Thanks for a good job on this project. In my project I also want to use 0.1C resolution.zzrr wrote: Sun Oct 30, 2022 8:52 pm Hi,
Could you please provide the source code for the same, but with regulation at least 0.5C. Super with 0.1C.
Thank you
thermostat with Oled display
Hello everyone,
thermostat based on the elmaya project with a setting resolution of 0.1C.
SSD1306Wire display // D3-SDA D4-SCL ----- 0.96 Oled ---
int relay_pin = 5; // D1
int ds_pin = 4; // D2
int button_pin = 14; // D5
#define button2_pin 12 // D6
#define button3_pin 13 // D7
I changed the relay code for my own needs, maybe it will be useful to someone else. Settings every 0.1C and adjustable hysteresis. Controlling the thermostat every 0.1C and added a hysteresis setting in the range from 0 to 10C every 0.1C from the application level. The hysteresis is also visible on the display. There are three physical buttons. One click Auto/Manual, double click turns the relay on or off manually if the thermostat is set to manual. The other two buttons for setting the temperature, when pressed for a long time, change the temperature quickly. Hysteresis set in the application using a switch or dimmer.
For the main part of the code thanks to elmaya.
viewtopic.php?p=141788#p141788
Hello, can you make adjustments to the displayed temperature on oled in the version with buttons?
shows 1.5C too much
shows 1.5C too much
quote from datasheets:
"...Benefits and Features
• Measures Temperatures from -55°C to +125°C
(-67°F to +257°F)
• ±0.5°C Accuracy from -10°C to +85°C..."
in my opinion your DS18B20 is enclosed in a case and is heated by a microcontroller or power supply or something else.
if it's not closed, it's broken.
However if you want a fix in the code,
find:
class TermostatTemp : public Supla::Sensor::Thermometer
public:
TermostatTemp() {}
void onInit()
channel.setNewValue(getValue());
double getValue()
return ThermostatTemperature;
void iterateAlways()
if (millis() - lastReadTime > 2500)
lastReadTime = millis();
actualTemp = DsTemp->getValue();
change:
actualTemp = DsTemp->getValue() - 1,5;
also on the SUPLA portal
I have the sensor on a 15cm cable, I tested 3 sensors and I have the same on each, it is possible that they are of poor quality.
the given example does not match "supla_Termostst_oled_dimm_V04.ino" and this is the software I use.
fatal error: LittleFS.h: No such file or directoryzzrr wrote: Mon Nov 14, 2022 12:13 am Hello everyone,
int relay_pin = 5; // D1 -- 5
int ds_pin = 4; // D2 -- 4
int button_pin = 14; // D5 -- 14
#define button2_pin 12 // D6 -- 12
#define button3_pin 13 // D7 -- 13
/* Copyright (C) AC SOFTWARE SP. Z O.O. This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version. This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with this program; if not, write to the Free Software Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. */ #define supla_lib_config_h_ // silences debug messages #include <LittleFS.h> #include <WiFiManager.h> #include <ArduinoJson.h> #include <EEPROM.h> #include <ESP8266TrueRandom.h> #include <SuplaDevice.h> #include <supla/control/relay.h> #include <supla/control/virtual_relay.h> #include <supla/control/button.h> #include <supla/sensor/DS18B20.h> #include <supla/control/dimmer_base.h> #include <supla/network/esp_wifi.h> #define STORAGE_OFFSET 512 #include <supla/storage/eeprom.h> Supla::Eeprom eeprom(STORAGE_OFFSET); Supla::ESPWifi wifi("SSID", "PASS"); //------ Do not change----wifimanager takes care------ #include "SSD1306Wire.h" //----- 0.96 