edit:
Fixed incorrect status in the Ap after losing the connection to the cloud.
with on/off button for local control.
The function of the button is to turn off or on with the last RGB and dimer setting (if when its turnet off either from the button or the App the last state was Red 50% dimer 70% when turning on from the button it´s will return to that setting)
keep the button pressed for 10 seconds for wificonfig (green output fully on when accessing wificonfig)
Smooth transition between on/off and color change.
Pinout:
CONFIG_PIN 0 // D3 WiFiconfig
RED_PIN 14 // D5
GREEN_PIN 12 // D6
BLUE_PIN 13 // D7
BRIGHTNESS_PIN 5 // D1
#include <FS.h> // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
extern "C"
#include "user_interface.h"
//#define D0 16 //no internal pullup resistor
//#define D1 5
//#define D2 4
//#define D3 0 //must not be pulled low during power on/reset, toggles value during boot
//#define D4 2 //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15 //must not be pulled high during power on/reset
#define CONFIG_PIN 0 // WiFiconfig
#define RED_PIN 14
#define GREEN_PIN 12
#define BLUE_PIN 13
#define BRIGHTNESS_PIN 5
char Supla_server[80];
char Location_id[15];
char Location_Pass[34];
char Supla_name[51];
char up_host[21] = "SuplaRGBW";
byte mac[6];
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000; // config delay 10 seconds ---------- opóźnienie konfiguracji 10 sekund
int C_W_state2 = HIGH;
long C_W_delay2 = 50; // button debounce
bool shouldSaveConfig = false;
bool initialConfig = false;
bool pr_wifi = true;
bool wificonfig = false;
bool state10 = true;
int s;
unsigned long wifi_checkDelay = 20000;
unsigned long wifimilis;
unsigned long mem_milis;
unsigned char _red = 0;
unsigned char _green = 255;
unsigned char _blue = 0;
unsigned char _color_brightness = 0;
unsigned char _brightness = 0;
int _col_bright = 0;
int _bright = 0;
int bright = 0 ;
int col_bright = 0 ;
int redin = 0;
int redout = 0;
int greenin = 0;
int greenout = 0;
int bluein = 0;
int blueout = 0;
int memBr;
int memCBr;
int memRed;
int memGreen;
int memBlue;
int Power_Off;
WiFiClient client;
WiFiManager wifiManager;
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
void ondemandwifiCallback () {
wificonfig = true;
digitalWrite(GREEN_PIN, HIGH);digitalWrite(RED_PIN, LOW);digitalWrite(BLUE_PIN, LOW);digitalWrite(BRIGHTNESS_PIN, LOW);
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 80);
WiFiManagerParameter custom_Location_id("ID", "Location id", Location_id, 15);
WiFiManagerParameter custom_Location_Pass("Password", "Location Pass", Location_Pass, 34);
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
wifiManager.setBreakAfterConfig(true);
wifiManager.setSaveConfigCallback(saveConfigCallback);
wifiManager.addParameter(&custom_Supla_server);
wifiManager.addParameter(&custom_Location_id);
wifiManager.addParameter(&custom_Location_Pass);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
wifiManager.setMinimumSignalQuality(8);
//wifiManager.setShowStaticFields(true); // force show static ip fields
//wifiManager.setShowDnsFields(true); // force show dns field always
if (!wifiManager.startConfigPortal("Supla_RGBW")) {Serial.println("Not connected to WiFi but continuing anyway.");
} else {Serial.println("connected...yeey :)");} //if you get here you have connected to the WiFi}
strcpy(Supla_server, custom_Supla_server.getValue());
strcpy(Location_id, custom_Location_id.getValue());
strcpy(Location_Pass, custom_Location_Pass.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
WiFi.softAPdisconnect(true); // close AP
void supla_timer() {
if (bright > _bright){
_bright = _bright + 1;
