With Oled display and buttons for Automatic/Manual, Manual On/Off, thermostat setting -0.5º and + 0.5º
operation with both the thermostat with or without OLED
without OLED:
viewtopic.php?f=10&t=5294
with OLED
viewtopic.php?f=10&t=5320
the display shows the status of the thermostat the same as the Oled version.
the screen automatically dims after 15 seconds and the first press on one of the buttons makes it bright again.
if any button is pressed while the screen is dimmed, it will glow and the following presses will acruate according to the button pressed.
After 15 seconds without pressing any button the screen dims.
In wificonfig you will have to setup the suplaserver and DirectLink data:
D_Link_1 --- paste the DirectLink corresponding to the Auto/Man channel.
D_Link_2 --- paste the DirectLink corresponding to the Manual On/Off channel.
D_Link_3 --- paste the DirectLink corresponding to the thermostat setting channel.
Link Temp -- paste the DirectLink corresponding to the temperature channel.
Link Ther -- paste the DirectLink corresponding to the thermostat channel.
Gpio:
Gpio 0 ; //D3-SDA
Gpio 2 ; //D4-SCL
Gpio 5 ; //D1 // triger Link 1 and wifi config
Gpio 4 ; //D2 // triger Link 2
Gpio 14; //D5 // triger Link 3
Gpio 12; //D6 // triger Link 4
#include <FS.h> // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <WiFiClientSecure.h>
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <WiFiManager.h> //--------- https://github.com/tzapu/WiFiManager/tree/0.14 -------------
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
//#define D0 16 //no internal pullup resistor
//#define D1 5
//#define D2 4
//#define D3 0 //must not be pulled low during power on/reset, toggles value during boot
//#define D4 2 //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15 //must not be pulled high during power on/reset
int button_1 = 5 ; //D1 // triger Link 1 and wifi config
int button_2 = 4 ; //D2 // triger Link 2
int button_3 = 14; //D5 // triger Link 3
int button_4 = 12; //D6 // triger Link 4
#define BTN_COUNT 4
//#include "SSD1306Wire.h" //----- 0.96 Oled --- https://github.com/ThingPulse/esp8266-oled-ssd1306
//SSD1306Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 0.96 Oled ---
#include "SH1106Wire.h" //----- 1.3 Oled ---
SH1106Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 1.3 Oled ---
const char* host = ".org";
const int httpsPort = 443;
const char* fingerprint = "CF 05 98 89 CA FF 8E D8 5E 5C E0 C2 E4 F7 E6 C3 C7 50 DD 5C";
char Supla_server[20];
char D_Link_1[61];
char D_Link_2[61];
char D_Link_3[61];
char Link_T[61];
char Link_T2[61];
byte mac[6];
String url = "/direct";
bool shouldSaveConfig = false;
bool initialConfig = false;
bool dimm = false;
unsigned long dimm_milis ;
bool Read1on = false;
bool Read2on = false;
bool onsend = false;
bool pr_wifi = false;
bool can1 = false;
bool can2 = false;
int Temp_mtbs = 5000; //Temperature update interval 5 seconds
unsigned long Temp_lasttime;
int TempDisp_mtbs = 2500; //Temperature display interval 2.5 seconds
unsigned long TempDisp_lasttime;
int lcd_n = 0;
int up_n = 0;
double Temp = -127.0;
double Temp2 = -127.0;
unsigned long wifi_checkDelay = 20000; // wifi reconnect delay tray to reconnect every 20 seconds ------------ Wi-Fi podłącz tacę opóźniającą, aby ponownie połączyć się co 20 sekund
unsigned long wifimilis; //
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000; // config delay 10 seconds ------------ opóźnienie konfiguracji 10 sekund
int row = 0;
int timeout = 180; // seconds to run for
const uint8_t logo32_glcd_bmp[] PROGMEM = //logo supla 32
0x00,0x00,0x00,0x00,0xC0,0x1F,0x00,0x00,0xE0,0x7F,0x00,0x00,
