int phases_1_number = phases_1["number"]; // 2
int phases_1_frequency = phases_1["frequency"]; // 50
int phases_1_voltage = phases_1["voltage"]; // 0
int phases_1_current = phases_1["current"]; // 0
int phases_1_powerActive = phases_1["powerActive"]; // 0
int phases_1_powerReactive = phases_1["powerReactive"]; // 0
int phases_1_powerApparent = phases_1["powerApparent"]; // 0
int phases_1_powerFactor = phases_1["powerFactor"]; // 0
int phases_1_phaseAngle = phases_1["phaseAngle"]; // 0
int phases_1_totalForwardActiveEnergy = phases_1["totalForwardActiveEnergy"]; // 0
int phases_1_totalReverseActiveEnergy = phases_1["totalReverseActiveEnergy"]; // 0
int phases_1_totalForwardReactiveEnergy = phases_1["totalForwardReactiveEnergy"]; // 0
int phases_1_totalReverseReactiveEnergy = phases_1["totalReverseReactiveEnergy"]; // 0
int phases_2_number = phases_2["number"]; // 3
int phases_2_frequency = phases_2["frequency"]; // 50
int phases_2_voltage = phases_2["voltage"]; // 0
int phases_2_current = phases_2["current"]; // 0
int phases_2_powerActive = phases_2["powerActive"]; // 0
int phases_2_powerReactive = phases_2["powerReactive"]; // 0
int phases_2_powerApparent = phases_2["powerApparent"]; // 0
int phases_2_powerFactor = phases_2["powerFactor"]; // 0
int phases_2_phaseAngle = phases_2["phaseAngle"]; // 0
int phases_2_totalForwardActiveEnergy = phases_2["totalForwardActiveEnergy"]; // 0
int phases_2_totalReverseActiveEnergy = phases_2["totalReverseActiveEnergy"]; // 0
int phases_2_totalForwardReactiveEnergy = phases_2["totalForwardReactiveEnergy"]; // 0
int phases_2_totalReverseReactiveEnergy = phases_2["totalReverseReactiveEnergy"]; // 0
} else {
Serial.println("failed ------------------------------------------------------");
display.clear();
display.drawString(64, 32, "OFFLINE");
display.display();