set_rgbw();
}else if (bright < _bright){
_bright = _bright - 1;
set_rgbw();
if (col_bright > _col_bright){
_col_bright = _col_bright + 1;
set_rgbw();
}else if (col_bright < _col_bright){
_col_bright = _col_bright - 1;
set_rgbw();
if (greenin > greenout){
greenout = greenout + 1;
set_rgbw();
}else if (greenin < greenout){
greenout = greenout - 1;
set_rgbw();
if (redin > redout){
redout = redout + 1;
set_rgbw();
}else if (redin < redout){
redout = redout - 1;
set_rgbw();
if (bluein > blueout){
blueout = blueout + 1;
set_rgbw();
}else if (bluein < blueout){
blueout = blueout - 1;
set_rgbw();
void get_rgbw_value(int channelNumber, unsigned char *red, unsigned char *green, unsigned char *blue, unsigned char *color_brightness, unsigned char *brightness) {
*brightness = _brightness;
*color_brightness= _color_brightness;
*red = _red;
*green = _green;
*blue = _blue;
void set_rgbw() {
analogWrite(BRIGHTNESS_PIN, (_bright * 1023) / 100);
int out_br =((_col_bright * 1023) / 100);
int out_red = map(redout, 0, 255, 0,out_br);
analogWrite(RED_PIN, (out_red));
int out_green = map(greenout, 0, 255, 0,out_br);
analogWrite(GREEN_PIN, (out_green));
int out_blue = map(blueout, 0, 255, 0,out_br);
analogWrite(BLUE_PIN, (out_blue));
mem_milis = (millis()+3000);
void set_rgbw_value(int channelNumber, unsigned char red, unsigned char green, unsigned char blue, unsigned char color_brightness, unsigned char brightness) {
if(((String(brightness).toInt()) == 0) && ((String(color_brightness).toInt()) == 0)){Power_Off = 1;}else{Power_Off = 0;}
_brightness = brightness;
bright = (String(_brightness).toInt());
_color_brightness= color_brightness;
col_bright = (String(_color_brightness).toInt());
_red = red;
redin = (String(_red).toInt());
_green = green;
greenin = (String(green).toInt());
_blue = blue;
bluein = (String(blue).toInt());
void save_epp(){
EEPROM.write(0,memRed);EEPROM.write(1,memGreen);EEPROM.write(2,memBlue);EEPROM.write(3,memBr);EEPROM.write(4,memCBr);EEPROM.write(5,Power_Off);
EEPROM.commit();
void read_epp(){
memRed = EEPROM.read(0);memGreen = EEPROM.read(1);memBlue = EEPROM.read(2);memBr = EEPROM.read(3);memCBr = EEPROM.read(4);Power_Off = EEPROM.read(5);
if (Power_Off == 0){
bright = memBr;
col_bright = memCBr;
redin = memRed;
greenin = memGreen;
bluein = memBlue;
void status_func(int status, const char *msg) { // ------------------------ Status --------------------------
s=status; // -- to check if we are registered and ready before restore from memory
// ------------ SETUP -----------------
void setup () {
wifi_set_sleep_type(NONE_SLEEP_T);
Serial.begin (115200);
delay (10);
EEPROM.begin(64);
pinMode(CONFIG_PIN, INPUT_PULLUP);
analogWriteFreq(100);
if (WiFi.SSID()==""){
initialConfig = true;
WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
Serial.println("mounting FS...");//read configuration from FS json
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial); //print config data to serial on startup
if (json.success()) {
Serial.println("\nparsed json");
strcpy(Supla_server, json["Supla_server"]);
strcpy(Location_id, json["Location_id"]);
strcpy(Location_Pass, json["Location_Pass"]);
strcpy(Supla_name, json["Supla_name"]);
} else {
Serial.println("failed to load json config");
} else {
Serial.println("failed to mount FS");
wifi_station_set_hostname(up_host);
read_epp();
if (Power_Off == 0){_brightness = memBr;_color_brightness= memCBr; _red = memRed;_green = memGreen;_blue = memBlue;}
else{_brightness = 0;_color_brightness= 0; _red = memRed;_green = memGreen;_blue = memBlue;}
SuplaDevice.setTimerFuncImpl(&supla_timer);
SuplaDevice.setRGBWCallbacks(&get_rgbw_value, &set_rgbw_value);