Oled --- https://github.com/ThingPulse/esp8266-oled-ssd1306 SSD1306Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 0.96 Oled --- //#include "SH1106Wire.h" //----- 1.3 Oled --- // SH1106Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 1.3 Oled --- extern "C" { #include "user_interface.h" } //#define D0 16 //no internal pullup resistor //#define D1 5 //#define D2 4 //DS18B20 //#define D3 0 //must not be pulled low during power on/reset, toggles value during boot //#define D4 2 //must not be pulled low during power on/reset, toggles value during boot //#define D5 14 //#define D6 12 //#define D7 13 //#define D8 15 //must not be pulled high during power on/reset //#define RX 3 //High at boot //#define TX 1 //must not be pulled low during power on/reset int relay_pin = 5; // D1 -- 5 int relay_pin1 = 0; // D0 -- int ds_pin = 4; // D2 -- 4 int button_pin = 14; // D5 -- 14 #define button2_pin 12 // D6 -- 12 #define button3_pin 13 // D7 -- 13 bool relayOnLevel = HIGH; // "HIGH" for active high relay, "LOW" for active low relay. bool Protected = false; // if "true" disables the possibility of activating the relay in manual mode. long C_W_delay = 10000; // ---------------------- config delay 10 seconds --------------------------- int C_W_state = HIGH; int last_C_W_state = HIGH; unsigned long time_last_C_W_change = 0; char Supla_server[81] = ("svrXX.supla.org"); // jeśli nie działa config wpisać char Email[81] = ("xxx@xx.xx"); // jeśli nie działa config wpisać char Supla_name[51] = ("Thermostat"); char term_hist[5] = ("1.0"); char Supla_status[51] = ("No server address"); char Router_SSID[32]; // jeśli nie działa config uzupełnić char Router_SSID[32] = "xxxxxxxxxxxx" char Router_Pass[64]; // jeśli nie działa config uzupełnić char Router_Pass[64] = "xxxxxxxxxxxx" bool shouldSaveConfig = false; bool initialConfig = false; bool starting = true; int s; char GUID[SUPLA_GUID_SIZE]; char AUTHKEY[SUPLA_AUTHKEY_SIZE]; byte uuidNumber[16]; static const char logo[] PROGMEM = "<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>"; double ThermostatTemperature = 20.5; double actualTemp = -127.0; double Term_Hist = 1.0; bool doSaveTermSetTemp = false; bool WiFiConected = false; bool dimm = false; unsigned long TempDisp_mtbs = 5000U; unsigned long TempDisp_lasttime; unsigned long dimm_mtbs = 15000U; unsigned long dimm_lasttime; WiFiManager wifiManager; Supla::Control::VirtualRelay *relay_0 = nullptr; Supla::Sensor::DS18B20 *DsTemp = nullptr; Supla::Control::RGBWBase *miDimmToTemp_hist = nullptr; const uint8_t logo32_glcd_bmp[] PROGMEM = // logo supla 32 { 0x00, 0x00, 0x00, 0x00, 0xC0, 0x1F, 0x00, 0x00, 0xE0, 0x7F, 0x00, 0x00, 0xF0, 0x70, 0x00, 0x00, 0x30, 0xE0, 0x00, 0x00, 0x38, 0xC0, 0x00, 0x00, 0x18, 0xC0, 0x01, 0x00, 0x18, 0xC0, 0x01, 0x00, 0x38, 0xC0, 0x00, 0x00, 0x38, 0xE0, 0x01, 0x00, 0x70, 0xF0, 0x07, 0x00, 0xE0, 0x7F, 0x0E, 0x00, 0xC0, 0x3F, 0x38, 0x00, 0x00, 0x1F, 0xE0, 0x0F, 0x00, 0x18, 0xC0, 0x1F, 0x00, 0x18, 0xC0, 0x30, 0x00, 0x18, 0xC0, 0x30, 0x00, 0x30, 0xC0, 0x30, 0x00, 0x30, 0x80, 0x1F, 0x00, 0x30, 0xC0, 0x0F, 0x00, 0x20, 0x60, 0x00, 0x00, 0x60, 0x20, 0x00, 0x00, 0x60, 0x30, 0x00, 0x00, 0x40, 0x18, 0x00, 0x00, 0xC0, 0x0D, 0x00, 0x00, 0xC0, 0x07, 0x00, 0x00, 0x60, 0x04, 0x00, 0x00, 0x20, 0x0C, 0x00, 0x00, 0x20, 0x0C, 0x00, 0x00, 0x60, 0x06, 0x00, 0x00, 0xC0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00}; const uint8_t logo16_wifi_bmp[] PROGMEM = // logo wifi 16 { 0x00, 0x00, 0x00, 0x00, 0xE0, 0x07, 0x38, 0x1C, 0xC4, 0x23, 0x72, 0x4E, 0x08, 0x10, 0xE4, 