0xF0,0x70,0x00,0x00,0x30,0xE0,0x00,0x00,0x38,0xC0,0x00,0x00,
0x18,0xC0,0x01,0x00,0x18,0xC0,0x01,0x00,0x38,0xC0,0x00,0x00,
0x38,0xE0,0x01,0x00,0x70,0xF0,0x07,0x00,0xE0,0x7F,0x0E,0x00,
0xC0,0x3F,0x38,0x00,0x00,0x1F,0xE0,0x0F,0x00,0x18,0xC0,0x1F,
0x00,0x18,0xC0,0x30,0x00,0x18,0xC0,0x30,0x00,0x30,0xC0,0x30,
0x00,0x30,0x80,0x1F,0x00,0x30,0xC0,0x0F,0x00,0x20,0x60,0x00,
0x00,0x60,0x20,0x00,0x00,0x60,0x30,0x00,0x00,0x40,0x18,0x00,
0x00,0xC0,0x0D,0x00,0x00,0xC0,0x07,0x00,0x00,0x60,0x04,0x00,
0x00,0x20,0x0C,0x00,0x00,0x20,0x0C,0x00,0x00,0x60,0x06,0x00,
0x00,0xC0,0x03,0x00,0x00,0x00,0x00,0x00
const uint8_t logo16_wifi_bmp[] PROGMEM = //logo wifi 16
0x00,0x00,0x00,0x00,0xE0,0x07,0x38,0x1C,0xC4,0x23,0x72,0x4E,
0x08,0x10,0xE4,0x27,0x10,0x0C,0x90,0x09,0x40,0x02,0x60,0x06,
0x40,0x02,0x80,0x01,0x00,0x00,0x00,0x00
const uint8_t logo16_supla_bmp[] PROGMEM = //logo supla 16
0x30,0x00,0x7C,0x00,0xC4,0x00,0x86,0x00,0x84,0x00,0xDC,0x03,
0x78,0x36,0x60,0x78,0x40,0x48,0x40,0x38,0x40,0x04,0x80,0x06,
0x80,0x03,0x40,0x02,0xC0,0x03,0x00,0x01
const uint8_t logo_Power_off[] PROGMEM = //Power off
0xe0, 0xff, 0xff, 0xff, 0x03, 0x38, 0xfc, 0xff, 0xff, 0x0f, 0x0c, 0xf0,
0xff, 0xff, 0x3f, 0x06, 0xe0, 0xff, 0xff, 0x3f, 0x02, 0xc0, 0xcf, 0x43,
0x78, 0x03, 0xc0, 0x33, 0x43, 0x78, 0x01, 0xc0, 0x7b, 0x7b, 0xff, 0x01,
0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0x7b,
0x7b, 0xff, 0x03, 0xc0, 0x33, 0x7b, 0xff, 0x02, 0xc0, 0xcf, 0x7b, 0x7f,
0x06, 0xe0, 0xff, 0xff, 0x7f, 0x0c, 0xf0, 0xff, 0xff, 0x3f, 0x18, 0xfc,
0xff, 0xff, 0x1f, 0xf0, 0xff, 0xff, 0xff, 0x07,
const uint8_t logo_Power_on[] PROGMEM = //Power on
0xe0, 0xff, 0xff, 0xff, 0x07, 0x38, 0x00, 0x00, 0x30, 0x0c, 0x0c, 0x00,
0x00, 0x18, 0x18, 0x06, 0x00, 0x00, 0x0c, 0x30, 0x02, 0x0e, 0x00, 0x06,
0x60, 0x03, 0x9f, 0x19, 0x02, 0x40, 0x81, 0xb1, 0x1b, 0x03, 0xc0, 0x81,
0xa0, 0x1a, 0x01, 0x80, 0x81, 0xa0, 0x1e, 0x01, 0x80, 0x81, 0xb1, 0x1c,
0x01, 0xc0, 0x03, 0x9b, 0x18, 0x03, 0x40, 0x02, 0x8e, 0x18, 0x02, 0x60,
0x06, 0x00, 0x00, 0x06, 0x20, 0x0c, 0x00, 0x00, 0x0c, 0x38, 0x38, 0x00,
0x00, 0x18, 0x0c, 0xe0, 0xff, 0xff, 0xff, 0x07,
typedef struct { //------------------------------------------- BTN ----------------------------------------------------
int pin;
char last_val;
unsigned long last_time;
} _btn_t;
_btn_t btn[BTN_COUNT];
void btn_init() {
for(int a=0;a<BTN_COUNT;a++)
if (btn[a].pin > 0) {
pinMode(btn[a].pin-1, INPUT_PULLUP);
btn[a].last_val = digitalRead(btn[a].pin-1);
btn[a].last_time = millis();
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
void ondemandwifiCallback () {
display.clear();
display.setContrast(100, 241, 64);
display.setTextAlignment(TEXT_ALIGN_CENTER);
display.setFont(ArialMT_Plain_10);
display.drawString(64, 16, "wifi config connect");
display.drawString(64, 28, "to wifi hotspot");
display.setFont(ArialMT_Plain_16);
display.drawString(64, 44, "RemoteThermostat");
display.display();
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 20);
WiFiManagerParameter custom_D_Link_1("LinkA", "D_Link_1", D_Link_1, 61);
WiFiManagerParameter custom_D_Link_2("LinkB", "D_Link_2", D_Link_2, 61);
WiFiManagerParameter custom_D_Link_3("LinkC", "D_Link_3", D_Link_3, 61);
WiFiManagerParameter custom_Link_T("LinkTemp", "Link Temp..", Link_T, 61);
WiFiManagerParameter custom_Link_T2("LinkTher", "Link Ther..", Link_T2, 61);
WiFiManager wifiManager;
wifiManager.setSaveConfigCallback(saveConfigCallback);
wifiManager.addParameter(&custom_Supla_server);
wifiManager.addParameter(&custom_D_Link_1);
wifiManager.addParameter(&custom_D_Link_2);
wifiManager.addParameter(&custom_D_Link_3);
wifiManager.addParameter(&custom_Link_T);
