there is something.eradek wrote: Sun Apr 03, 2022 12:13 pm Hi Elmaya,
I am using your thermostat in couple of devices. Is there a chance for upgraded code for the old version without rotary encoder?
temperature from 0º to 100º in steps of 1ºC.
additional relay (Gpio 4 "D2").
3 buttons for local control.
The additional relay allows configuration as a power switch, light switch or stairs timer.
The buttons have the following functions.
Gpio 12 "D6":
ON_CLICK_1 = toggle Auto/Manual mode,
ON_CLICK_2 = toggle manual On/Off,
ON_HOLD 1 second = toggle relay 2,
ON_HOLD 10 seconds = WiFiConfig.
Gpio 14 "D5":
ON_CLICK_1 = increases the desired temperature "preset" by 1ºC,
ON_HOLD = increases successively in steps of 1ºC.
Gpio 13 "D7":
ON_CLICK_1 = decreases the desired temperature "preset" by 1ºC,
ON_HOLD = decreases successively in steps of 1ºC.
Gpio 3 "RX" = DS18B20.
Gpio 5 "D1" = thermostat relay.
Gpio 4 "D2" = additional relay.
Gpio 0 "D3" = SDA "oled".
Gpio 2 "D4" = SCL "oled".
Gpio 14 "D5" = pushbutton temp +.
Gpio 12 "D6" = mode button.
Gpio 13 "D7" = pushbutton temp -.
Gpio 15 "D8" = Led auto/man mode, connected to GND through resistor "optional".
Gpio 16 "D0" = stateLed, connected to +3.3v through resistor "optional".
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
#define supla_lib_config_h_ // silences debug messages
#include "LittleFS.h"
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <EEPROM.h>
#include <ESP8266TrueRandom.h>
#include <SuplaDevice.h> // Supla device 2.4.1
#include <supla/control/dimmer_base.h>
#define STORAGE_OFFSET 512
Supla::Eeprom eeprom(STORAGE_OFFSET);
Supla::ESPWifi wifi("SSID", "PASS"); //------ Do not change----wifimanager takes care------
#include "SSD1306Wire.h" //----- 0.96 Oled --- https://github.com/ThingPulse/esp8266-oled-ssd1306
SSD1306Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 0.96 Oled ---
//#include "SH1106Wire.h" //----- 1.3 Oled ---
//SH1106Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 1.3 Oled ---
extern "C"
#include "user_interface.h"
//#define D0 16 //no internal pullup resistor
//#define D1 5
//#define D2 4
//#define D3 0 //must not be pulled low during power on/reset, toggles value during boot
//#define D4 2 //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15 //must not be pulled high during power on/reset
//#define RX 3 //High at boot
//#define TX 1 //must not be pulled low during power on/reset
int ds_pin = 3; //RX -- 3
int relay_pin = 5; //D1 -- 5
int relay2_pin = 4; //D2 -- 4
int button_pin = 12; //D6 -- 12
#define button2_pin 14 //D5 -- 14
#define button3_pin 13 //D7 -- 13
#define autoManLed 15 //D8 -- 15
#define stateLed 16 //D0 -- 16
bool relayOnLevel = HIGH; // "HIGH" for active high relay, "LOW" for active low relay.
bool Protected = false; // if "true" disables the possibility of activating the relay in manual mode.