uint8_t mac[WL_MAC_ADDR_LENGTH];
WiFi.macAddress(mac);
char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
SuplaDevice.addRgbControllerAndDimmer ();
SuplaDevice.setName(Supla_name);
int LocationID = atoi(Location_id);
SuplaDevice.begin(GUID,
mac,
Supla_server,
LocationID,
Location_Pass);
// ---------------- LOOP ------------------------------ -----------------------------
void loop () {
if (initialConfig == true){
Serial.println("initial config triger");
ondemandwifiCallback () ;
if (shouldSaveConfig == true) {
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["Supla_server"] = Supla_server;
json["Location_id"] = Location_id;
json["Location_Pass"] = Location_Pass;
json["Supla_name"] = Supla_name;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.prettyPrintTo(Serial); //print config data to serial
json.printTo(configFile);
configFile.close();
Serial.println("config saved");
if (wificonfig == true){
delay(5000);
ESP.restart();
if (millis() > mem_milis){
if (EEPROM.read(5) != Power_Off){
save_epp();
if (((String(_brightness).toInt()) != EEPROM.read(3)) || ((String(_color_brightness).toInt()) != EEPROM.read(4)) || ((String(_red).toInt()) !=EEPROM.read(0)) || ((String(_green).toInt()) != EEPROM.read(1)) || ((String(_blue).toInt()) != EEPROM.read(2))){
memBr = (String(_brightness).toInt());memCBr =(String(_color_brightness).toInt());memRed =(String(_red).toInt());memGreen = (String(_green).toInt());memBlue = (String(_blue).toInt());
save_epp();
int C_W_read = digitalRead(CONFIG_PIN);{
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay2) {
if (C_W_read != C_W_state2) {
Serial.println("short press");
C_W_state2 = C_W_read;
if (C_W_state2 == LOW) {
Power_Off = 1;
_brightness = 0;
SuplaDevice.channelSetRGBWvalues(0,memRed,memGreen,memBlue,0,0); // restore _color_brightness & _brightness
}else{
_color_brightness = memCBr;
Power_Off = 0;
SuplaDevice.channelSetRGBWvalues(0,memRed,memGreen,memBlue,memCBr,memBr); // restore _color_brightness & _brightness
if (Power_Off){
Serial.println("Power sate Off");
}else{
Serial.println("Power sate On");
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
Serial.println("long press");
C_W_state = C_W_read;
if (C_W_state == LOW) {
last_C_W_state = C_W_read;
switch (s) { // ------------------------------------------------ Status ------------------------------------
case 17: // ----- STATUS_REGISTERED_AND_READY
if (state10 == true){
read_epp();
yield();
}else{
yield();
_brightness = 0;
SuplaDevice.channelSetRGBWvalues(0,memRed,memGreen,memBlue,0,0); // off
state10 = false;
break;
case 10: // --------------------- REGISTER_IN_PROGRESS ----------------------
state10 = true;
break;
if (WiFi.status() == WL_CONNECTED){
SuplaDevice.iterate();
delay(50);
if (pr_wifi == true){
Serial.println("");
Serial.println("CONNECTED");
Serial.print("local IP: ");
Serial.print("subnetMask: ");
Serial.print("gatewayIP: ");
long rssi = WiFi.RSSI();
Serial.print("Signal Strength (RSSI): ");
Serial.print(rssi);
Serial.println(" dBm");
pr_wifi = false;
//----------------Supla.org ethernet layer --------------------------- -------------
if ( size > 0 ) {
return -1;
return client.connected();
client.stop();
SuplaDeviceCallbacks supla_arduino_get_callbacks (void) {
SuplaDeviceCallbacks cb;
cb.tcp_read = & supla_arduino_tcp_read;
cb.tcp_write = & supla_arduino_tcp_write;
cb.eth_setup = & supla_arduino_eth_setup;
cb.svr_connected = & supla_arduino_svr_connected;
cb.svr_connect = & supla_arduino_svr_connect;
cb.svr_disconnect = & supla_arduino_svr_disconnect;
cb.get_temperature = NULL;
cb.get_rgbw_value = & get_rgbw_value;
cb.set_rgbw_value = & set_rgbw_value;
return cb;
