Esp8266 12 touch control relay
eradek
Ok then I can stay with 3V3. Anyhow I am still doing something wrong, device register with the server it works fine, however when I turn on relay or touch the button I don't get 3V3 on relay pins, to be honest nothing changes on relay pins. Is there any check I can do?
elmaya
What does it show you on the serial monitor?
do you have A0 A1 A2 connected to GND? "red marks"
eradek
Yes, they are connected to ground. This is what I see on terminal.
CONNECTED
local IP: 192.168.1.14
subnetMask: 255.255.255.128
gatewayIP: 192.168.1.1
Signal Strength (RSSI): -62 dBm
Server status:
9
Not connected
Server status:
10
Register in progress
Server status:
17
Registered and ready.
EEPROM.0 read.1 channel 0
Value changed
EEPROM.1 read.0 channel 1
EEPROM.2 read.0 channel 2
EEPROM.3 read.1 channel 3
Value changed
EEPROM.4 read.0 channel 4
EEPROM.5 read.0 channel 5
EEPROM.6 read.1 channel 6
Value changed
EEPROM.7 read.1 channel 7
Value changed
EEPROM.8 read.0 channel 8
EEPROM.9 read.1 channel 9
Value changed
EEPROM.10 read.0 channel 10
EEPROM.11 read.0 channel 11
3 touched
Value changed
BTN Switsh off relay 104
3 released
EEPROM.3 write.0 channel 3
3 touched
Value changed
BTN Switsh on relay 104
3 released
EEPROM.3 write.1 channel 3
3 touched
Value changed
3 released
2 touched
Value changed
BTN Switsh on relay 103
2 released
EEPROM.2 write.1 channel 2
elmaya
It seems that MCP23017 is not working.
have you tried disconnecting from the power supply for a few seconds to restart everything, maybe the MCP23017 is stuck?
Are you using the code from the first page of the thread?
are you compiling with arduino ide?
eradek
Yes, using arduino ide tried everything. I think its broke MCP23017, ordered new one and will check that. Thanks for help.
beautiful times
Return to “Ideas and concepts”