long C_W_delay = 10000; // ---------------------- config delay 10 seconds ---------------------------
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
char Supla_server[81] = ("svr?.supla.org");
char Email[81] = ("your@email");
char Supla_name[51] = ("Thermostat");
char term_hist[5] = ("1.0");
char Supla_status[51] = ("No server address");
char Router_SSID[32];
char Router_Pass[64];
bool shouldSaveConfig = false;
bool initialConfig = false;
bool starting = true;
int s;
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16];
const char logo[] PROGMEM = "<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>";
double ThermostatTemperature = 20.0;
double actualTemp = -127.0;
float Term_Hist = 1.0;
int TempDisp_mtbs = 5000;
unsigned long TempDisp_lasttime;
int dimm_mtbs = 15000;
unsigned long dimm_lasttime;
bool WiFiConected = false;
bool dimm = false;
bool updateOled = false;
WiFiManager wifiManager;
Supla::Control::Relay *relay_0 = nullptr;
Supla::Control::Relay *relay_2 = nullptr;
Supla::Sensor::DS18B20 *DsTemp = nullptr;
Supla::Control::RGBWBase *miDimmToTemp = nullptr;
Supla::Device::StatusLed *LedS = nullptr;
const uint8_t logo32_glcd_bmp[] PROGMEM = //logo supla 32
0x00, 0x00, 0x00, 0x00, 0xC0, 0x1F, 0x00, 0x00, 0xE0, 0x7F, 0x00, 0x00,
0xF0, 0x70, 0x00, 0x00, 0x30, 0xE0, 0x00, 0x00, 0x38, 0xC0, 0x00, 0x00,
0x18, 0xC0, 0x01, 0x00, 0x18, 0xC0, 0x01, 0x00, 0x38, 0xC0, 0x00, 0x00,
0x38, 0xE0, 0x01, 0x00, 0x70, 0xF0, 0x07, 0x00, 0xE0, 0x7F, 0x0E, 0x00,
0xC0, 0x3F, 0x38, 0x00, 0x00, 0x1F, 0xE0, 0x0F, 0x00, 0x18, 0xC0, 0x1F,
0x00, 0x18, 0xC0, 0x30, 0x00, 0x18, 0xC0, 0x30, 0x00, 0x30, 0xC0, 0x30,
0x00, 0x30, 0x80, 0x1F, 0x00, 0x30, 0xC0, 0x0F, 0x00, 0x20, 0x60, 0x00,
0x00, 0x60, 0x20, 0x00, 0x00, 0x60, 0x30, 0x00, 0x00, 0x40, 0x18, 0x00,
0x00, 0xC0, 0x0D, 0x00, 0x00, 0xC0, 0x07, 0x00, 0x00, 0x60, 0x04, 0x00,
0x00, 0x20, 0x0C, 0x00, 0x00, 0x20, 0x0C, 0x00, 0x00, 0x60, 0x06, 0x00,
0x00, 0xC0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00
const uint8_t logo16_wifi_bmp[] PROGMEM = //logo wifi 16
0x00, 0x00, 0x00, 0x00, 0xE0, 0x07, 0x38, 0x1C, 0xC4, 0x23, 0x72, 0x4E,
0x08, 0x10, 0xE4, 0x27, 0x10, 0x0C, 0x90, 0x09, 0x40, 0x02, 0x60, 0x06,
0x40, 0x02, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00
const uint8_t logo16_wifi_off_bmp[] PROGMEM = //logo wifi off 16
0x01, 0x80, 0x02, 0x40, 0xE4, 0x27, 0x38, 0x1C, 0xD4, 0x6B, 0x73, 0xCE,
0xD9, 0x93, 0xE4, 0x27, 0xB0, 0x0D, 0xD8, 0x1B, 0x60, 0x06, 0x70, 0x0E,
0x48, 0x12, 0x84, 0x21, 0x02, 0x40, 0x01, 0x80
const uint8_t logo16_supla_bmp[] PROGMEM = //logo supla 16
0x30, 0x00, 0x7C, 0x00, 0xC4, 0x00, 0x86, 0x00, 0x84, 0x00, 0xDC, 0x03,
0x78, 0x36, 0x60, 0x78, 0x40, 0x48, 0x40, 0x38, 0x40, 0x04, 0x80, 0x06,
0x80, 0x03, 0x40, 0x02, 0xC0, 0x03, 0x00, 0x01
const uint8_t logo_Power_off[] PROGMEM = //Power off
0xe0, 0xff, 0xff, 0xff, 0x03, 0x38, 0xfc, 0xff, 0xff, 0x0f, 0x0c, 0xf0,
0xff, 0xff, 0x3f, 0x06, 0xe0, 0xff, 0xff, 0x3f, 0x02, 0xc0, 0xcf, 0x43,
0x78, 0x03, 0xc0, 0x33, 0x43, 0x78, 0x01, 0xc0, 0x7b, 0x7b, 0xff, 0x01,
0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0x7b,
0x7b, 0xff, 0x03, 0xc0, 0x33, 0x7b, 0xff, 0x02, 0xc0, 0xcf, 0x7b, 0x7f,
0x06, 0xe0, 0xff, 0xff, 0x7f, 0x0c, 0xf0, 0xff, 0xff, 0x3f, 0x18, 0xfc,
0xff, 0xff, 0x1f, 0xf0, 0xff, 0xff, 0xff, 0x07,
const uint8_t logo_Power_on[] PROGMEM = //Power on
0xe0, 0xff, 0xff, 0xff, 0x07, 0x38, 0x00, 0x00, 0x30, 0x0c, 0x0c, 0x00,
0x00, 0x18, 0x18, 0x06, 0x00, 0x00, 0x0c, 0x30, 0x02, 0x0e, 0x00, 0x06,
0x60, 0x03, 0x9f, 0x19, 0x02, 0x40, 0x81, 0xb1, 0x1b, 0x03, 0xc0, 0x81,