0x27, 0x10, 0x0C, 0x90, 0x09, 0x40, 0x02, 0x60, 0x06, 0x40, 0x02, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00}; const uint8_t logo16_supla_bmp[] PROGMEM = // logo supla 16 { 0x30, 0x00, 0x7C, 0x00, 0xC4, 0x00, 0x86, 0x00, 0x84, 0x00, 0xDC, 0x03, 0x78, 0x36, 0x60, 0x78, 0x40, 0x48, 0x40, 0x38, 0x40, 0x04, 0x80, 0x06, 0x80, 0x03, 0x40, 0x02, 0xC0, 0x03, 0x00, 0x01}; const uint8_t logo_Power_off[] PROGMEM = // Power off { 0xe0, 0xff, 0xff, 0xff, 0x03, 0x38, 0xfc, 0xff, 0xff, 0x0f, 0x0c, 0xf0, 0xff, 0xff, 0x3f, 0x06, 0xe0, 0xff, 0xff, 0x3f, 0x02, 0xc0, 0xcf, 0x43, 0x78, 0x03, 0xc0, 0x33, 0x43, 0x78, 0x01, 0xc0, 0x7b, 0x7b, 0xff, 0x01, 0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0x7b, 0x7b, 0xff, 0x03, 0xc0, 0x33, 0x7b, 0xff, 0x02, 0xc0, 0xcf, 0x7b, 0x7f, 0x06, 0xe0, 0xff, 0xff, 0x7f, 0x0c, 0xf0, 0xff, 0xff, 0x3f, 0x18, 0xfc, 0xff, 0xff, 0x1f, 0xf0, 0xff, 0xff, 0xff, 0x07, }; const uint8_t logo_Power_on[] PROGMEM = // Power on { 0xe0, 0xff, 0xff, 0xff, 0x07, 0x38, 0x00, 0x00, 0x30, 0x0c, 0x0c, 0x00, 0x00, 0x18, 0x18, 0x06, 0x00, 0x00, 0x0c, 0x30, 0x02, 0x0e, 0x00, 0x06, 0x60, 0x03, 0x9f, 0x19, 0x02, 0x40, 0x81, 0xb1, 0x1b, 0x03, 0xc0, 0x81, 0xa0, 0x1a, 0x01, 0x80, 0x81, 0xa0, 0x1e, 0x01, 0x80, 0x81, 0xb1, 0x1c, 0x01, 0xc0, 0x03, 0x9b, 0x18, 0x03, 0x40, 0x02, 0x8e, 0x18, 0x02, 0x60, 0x06, 0x00, 0x00, 0x06, 0x20, 0x0c, 0x00, 0x00, 0x0c, 0x38, 0x38, 0x00, 0x00, 0x18, 0x0c, 0xe0, 0xff, 0xff, 0xff, 0x07, }; const uint8_t hand16_bmp[] PROGMEM = // logo hand 16 { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x03, 0x30, 0x02, 0x08, 0x3F, 0x04, 0x40, 0x04, 0x7C, 0x02, 0x40, 0x02, 0x7C, 0x02, 0x60, 0x04, 0x3C, 0x18, 0x10, 0xE0, 0x0F, 0x00, 0x00, 0x00, 0x00}; class ManualRelay : public Supla::Control::Relay { public: ManualRelay() : Relay(-1, true, 32) {} void onInit() { digitalWrite(relay_pin, !relayOnLevel); pinMode(relay_pin, OUTPUT); } void turnOn(_supla_int_t duration) { if (!relay_0->isOn() && Protected) { digitalWrite(relay_pin, !relayOnLevel); channel.setNewValue(false); Serial.println("*** Protected!! relay will not be activated in manual mode ***"); } else { digitalWrite(relay_pin, relayOnLevel); channel.setNewValue(true); Serial.println("*** relay On ***"); } } void turnOff(_supla_int_t duration) { digitalWrite(relay_pin, !relayOnLevel); channel.setNewValue(false); Serial.println("*** relay Off ***"); } bool isOn() { if (relayOnLevel) { return digitalRead(relay_pin); } else { return !digitalRead(relay_pin); } } }; ManualRelay *relay_1 = nullptr; class TermostatSet : public Supla::Control::Relay { public: TermostatSet() : Relay(-1, true, 32) {} void onInit() { // do nothing here } void turnOn(_supla_int_t duration) { ThermostatTemperature += 0.1; if (ThermostatTemperature > 100.0) ThermostatTemperature = 100.0; channel.setNewValue(false); doSaveTermSetTemp = true; } void turnOff(_supla_int_t duration) { ThermostatTemperature -= 0.1; if (ThermostatTemperature < 0.0) ThermostatTemperature = 0.0; channel.setNewValue(false); doSaveTermSetTemp = true; } bool isOn() { return false; } }; TermostatSet *TerSet = nullptr; class TermostatTemp : public Supla::Sensor::Thermometer { public: TermostatTemp() {} void onInit() { channel.setNewValue(getValue()); } double getValue() { return ThermostatTemperature; } void iterateAlways() { channel.setNewValue(getValue()); if (millis() - lastReadTime > 2500) { lastReadTime = millis(); actualTemp = DsTemp->getValue(); if (relay_0->isOn()) { if (((relay_1->isOn()) && (actualTemp >= ThermostatTemperature)) || (actualTemp < -100.0)) { relay_1->turnOff(0); } else if ((!relay_1->isOn()) && (actualTemp <= (ThermostatTemperature - Term_Hist))) { relay_1->turnOn(0); } } } } }; TermostatTemp *TerTemp = nullptr; class TermostatSet_hist : public Supla::Control::Relay { public: TermostatSet_hist() : Relay(-1, true, 32) {} void onInit() { // do nothing here } void turnOn(_supla_int_t duration) { Term_Hist += 0.1; if (Term_Hist > 10.0) Term_Hist = 10.0; channel.setNewValue(false); miDimmToTemp_hist->setRGBW(-1, -1, -1, -1, (Term_Hist * 10)); } void turnOff(_supla_int_t duration) { Term_Hist -= 0.1; if (Term_Hist <= 0.0) Term_Hist = 0.0; channel.setNewValue(false); miDimmToTemp_hist->setRGBW(-1, -1, -1, -1, (Term_Hist * 10)); } bool isOn() { return false; } }; TermostatSet_hist *TerSet_hist = nullptr; class TermostatTemp_hist : public Supla::Sensor::Thermometer { public: TermostatTemp_hist() {} void onInit() { channel.setNewValue(getValue()); } double getValue() { return Term_Hist; Term_Hist = Term_Hist; } void iterateAlways() { channel.setNewValue(getValue()); } }; TermostatTemp_hist *TerTemp_hist = nullptr; enum addedActions { unDimm }; class addedActionsClass : public Supla::ActionHandler { public: addedActionsClass(){}; void handleAction(int event, int action) { if (action == unDimm) { if (dimm) { dimm = false; dimm_lasttime = millis(); display.setContrast(200, 241, 64); } else { dimm_lasttime = millis(); } } } }; addedActionsClass *custAct = new addedActionsClass; class DimmToTemp_hist : public Supla::Control::DimmerBase { public: DimmToTemp_hist() {} void setRGBWValueOnDevice(uint32_t red, uint32_t green, uint32_t blue, uint32_t colorBrightness, uint32_t brightness) { float dimmTemp_hist = map(brightness, 0, 1023, 0, 100); Term_Hist = dimmTemp_hist * 0.1; } }; void saveConfigCallback() { Serial.println("Should save config"); shouldSaveConfig = true; } void ondemandwifiCallback() { display.clear(); display.setContrast(200, 241, 64); display.setTextAlignment(TEXT_ALIGN_CENTER); display.setFont(ArialMT_Plain_10); display.drawString(64, 16, "wifi config connect"); display.drawString(64, 28, "to wifi hotspot"); display.setFont(ArialMT_Plain_16); display.drawString(64, 44, "Thermostat"); display.display(); wifi.setSsid(""); wifi.setPassword(""); wifiManager.setConfigPortalBlocking(true); wifiManager.setCleanConnect(true); wifiManager.setBreakAfterConfig(true); wifiManager.setSaveConfigCallback(saveConfigCallback); wifiManager.setCustomHeadElement(logo); wifiManager.setMinimumSignalQuality(8); wifiManager.setConfigPortalTimeout(300); std::vector<const char *> menu = {"wifi", "wifinoscan", "sep", "update", "sep", "info", "restart"}; wifiManager.setMenu(menu); wifiManager.setTitle("By..ElMaya"); WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81, "required"); WiFiManagerParameter custom_Email("email", "Email", Email, 81, "required"); WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51, "required"); WiFiManagerParameter custom_term_hist("histerisis", "Histerisis", term_hist, 5, "required"); WiFiManagerParameter custom_html_id21("<div><h4> - Supla State - "); WiFiManagerParameter custom_html_id22(Supla_status); WiFiManagerParameter custom_html_id23("</h4></div>"); wifiManager.addParameter(&custom_Supla_server); wifiManager.addParameter(&custom_Email); wifiManager.addParameter(&custom_Supla_name); wifiManager.addParameter(&custom_term_hist); wifiManager.addParameter(&custom_html_id21); wifiManager.addParameter(&custom_html_id22); wifiManager.addParameter(&custom_html_id23); if (!wifiManager.startConfigPortal("Thermostat")) { Serial.println("Not connected to WiFi but continuing anyway."); } else { Serial.println("connected...yeey :)"); } strcpy(Supla_server, custom_Supla_server.getValue()); strcpy(Email, custom_Email.getValue()); strcpy(Supla_name, custom_Supla_name.getValue()); strcpy(term_hist, custom_term_hist.getValue()); wifiManager.getWiFiSSID().toCharArray(Router_SSID, 33); wifiManager.getWiFiPass().toCharArray(Router_Pass, 65); if (strcmp(Supla_server, "get_new_guid_and_authkey") == 0) { Serial.println("new guid & authkey."); EEPROM.write(300, 0); EEPROM.commit(); delay(100); ESP.reset(); } if (shouldSaveConfig) { DynamicJsonDocument json(1024); json["Supla_server"] = Supla_server; json["Email"] = Email; json["Supla_name"] = Supla_name; json["term_hist"] = term_hist; json["Router_SSID"] = Router_SSID; json["Router_Pass"] = Router_Pass; File configFile = LittleFS.open("/config.json", "w"); if (!configFile) { Serial.println("failed to open config file for writing"); } serializeJsonPretty(json, Serial); serializeJson(json, configFile); configFile.close(); shouldSaveConfig = false; initialConfig = false; WiFi.mode(WIFI_STA); delay(5000); ESP.restart(); } WiFi.softAPdisconnect(true); // close AP if (initialConfig == true) { shouldSaveConfig = false; initialConfig = false; WiFi.mode(WIFI_STA); delay(5000); ESP.restart(); } } void status_func(int status, const char *msg) { // ------------------------ Status -------------------------- if (s != status) { s = status; if (s != 10) { strcpy(Supla_status, msg); } } } void TH_Overlay() { display.clear(); if (actualTemp > -100) { // display.setFont(Arimo_Bold_32); display.setFont(ArialMT_Plain_24); display.setTextAlignment(TEXT_ALIGN_CENTER); display.drawString(64, 19, String(actualTemp, 1) + "ºC"); } else { // display.setFont(Arimo_Bold_32); display.setFont(ArialMT_Plain_24); display.setTextAlignment(TEXT_ALIGN_CENTER); display.drawString(64, 19, "-----"); } if (relay_0->isOn()) { display.setFont(ArialMT_Plain_16); display.setTextAlignment(TEXT_ALIGN_CENTER); display.drawString(38, 48, "T " + String(ThermostatTemperature, 1) + "ºC"); display.drawString(61, 0, "Auto"); } else { display.setFont(ArialMT_Plain_16); display.setTextAlignment(TEXT_ALIGN_CENTER); display.drawString(38, 48, "T " + String(ThermostatTemperature, 1) + "ºC"); display.drawXbm(52, 0, 16, 16, hand16_bmp); } if (TerSet_hist->isOn()) { display.setFont(ArialMT_Plain_16); display.setTextAlignment(TEXT_ALIGN_CENTER); display.drawString(105, 48, "H " + String(Term_Hist, 1) + "ºC"); // display.drawString(61, 0, "Auto"); } else { display.setFont(ArialMT_Plain_10); display.setTextAlignment(TEXT_ALIGN_CENTER); display.drawString(105, 48, "H " + String(Term_Hist, 1) + "ºC"); // display.drawXbm(52, 0, 16, 16, hand16_bmp); } if (WiFiConected) { display.drawXbm(1, 0, 16, 16, logo16_wifi_bmp); // -------------------------------------------------- oled wifi ok -------- if (s == STATUS_REGISTERED_AND_READY) { display.drawXbm(22, 0, 16, 16, logo16_supla_bmp); // ------------------------------------------------ oled supla ok -------- } else if (s != 10) { display.setFont(ArialMT_Plain_16); display.drawString(30, 0, String(s)); } } if (relay_1->isOn()) { display.drawXbm(86, 0, 40, 16, logo_Power_on); // -------------------------------------------------- Relay on --------- } else { display.drawXbm(86, 0, 40, 16, logo_Power_off); // ------------------------------------------------- Relay off -------- } display.display(); TempDisp_lasttime = millis(); } void