H801
kutdenis
Friends, and you can see detailed instructions on the firmware module H801.
Bautrade?
Flash speed?
ip address that is setup?
Maybe there are some nuances in the firmware?
There may be bugs with the firmware?
Thank you very much!
TMSer
Hey.
This is what worked for me.
Baudrate: 115200
Flash size: 1MB
Flash Speed: 40MHz
SPI mode: DIO
I had to completly erase the flash first from the ESP chip for it to work.
http://www.pratikpanda.com/completely-f ... sh-memory/
kutdenis
TMSer
I was helped here in this viewtopic.php?f=11&t=228&hilit=h801&start=20#p5516 manual. Unfortunately, a lot of opportunity I limited, no full Windows. All manipulations have to be done through the terminal.
Return to “Help”