0xa0, 0x1a, 0x01, 0x80, 0x81, 0xa0, 0x1e, 0x01, 0x80, 0x81, 0xb1, 0x1c,
0x01, 0xc0, 0x03, 0x9b, 0x18, 0x03, 0x40, 0x02, 0x8e, 0x18, 0x02, 0x60,
0x06, 0x00, 0x00, 0x06, 0x20, 0x0c, 0x00, 0x00, 0x0c, 0x38, 0x38, 0x00,
0x00, 0x18, 0x0c, 0xe0, 0xff, 0xff, 0xff, 0x07,
const uint8_t hand16_bmp[] PROGMEM = //logo hand 16
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x03, 0x30, 0x02, 0x08, 0x3F,
0x04, 0x40, 0x04, 0x7C, 0x02, 0x40, 0x02, 0x7C, 0x02, 0x60, 0x04, 0x3C,
0x18, 0x10, 0xE0, 0x0F, 0x00, 0x00, 0x00, 0x00
const uint8_t logo16_2_on[] PROGMEM = //logo 2 on 16
0x00, 0x00, 0xE0, 0x07, 0xE0, 0x07, 0x18, 0x18, 0x00, 0x18, 0x00, 0x18,
0x00, 0x18, 0x00, 0x06, 0x00, 0x06, 0x80, 0x01, 0x60, 0x00, 0x60, 0x00,
0x18, 0x00, 0xF8, 0x1F, 0xF8, 0x1F, 0x00, 0x00
const uint8_t logo16_2_off[] PROGMEM = //logo 2 off 16
0x01, 0x80, 0xE2, 0x47, 0xE4, 0x27, 0x18, 0x18, 0x10, 0x18, 0x20, 0x1C,
0x40, 0x1A, 0x80, 0x07, 0x80, 0x07, 0xC0, 0x03, 0x60, 0x04, 0x70, 0x08,
0x18, 0x10, 0xFC, 0x3F, 0xFA, 0x5F, 0x01, 0x80
class ManualRelay : public Supla::Control::Relay {
public:
ManualRelay() : Relay(-1, true, 32) {}
void onInit() {
digitalWrite(relay_pin, !relayOnLevel);
pinMode(relay_pin, OUTPUT);
void turnOn(_supla_int_t duration) {
if (!relay_0->isOn() && Protected) {
channel.setNewValue(false);
Serial.println("*** Protected!! relay will not be activated in manual mode ***");
} else {
digitalWrite(relay_pin, relayOnLevel);
channel.setNewValue(true);
Serial.println("*** relay On ***");
void turnOff(_supla_int_t duration) {
Serial.println("*** relay Off ***");
bool isOn() {
if (relayOnLevel) {
return digitalRead(relay_pin);
} else {
return !digitalRead(relay_pin);
}; ManualRelay *relay_1 = nullptr;
class TermostatTemp : public Supla::Sensor::Thermometer {
public:
TermostatTemp() {}
void onInit() {
channel.setNewValue(getValue() );
double getValue() {
return ThermostatTemperature;
void iterateAlways() {
if ( millis() - lastReadTime > 2500) {
lastReadTime = millis();
actualTemp = DsTemp->getValue();
if (relay_0->isOn()) {
if (((relay_1->isOn()) && ( actualTemp >= ThermostatTemperature)) || ( actualTemp < -100.0)) {
relay_1->turnOff(0);
} else if ((!relay_1->isOn()) && ( actualTemp <= (ThermostatTemperature - Term_Hist))) {
relay_1->turnOn(0);
}; TermostatTemp *TerTemp = nullptr;
class TermostatSet : public Supla::Control::Relay {
public:
TermostatSet() : Relay(-1, true, 32) {}
void onInit() {
// do nothing here
ThermostatTemperature += 1.0;
if (ThermostatTemperature > 100.0) ThermostatTemperature = 100.0;
miDimmToTemp->setRGBW(-1, -1, -1, -1, (ThermostatTemperature));
updateOled = true;
ThermostatTemperature -= 1.0;
if (ThermostatTemperature < 0.0) ThermostatTemperature = 0.0;
updateOled = true;
bool isOn() {
return false;
}; TermostatSet *TerSet = nullptr;
enum addedActions {unDimm};
class addedActionsClass : public Supla::ActionHandler {
public: addedActionsClass() {};
void handleAction(int event, int action) {
if (action == unDimm) {
if (dimm) {
dimm = false ;
dimm_lasttime = millis();
display.setContrast(200, 241, 64);
} else {
addedActionsClass *custAct = new addedActionsClass;
class DimmToTemp : public Supla::Control::DimmerBase {
public:
DimmToTemp() { }
void setRGBWValueOnDevice(uint32_t red,
uint32_t green,
uint32_t blue,
uint32_t colorBrightness,
uint32_t brightness) {
float dimmTemp = map(brightness, 0, 1023, 0, 100);
ThermostatTemperature = dimmTemp;
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
void ondemandwifiCallback () {
// Enables custom LED sequence based on given durations.