guid_authkey(void) { if (EEPROM.read(300) != 60) { int eep_gui = 301; ESP8266TrueRandom.uuid(uuidNumber); String uuidString = ""; for (int i = 0; i < 16; i++) { int topDigit = uuidNumber[i] >> 4; int bottomDigit = uuidNumber[i] & 0x0f; uuidString += "0123456789abcdef"[topDigit]; uuidString += "0123456789abcdef"[bottomDigit]; } int length_uuid = uuidString.length(); for (int i = 0; i < length_uuid; ++i) { EEPROM.put(eep_gui + i, uuidString[i]); } int eep_aut = 341; ESP8266TrueRandom.uuid(uuidNumber); String uuidString2 = ""; for (int i = 0; i < 16; i++) { int topDigit = uuidNumber[i] >> 4; int bottomDigit = uuidNumber[i] & 0x0f; uuidString2 += "0123456789abcdef"[topDigit]; uuidString2 += "0123456789abcdef"[bottomDigit]; } int length_uuid2 = uuidString2.length(); for (int i = 0; i < length_uuid2; ++i) { EEPROM.put(eep_aut + i, uuidString2[i]); } EEPROM.write(300, 60); EEPROM.commit(); delay(0); } read_guid(); read_authkey(); } String read_guid(void) { String read_eeprom = ""; int i, ii = 0; int eep_star = 301; int end_guid = eep_star + SUPLA_GUID_SIZE; String temp_read = "0x"; for (i = eep_star; i < end_guid + 16; i = i + 1) { temp_read += char(EEPROM.read(i)); read_eeprom += char(EEPROM.read(i)); if ((i % 2) == 0) { char *_guid = strcpy((char *)malloc(temp_read.length() + 1), temp_read.c_str()); GUID[ii] = strtoul(_guid, NULL, 16); temp_read = "0x"; ii++; } } return read_eeprom; } String read_authkey(void) { String read_eeprom = ""; int i, ii = 0; int eep_star = 341; int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE; String temp_read = "0x"; for (i = eep_star; i < end_authkey + 16; i = i + 1) { temp_read += char(EEPROM.read(i)); read_eeprom += char(EEPROM.read(i)); if ((i % 2) == 0) { char *_authkey = strcpy((char *)malloc(temp_read.length() + 1), temp_read.c_str()); AUTHKEY[ii] = strtoul(_authkey, NULL, 16); temp_read = "0x"; ii++; } } return read_eeprom; } void setup() { wifi_set_sleep_type(NONE_SLEEP_T); pinMode(button_pin, INPUT_PULLUP); Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY, 1); display.init(); display.flipScreenVertically(); display.clear(); display.setFont(ArialMT_Plain_24); display.drawString(42, 6, "Supla"); display.setFont(ArialMT_Plain_16); display.drawString(33, 40, "Thermostat"); display.drawXbm(0, 16, 32, 32, logo32_glcd_bmp); display.display(); delay(10); EEPROM.begin(1024); if (EEPROM.read(300) != 60) { initialConfig = true; } guid_authkey(); if (LittleFS.begin()) { // ------------------------- wificonfig read ----------------- if (LittleFS.exists("/config.json")) { File configFile = LittleFS.open("/config.json", "r"); if (configFile) { DynamicJsonDocument json(1024); DeserializationError deserializeError = deserializeJson(json, configFile); serializeJsonPretty(json, Serial); if (!deserializeError) { Serial.println("\nparsed json"); if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]); if (json.containsKey("Email")) strcpy(Email, json["Email"]); if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]); if (json.containsKey("term_hist")) { strcpy(term_hist, json["term_hist"]); Term_Hist = (String(term_hist).toFloat()); if (Term_Hist < 0.1) { Term_Hist = 0.1; } else if (Term_Hist > 10.0) { Term_Hist = 10.0; } } if (json.containsKey("Router_SSID")) strcpy(Router_SSID, json["Router_SSID"]); if (json.containsKey("Router_Pass")) strcpy(Router_Pass, json["Router_Pass"]); } else { initialConfig = true; } configFile.close(); } } } else { Serial.println("failed to mount FS"); } Serial.print("Term_Hist: "); Serial.println(Term_Hist); wifi_station_set_hostname(Supla_name); WiFi.mode(WIFI_STA); if (initialConfig == true) { ondemandwifiCallback(); } TerSet_hist = new TermostatSet_hist(); TerSet_hist->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH); TerSet_hist->disableChannelState(); TerTemp_hist = new TermostatTemp_hist(); TerTemp_hist->disableChannelState(); EEPROM.get(381, ThermostatTemperature); if ((ThermostatTemperature > 125.0) || isnan(ThermostatTemperature)) { ThermostatTemperature = 20.0; EEPROM.put(381, ThermostatTemperature); EEPROM.commit(); } relay_0 = new Supla::Control::VirtualRelay(32); relay_0->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH); relay_0->setDefaultStateRestore(); relay_0->disableChannelState(); relay_1 = new ManualRelay(); relay_1->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH); relay_1->setDefaultStateOff(); relay_1->disableChannelState(); DsTemp = new Supla::Sensor::DS18B20(ds_pin); TerTemp = new TermostatTemp(); TerTemp->disableChannelState(); TerSet = new TermostatSet(); TerSet->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH); TerSet->disableChannelState(); auto button_1 = new Supla::Control::Button(button_pin, true, true); button_1->setMulticlickTime(800, false); button_1->addAction(Supla::TOGGLE, relay_0, Supla::ON_CLICK_1); if (!Protected) button_1->addAction(Supla::TOGGLE, relay_1, Supla::ON_CLICK_2); button_1->addAction(unDimm, custAct, Supla::ON_PRESS); relay_0->addAction(Supla::TURN_OFF, relay_1, Supla::ON_TURN_OFF); miDimmToTemp_hist = new DimmToTemp_hist(); miDimmToTemp_hist->disableChannelState(); auto button_2 = new Supla::Control::Button(button2_pin, true, true); auto button_3 = new Supla::Control::Button(button3_pin, true, true); button_2->setHoldTime(500); button_3->setHoldTime(500); button_2->repeatOnHoldEvery(30); button_3->repeatOnHoldEvery(30); button_2->addAction(unDimm, custAct, Supla::ON_PRESS); button_3->addAction(unDimm, custAct, Supla::ON_PRESS); button_2->addAction(Supla::TURN_ON, TerSet, Supla::ON_PRESS); button_3->addAction(Supla::TURN_OFF, TerSet, Supla::ON_PRESS); button_2->addAction(Supla::TURN_ON, TerSet, Supla::ON_HOLD); button_3->addAction(Supla::TURN_OFF, TerSet, Supla::ON_HOLD); SuplaDevice.setName(Supla_name); wifi.setSsid(Router_SSID); wifi.setPassword(Router_Pass); SuplaDevice.setStatusFuncImpl(&status_func); wifi.enableSSL(false); SuplaDevice.begin(GUID, Supla_server, Email, AUTHKEY); } void loop() { int C_W_read = digitalRead(button_pin); { if (C_W_read != last_C_W_state) { time_last_C_W_change = millis(); } if ((millis() - time_last_C_W_change) > C_W_delay) { if (C_W_read != C_W_state) { C_W_state = C_W_read; if (C_W_state == LOW) { ondemandwifiCallback(); } } } last_C_W_state = C_W_read; } SuplaDevice.iterate(); delay(5); if (doSaveTermSetTemp) { EEPROM.put(381, ThermostatTemperature); EEPROM.commit(); doSaveTermSetTemp = false; } if ((millis() - TempDisp_lasttime) > TempDisp_mtbs) { WiFiConected = (WiFi.status() == WL_CONNECTED); TempDisp_mtbs = 500; TH_Overlay(); } if ((millis() - dimm_lasttime) > dimm_mtbs) { if (dimm == false) { display.setContrast(50, 50, 30); display.display(); dimm = true; } dimm_lasttime = millis(); } }
I also had a problem with libraries. For me, the LittleFS library works as in the attachment.
/Documents/Arduino/libraries/LittleFS/src/LittleFS.h:34:25: fatal error: flash_utils.h: No such file or directoryzzrr wrote: Sat Nov 26, 2022 1:47 pm I also had a problem with libraries. For me, the LittleFS library works as in the attachment.
compilation terminated.