wifiManager.addParameter(&custom_Link_T2);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;margin-left: auto; margin-right: auto;width:60%;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
wifiManager.setBreakAfterConfig(true);
wifiManager.setMinimumSignalQuality();
wifiManager.setConfigPortalTimeout(timeout);
if (!wifiManager.startConfigPortal("Remote_Thermostat")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
ESP.restart();
delay(5000);
Serial.println("connected...yeey :)");
strcpy(Supla_server, custom_Supla_server.getValue());
strcpy(D_Link_1, custom_D_Link_1.getValue());
strcpy(D_Link_2, custom_D_Link_2.getValue());
strcpy(D_Link_3, custom_D_Link_3.getValue());
strcpy(Link_T, custom_Link_T.getValue());
strcpy(Link_T2, custom_Link_T2.getValue());
WiFi.softAPdisconnect(true); // close AP
void TH_Overlay() {
display.clear();
if (Temp > -100){
display.setFont(ArialMT_Plain_24);
display.drawString(64, 20, String(Temp, 2) + "ºC");
}else{
display.drawString(64, 20, "-----");
if (Read1on == true){
if (can1 == 1){
display.drawString(64, 48, "Auto Set " + String(Temp2, 1) + "ºC");
}else{
display.drawString(64, 48, "Manual mode");
if (pr_wifi == true){
display.drawXbm(1, 0, 16, 16, logo16_wifi_bmp);// -------------------------------------------------- oled wifi ok --------
if (onsend == true){
display.drawXbm(24, 0, 16, 16, logo16_supla_bmp);// ------------------------------------------------ oled supla ok --------
if (Read2on == true){
if (can2 == 0){
display.drawXbm(86, 0, 40, 16, logo_Power_off);// ------------------------------------------------- Relay off --------
if (can2 == 1){
display.drawXbm(86, 0, 40, 16, logo_Power_on);// -------------------------------------------------- Relay on ---------
display.display();
yield();
TempDisp_lasttime = millis();
void iterate_btn() {
char v;
unsigned long now = millis();
for(int a=0;a<4;a++)
v = digitalRead(btn[a].pin-1);
if (v != btn[a].last_val && now - btn[a].last_time ) {
btn[a].last_val = v;
btn[a].last_time = now;
delay(75);
if (v==0)
if (dimm == true){
dimm_milis = millis() + 15000 ;
display.setContrast(100, 230, 60);
dimm = false;
TH_Overlay();
return;
}else{
if (a == 0){
onsend = true;
TH_Overlay();
url = D_Link_1;
url = (url + "/toggle");
direct_Link();
//delay(100);
D_Link_read();
return;
if (a == 1){
onsend = true;
TH_Overlay();
url = D_Link_2;
direct_Link();
//delay(100);
D_Link_read2();
return;
if (a == 2 ) {
onsend = true;
TH_Overlay();
url = D_Link_3;
url = (url + "/turn-off");
direct_Link();
Temp2_D_Link();
return;
if (a == 3 ) {
onsend = true;
TH_Overlay();
url = D_Link_3;
url = (url + "/turn-on");
direct_Link();
Temp2_D_Link();
return;
void setup() { //------------------------------------------------ Setup ----------------------------------------------
Serial.begin(115200);
memset(btn, 0, sizeof(btn));
btn[0].pin =button_1 +1; // pin gpio buton +1
btn[1].pin =button_2 +1; // pin gpio buton +1
btn[2].pin =button_3 +1; // pin gpio buton +1
btn[3].pin =button_4 +1; // pin gpio buton +1
btn_init();
display.init();
display.flipScreenVertically();
display.clear();
display.drawString(33, 40, "SUPLA");
display.drawXbm(0, 16, 32, 32,logo32_glcd_bmp );
display.display();
if (WiFi.SSID()==""){ initialConfig = true;}
Serial.println("mounting FS...");
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
Serial.println(jsonBuffer.size());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
strcpy(Supla_server, json["Supla_server"]);
strcpy(D_Link_1, json["D_Link_1"]);
strcpy(D_Link_2, json["D_Link_2"]);
strcpy(D_Link_3, json["D_Link_3"]);
strcpy(Link_T, json["Link_T"]);
strcpy(Link_T2, json["Link_T2"]);
} else {Serial.println("failed to load json config");}
} else {Serial.println("failed to mount FS");}