// Automatic sequence change will be disabled.
// (1000, 0) = LED ON.
LedS->setCustomSequence(1000, 0); // void setCustomSequence(int onDurationMs, int offDurationMs);
display.clear();
display.setTextAlignment(TEXT_ALIGN_CENTER);
display.setFont(ArialMT_Plain_10);
display.drawString(64, 16, "wifi config connect");
display.drawString(64, 28, "to wifi hotspot");
display.setFont(ArialMT_Plain_16);
display.drawString(64, 44, "Thermostat");
display.display();
wifi.setSsid("");
wifi.setPassword("");
wifiManager.setConfigPortalBlocking(true);
wifiManager.setCleanConnect(true);
wifiManager.setBreakAfterConfig(true);
wifiManager.setSaveConfigCallback(saveConfigCallback);
wifiManager.setCustomHeadElement(logo);
wifiManager.setMinimumSignalQuality(8);
wifiManager.setConfigPortalTimeout(300);
std::vector<const char *> menu = {"wifi", "wifinoscan", "sep", "update", "sep", "info", "restart"};
wifiManager.setMenu(menu);
wifiManager.setTitle("By..ElMaya");
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81, "required");
WiFiManagerParameter custom_Email("email", "Email", Email, 81, "required");
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51, "required");
WiFiManagerParameter custom_term_hist("histerisis", "Histerisis", term_hist, 5, "required");
WiFiManagerParameter custom_html_id21("<div><h4> - Supla State - ");
WiFiManagerParameter custom_html_id22(Supla_status);
WiFiManagerParameter custom_html_id23("</h4></div>");
wifiManager.addParameter(&custom_Supla_server);
wifiManager.addParameter(&custom_Email);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.addParameter(&custom_term_hist);
wifiManager.addParameter(&custom_html_id21);
wifiManager.addParameter(&custom_html_id22);
wifiManager.addParameter(&custom_html_id23);
if (!wifiManager.startConfigPortal("Thermostat")) {
Serial.println("Not connected to WiFi but continuing anyway.");
} else {
Serial.println("connected...yeey :)");
strcpy(Supla_server, custom_Supla_server.getValue());
strcpy(Email, custom_Email.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
strcpy(term_hist, custom_term_hist.getValue());
wifiManager.getWiFiSSID().toCharArray(Router_SSID, 33);
wifiManager.getWiFiPass().toCharArray(Router_Pass, 65);
if (strcmp(Supla_server, "get_new_guid_and_authkey") == 0) {
Serial.println("new guid & authkey.");
EEPROM.write(300, 0);
EEPROM.commit();
delay(100);
ESP.reset();
if (shouldSaveConfig) {
DynamicJsonDocument json(1024);
json["Supla_server"] = Supla_server;
json["Email"] = Email;
json["Supla_name"] = Supla_name;
json["term_hist"] = term_hist;
json["Router_SSID"] = Router_SSID;
json["Router_Pass"] = Router_Pass;
File configFile = LittleFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
serializeJsonPretty(json, Serial);
serializeJson(json, configFile);
configFile.close();
WiFi.mode(WIFI_STA);
delay(5000);
ESP.restart();
WiFi.softAPdisconnect(true);
if (initialConfig == true) {
delay(5000);
ESP.restart();
LedS->setAutoSequence(); // Restores automatic LED sequence change based on device state.
