It is not an ideal solution but waiting for the implementation of energy meter can be a temporary solution.
To access the Wi-Fi configuration, press button for at least 10 seconds, Led winks in wificonfig.
in the configuration page enter the data for "suplaServer, Email and Supla Device Name (name with which it will be seen in the cloud and DHCP)"
read-only field with the latest Supla connection state.
expectedVoltage -- for calibration.
expectedActivePower -- for calibration.
clear counter -- reset pulse counter.
calibration process:
connect a resistive load with a known consumption, for example a 60W bulb.
access wificonfig (button pressed 10 seconds)
in the "expectedVoltage" field set the voltage of your line for example 227.
in the "expectedActivePower" field, set the consumption of the connected load, for example 60.
press save.
The procedure takes about 15 seconds, then the device restarts and the readings will be correct.
the calibration is only executed if there are data in both fields "expectedVoltage" and "expectedActivePower"
This allows for example to change the Wi-Fi network without recalibrating.
Active Power (W) reading in the humidity channel will be /10
11.1 corresponds to a consumption of 111W
OTA update http://XX:81/update -- xx = device ip. for example http://192.168.1.22:81/update
user: admin
password: pass