host = Supla_server;
WiFi.mode(WIFI_STA);
dimm_milis = millis() + 15000;
void loop() {
if (initialConfig) {
ondemandwifiCallback () ;
if (millis() > dimm_milis){
if (dimm == false){
display.setContrast(50, 50, 30);
display.display();
dimm = true ;
if (WiFi.status() != WL_CONNECTED)
pr_wifi = false;
WiFi_up();
iterate_btn();
int C_W_read = digitalRead(button_1);{
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
Serial.println("Triger sate changed");
C_W_state = C_W_read;
if (C_W_state == LOW) {
last_C_W_state = C_W_read;
if (millis() > Temp_lasttime + Temp_mtbs) { //-------------Temp_lasttime--------------------
if (up_n < 5) { up_n = up_n +1;}
if (up_n == 5) {up_n = 1;}
if (up_n == 1){
onsend = true;
TH_Overlay();
Temp_D_Link();
if (up_n == 2){
onsend = true;
TH_Overlay();
Temp2_D_Link();
if (up_n == 3){
onsend = true;
TH_Overlay();
D_Link_read();
if (up_n == 4){
onsend = true;
TH_Overlay();
D_Link_read2();
Temp_lasttime = millis();
if (shouldSaveConfig) {
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["Supla_server"] = Supla_server;
json["D_Link_1"] = D_Link_1;
json["D_Link_2"] = D_Link_2;
json["D_Link_3"] = D_Link_3;
json["Link_T"] = Link_T;
json["Link_T2"] = Link_T2;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {Serial.println("failed to open config file for writing");}
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
Serial.println("config saved");
delay(3000);
ESP.restart();
delay(5000);
if (millis() > TempDisp_lasttime + TempDisp_mtbs) { //-------------TempDisp_lasttime--------------------
TH_Overlay();
void WiFi_up() {
if (millis() > wifimilis) {
WiFi.begin();
for (int x = 20; x > 0; x--)
if (x == 1){
wifimilis = (millis() + wifi_checkDelay) ;
if (WiFi.status() == WL_CONNECTED)
pr_wifi = true;
break;
} else{
delay(500);
Serial.print(".");
pr_wifi = true;
Serial.println("");
Serial.println("Connected");
Serial.println("Adres IP: ");
Serial.print(WiFi.localIP());
Serial.print(" / ");
Serial.print(WiFi.subnetMask());
long rssi = WiFi.RSSI();
Serial.print("(RSSI): ");
Serial.print(rssi);
Serial.println(" dBm");
onsend = true;
TH_Overlay();
Temp_D_Link();
Temp2_D_Link();
url = D_Link_1;
D_Link_read();
url = D_Link_2;
D_Link_read2();
Serial.println("");
Serial.println("connection failed");
pr_wifi = false;
void direct_Link() {
WiFiClientSecure client;
if (!client.connect(host, httpsPort)) {
return;
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"User-Agent: ESP8266\r\n" +
"Connection: close\r\n\r\n");
while (client.connected()) {
String line = client.readStringUntil('\n');
if (line == "\r") {
break;
String line = client.readStringUntil('}');
line = line + "}";
if (line.indexOf("true") >0) {
} else {
Serial.println("failed");
onsend = false;
TH_Overlay();
void Temp_D_Link() {
url = Link_T;
return;
client.print(String("GET ") + url + "/read" + " HTTP/1.1\r\n" +
if (line == "\r") {
break;
line = line + "}";
DynamicJsonBuffer jsonBuffer(200);
JsonObject& root = jsonBuffer.parseObject(line);
if (!root.success()) {
Serial.println("parseObject() failed");
return;
Temp = root["temperature"];
onsend = false;
TH_Overlay();
void Temp2_D_Link() {
url = Link_T2;
return;
if (line == "\r") {
break;
line = line + "}";
return;
Temp2 = root["temperature"];
onsend = false;
TH_Overlay();
void D_Link_read() {
url = D_Link_1;
Read1on = false;
return;
if (line == "\r") {
break;
line = line + "}";
Read1on = false;
return;
can1 = root["on"];
Read1on = true;
onsend = false;
TH_Overlay();
void D_Link_read2() {
url = D_Link_2;
Read2on = false;
return;
if (line == "\r") {
break;
line = line + "}";
Read2on = false;
return;
can2 = root["on"];
Read2on = true;
onsend = false;
TH_Overlay();