void status_func(int status, const char *msg) { // ------------------------ Status --------------------------
if (s != status) {
s = status;
if (s != 10) {
strcpy(Supla_status, msg);
void TH_Overlay() {
display.clear();
if (actualTemp > -100) {
display.setFont(Arimo_Bold_32);
//display.setFont(ArialMT_Plain_24);
display.drawString(64, 14, String(actualTemp, 1) + "ºC");
} else {
display.drawString(64, 14, "-----");
display.drawString(64, 48, "Preset " + String(ThermostatTemperature, 1) + "ºC");
display.drawString(61, 0, "Auto");
} else {
display.drawXbm(52, 0, 16, 16, hand16_bmp);
if (!WiFiConected) {
display.drawXbm(22, 0, 16, 16, logo16_wifi_off_bmp);// -------------------------------------------------- oled no wifi --------
} else {
if (s == STATUS_REGISTERED_AND_READY) {
display.drawXbm(22, 0, 16, 16, logo16_supla_bmp);// ------------------------------------------------ oled supla ok --------
} else if (s != 10) {
display.drawString(30, 0, String(s));
if (relay_1->isOn()) {
display.drawXbm(86, 0, 40, 16, logo_Power_on);// -------------------------------------------------- Relay on ---------
} else {
display.drawXbm(86, 0, 40, 16, logo_Power_off);// ------------------------------------------------- Relay off --------
if (relay_2->isOn()) {
display.drawXbm(1, 0, 16, 16, logo16_2_on);// -------------------------------------------------- Relay 2 on ---------
} else {
display.drawXbm(1, 0, 16, 16, logo16_2_off);// ------------------------------------------------- Relay 2 off --------
display.display();
TempDisp_lasttime = millis();
void guid_authkey(void) {
if (EEPROM.read(300) != 60) {
int eep_gui = 301;
ESP8266TrueRandom.uuid(uuidNumber);
String uuidString = "";
for (int i = 0; i < 16; i++) {
int topDigit = uuidNumber[i] >> 4;
int bottomDigit = uuidNumber[i] & 0x0f;
uuidString += "0123456789abcdef"[topDigit];
uuidString += "0123456789abcdef"[bottomDigit];
int length_uuid = uuidString.length();
for (int i = 0; i < length_uuid; ++i) {
EEPROM.put(eep_gui + i, uuidString[i]);
int eep_aut = 341;
String uuidString2 = "";
uuidString2 += "0123456789abcdef"[topDigit];
uuidString2 += "0123456789abcdef"[bottomDigit];
int length_uuid2 = uuidString2.length();
for (int i = 0; i < length_uuid2; ++i) {
EEPROM.put(eep_aut + i, uuidString2[i]);
EEPROM.write(300, 60);
EEPROM.commit();
delay(0);
read_guid();
read_authkey();
//Serial.print("GUID : ");Serial.println(read_guid());
//Serial.print("AUTHKEY : ");Serial.println(read_authkey());
String read_guid(void) {
String read_eeprom = "";
int i, ii = 0;
int eep_star = 301;
int end_guid = eep_star + SUPLA_GUID_SIZE;
String temp_read = "0x";
for (i = eep_star; i < end_guid + 16; i = i + 1) {
temp_read += char(EEPROM.read(i));
read_eeprom += char(EEPROM.read(i));
if ( (i % 2) == 0) {
char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
GUID[ii] = strtoul( _guid, NULL, 16);
temp_read = "0x";
ii++;
return read_eeprom;
String read_authkey(void) {
int i, ii = 0;
int eep_star = 341;
int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
for (i = eep_star; i < end_authkey + 16; i = i + 1) {
char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
temp_read = "0x";
ii++;
return read_eeprom;
void setup() {
wifi_set_sleep_type(NONE_SLEEP_T);
pinMode(button_pin, INPUT_PULLUP);
Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY, 1);
display.init();
display.flipScreenVertically();
display.clear();
display.drawString(42, 6, "Supla");
display.drawString(33, 40, "Thermostat");
display.drawXbm(0, 16, 32, 32, logo32_glcd_bmp );
display.display();
delay(10);
EEPROM.begin(1024);
initialConfig = true;
guid_authkey();
if (LittleFS.begin()) { // ------------------------- wificonfig read -----------------
if (LittleFS.exists("/config.json")) {
File configFile = LittleFS.open("/config.json", "r");
if (configFile) {
DeserializationError deserializeError = deserializeJson(json, configFile);
