PWgregor36 wrote: Sat Nov 26, 2022 4:44 pm
/Documents/Arduino/libraries/LittleFS/src/LittleFS.h:34:25: fatal error: flash_utils.h: No such file or directory
compilation terminated.
thermostat with Oled display
I need versions for sonofbasic r2. Is there any possibility to send the software. Set online and that if there is no WIFI, it works with a pre-set temperature.
this version does not save the temperature set with the buttons on the serverelmaya wrote: Wed Sep 18, 2019 4:20 pm compiled firmware for Oled 1.3" (SH1106)
surely someone needs it![]()
flicker symptom fixed![]()
supla_Termostst_oled1_3_dimm_V042_DOUT_16Mbit.rar
Hi ,elmaya wrote: Sun Feb 27, 2022 12:14 pm update
added rotary encoder for local control.
Thermostat_DS_OLED_C.rarCode: Select all
bool relayOnLevel = LOW; // "HIGH" for active high relay, "LOW" for active low relay.
Is there anyone who could compile this program and upload .bin file for me?
I spent hours of my life to sorted library fails but I failed,
only difference id to control relay by LOW signal.
Thanks.
I no longer have the strength to do this. There is a version of this thermostat with cooling and relay status controls from the app
Hello, I'm joining the question ... Please upload this soft to sonoff bacisonoff basic r2.
Just FYI,
Active Low relay module based on PNP transistor will not work properly-stays ON all time. Use with optocoupler one.
