Supla Button 4 direct links
ritual
bulek68 wrote: Sun Jan 05, 2020 8:09 pm My construction concept for SUPLA Direct Link by elmaya. ;)
my concept for this.
ritual
Bad idea, already out of battery. Will try to implement wireless charging with li-ion battery.
ritual
Is it possible to execute multiple direct links by connecting a single gpio?
Like if i press one button and all the lights and fans in one room is turned on or off.
elmaya
just create a link for "Channel Group"
ritual
i tried using channel groups but when i try adding 2 switches which are on 2 different hardware it was not showing it in devices. it was only allowing me to add switches that were on same hardware.
ritual
i got it working, it only works if they are having same type i.e they all should be light switch or on/off switch. i have my fan connected as on/off switch and my lights are as light switches.is it possible to add it in one channel group or should i change the type of switch?
elmaya
change the type of the fan channel to light switch and add the corresponding icon.
ritual
there is no fan icon in light switch as of now. And if i upload it, then it doesn't get detected on google home anyway, so it remains as light switch in it and if i ask google assistant to turn off lights it switches the fan off aswell.
broki
Witam
Czy ktoś ma może schematy z pierwszej strony tego postu ?
Ni wiem jak mam podłączyć przyciski do wywołania linków bezpośrednich.
ritual
broki wrote: Tue Jan 26, 2021 7:36 pm Witam
connect the gpio to ground to execute the direct link
Return to “Ideas and concepts”