if (!deserializeError) {
Serial.println("\nparsed json");
if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
if (json.containsKey("Email")) strcpy(Email, json["Email"]);
if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
if (json.containsKey("term_hist")) {
strcpy(term_hist, json["term_hist"]);
Term_Hist = (String(term_hist).toFloat());
if (Term_Hist < 0.1) {
Term_Hist = 0.1;
else if (Term_Hist > 10.0) {
Term_Hist = 10.0;
if (json.containsKey("Router_SSID")) strcpy(Router_SSID, json["Router_SSID"]);
if (json.containsKey("Router_Pass")) strcpy(Router_Pass, json["Router_Pass"]);
} else {
configFile.close();
} else {
Serial.println("failed to mount FS");
wifi_station_set_hostname(Supla_name);
if (initialConfig) {
ondemandwifiCallback();
relay_0 = new Supla::Control::Relay(autoManLed, true, 32);
relay_0->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
relay_0->setDefaultStateRestore();
relay_0->disableChannelState();
relay_1 = new ManualRelay();
relay_1->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
relay_1->setDefaultStateOff();
relay_1->disableChannelState();
DsTemp = new Supla::Sensor::DS18B20(ds_pin);
TerTemp = new TermostatTemp();
TerTemp->disableChannelState();
TerSet = new TermostatSet();
TerSet->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
TerSet->disableChannelState();
relay_0->addAction(Supla::TURN_OFF, relay_1, Supla::ON_TURN_OFF);
miDimmToTemp = new DimmToTemp();
miDimmToTemp->disableChannelState();
auto button_2 = new Supla::Control::Button(button2_pin, true, true);
auto button_3 = new Supla::Control::Button(button3_pin, true, true);
button_2->setHoldTime(500);
button_3->setHoldTime(500);
button_2->repeatOnHoldEvery(200);
button_3->repeatOnHoldEvery(200);
button_2->addAction(unDimm, custAct, Supla::ON_PRESS);
button_3->addAction(unDimm, custAct, Supla::ON_PRESS);
button_2->addAction(Supla::TURN_ON, TerSet, Supla::ON_PRESS);
button_3->addAction(Supla::TURN_OFF, TerSet, Supla::ON_PRESS);
button_2->addAction(Supla::TURN_ON, TerSet, Supla::ON_HOLD);
button_3->addAction(Supla::TURN_OFF, TerSet, Supla::ON_HOLD);
relay_2 = new Supla::Control::Relay(relay2_pin, true, 224);
relay_2->getChannel()->setDefault(SUPLA_CHANNELFNC_LIGHTSWITCH);
relay_2->disableChannelState();
relay_2->setDefaultStateRestore();
relay_2->keepTurnOnDuration();
auto button_1 = new Supla::Control::Button(button_pin, true, true);
button_1->setMulticlickTime(800, false);
button_1->setHoldTime(1000);
button_1->addAction(Supla::TOGGLE, relay_0, Supla::ON_CLICK_1);
if (!Protected)button_1->addAction(Supla::TOGGLE, relay_1, Supla::ON_CLICK_2);
button_1->addAction(unDimm, custAct, Supla::ON_PRESS);
button_1->addAction(Supla::TOGGLE, relay_2, Supla::ON_HOLD);
LedS = new Supla::Device::StatusLed(stateLed, true);
// StatusLed(uint8_t outPin, bool invert)
// Use inverted logic for GPIO output, when:
// false -> HIGH=ON, LOW=OFF
// true -> HIGH=OFF, LOW=ON
LedS->setMode(Supla::LED_OFF_WHEN_CONNECTED);
// LED_ON_WHEN_CONNECTED /* default ,
// LED_OFF_WHEN_CONNECTED,
// LED_ALWAYS_OFF
SuplaDevice.setName(Supla_name);
wifi.setSsid(Router_SSID);
wifi.setPassword(Router_Pass);
SuplaDevice.setStatusFuncImpl(&status_func);
wifi.enableSSL(false);
SuplaDevice.begin(GUID, Supla_server, Email, AUTHKEY);
void loop() {
int C_W_read = digitalRead(button_pin); {
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
C_W_state = C_W_read;
if (C_W_state == LOW) {
ondemandwifiCallback () ;
last_C_W_state = C_W_read;
SuplaDevice.iterate();
delay(20);
if (((millis() - TempDisp_lasttime) > TempDisp_mtbs) || (updateOled)) {
WiFiConected = (WiFi.status() == WL_CONNECTED);
TempDisp_mtbs = 500;
if (updateOled){
updateOled = false;
TH_Overlay();
if ((millis() - dimm_lasttime) > dimm_mtbs) {
if (!dimm) {
display.setContrast(50, 50, 30);
display.display();
dimm = true ;
