8 buttons and 8 relays in esp with hc595
piotrekk
I already have some PCBs made a long time ago, now I wanted to use another PCB for another project. why should an unused board lie if it can be used to switch on relays
elmaya
8 X 8 + NTC10k rewritten for the current Supla library.
6 bistable inputs and 2 monostable: Gpio2 and gpio1 "TX" are incompatible with bistable switches.
#define supla_lib_config_h_  // silences debug messages
#include "LittleFS.h"
#include <WiFiManager.h>
#include <EEPROM.h>
#include <ESP8266TrueRandom.h>
#include <ArduinoJson.h>
#include <DoubleResetDetector.h>
#include <ShiftRegister74HC595.h>
#include <SuplaDevice.h>
#include <supla/sensor/NTC10K.h>
Supla::ESPWifi wifi("SSID", "PASS");  //------ Do not change----wifimanager takes care------
#define STORAGE_OFFSET 512
Supla::Eeprom eeprom(STORAGE_OFFSET);
//#define D0 16  //no internal pullup resistor
//#define D1  5
//#define D2  4
//#define D3  0  //must not be pulled low during power on/reset, toggles value during boot
//#define D4  2  //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15  //must not be pulled high during power on/reset
//#define RX  3  //High at boot
//#define TX  1  //must not be pulled low during power on/reset
char Supla_server[81] = ("Set server address");
char Email[81] = ("set email address");
char Supla_name[81] = ("Supla595");
char Router_SSID[32];
char Router_Pass[64];
char Supla_status[51];
bool shouldSaveConfig = false;
bool initialConfig = false;
int s;
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16];
int hc595outState[] = {0, 0, 0, 0, 0, 0, 0, 0};
static const char logo[] PROGMEM = "<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>";
WiFiManager wifiManager;
// create shift register object (number of shift registers, data pin 14 on 74595, clock pin 11 on 74595, latch pin 12 on 74595)
ShiftRegister74HC595 sr (1, 15, 16, 0);
#define DRD_TIMEOUT 10 // Number of seconds after reset during which a  subseqent reset will be considered a double reset.
#define DRD_ADDRESS 0 // RTC Memory Address for the DoubleResetDetector to use
DoubleResetDetector drd(DRD_TIMEOUT, DRD_ADDRESS);
class CustomControl : public Supla::Io {
  public:
    void customDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
      if (pin > 99) {
        sr.set(pin - 100, val);
        hc595outState[pin - 100] = val;
      else {
        return ::digitalWrite(pin, val);
    int customDigitalRead(int channelNumber, uint8_t pin) {
      if (pin > 99) {
        return hc595outState[pin - 100];
      } else {
        return ::digitalRead(pin);
} CustomControl;
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
void ondemandwifiCallback () {
  wifiManager.setDebugOutput(false); // Debug off
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81, "required");
  WiFiManagerParameter custom_Email("email", "Email", Email, 81, "required");
  WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 81, "required");
  WiFiManagerParameter custom_html_id21("<div><h4> - Supla State -   ");
  WiFiManagerParameter custom_html_id22( Supla_status);
  WiFiManagerParameter custom_html_id23( "</h4></div>");
  wifiManager.setBreakAfterConfig(true);
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  wifiManager.setConfigPortalBlocking(true);
  wifiManager.addParameter(&custom_Supla_server);
  wifiManager.addParameter(&custom_Email);
  wifiManager.addParameter(&custom_Supla_name);
  wifiManager.addParameter(&custom_html_id21);
  wifiManager.addParameter(&custom_html_id22);
  wifiManager.addParameter(&custom_html_id23);
  wifiManager.setCustomHeadElement(logo);
  wifiManager.setMinimumSignalQuality(8);
  wifiManager.setConfigPortalTimeout(300);
  std::vector<const char *> menu = {"wifi", "wifinoscan", "sep", "update", "sep", "info", "restart", "exit"};
  wifiManager.setMenu(menu);
  wifiManager.setTitle("By..ElMaya");
  if (!wifiManager.startConfigPortal("Supla595")) {
    Serial.println("Not connected to WiFi but continuing anyway.");
  } else {
    Serial.println("connected...yeey :)");
  strcpy(Supla_server, custom_Supla_server.getValue());
  strcpy(Email, custom_Email.getValue());
  strcpy(Supla_name, custom_Supla_name.getValue());
  wifiManager.getWiFiSSID().toCharArray(Router_SSID, 33);
  wifiManager.getWiFiPass().toCharArray(Router_Pass, 65);
  if (strcmp(Supla_server, "get_new_guid_and_authkey") == 0) {
    Serial.println("new guid & authkey.");
    EEPROM.write(300, 0);
    EEPROM.commit();
    delay(100);
    ESP.reset();
  if (shouldSaveConfig == true) {
    Serial.println(" config...");
    DynamicJsonDocument json(1024);
    json["Supla_server"] = Supla_server;
    json["Email"] = Email;
    json["Supla_name"] = Supla_name;
    json["Router_SSID"] = Router_SSID;
    json["Router_Pass"] = Router_Pass;
    File configFile = LittleFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    serializeJsonPretty(json, Serial);
    serializeJson(json, configFile);
    configFile.close();
    Serial.println("Config written successfully");
    WiFi.mode(WIFI_STA);
    delay(5000);
    ESP.restart();
  WiFi.softAPdisconnect(true);
void status_func(int status, const char *msg) {
  if (s != status) {
    s = status;
    if (s != 10) {
      strcpy(Supla_status, msg);
void guid_authkey(void) {
  if (EEPROM.read(300) != 60) {
    int eep_gui = 301;
    ESP8266TrueRandom.uuid(uuidNumber);
    String uuidString = "";
    for (int i = 0; i < 16; i++) {
      int topDigit = uuidNumber[i] >> 4;
      int bottomDigit = uuidNumber[i] & 0x0f;
      uuidString += "0123456789abcdef"[topDigit];
      uuidString += "0123456789abcdef"[bottomDigit];
    int length_uuid = uuidString.length();
    for (int i = 0; i < length_uuid; ++i) {
      EEPROM.put(eep_gui + i, uuidString[i]);
    int eep_aut = 341;
    String uuidString2 = "";
      uuidString2 += "0123456789abcdef"[topDigit];
      uuidString2 += "0123456789abcdef"[bottomDigit];
    int length_uuid2 = uuidString2.length();
    for (int i = 0; i < length_uuid2; ++i) {
      EEPROM.put(eep_aut + i, uuidString2[i]);
    EEPROM.write(300, 60);
    EEPROM.commit();
    delay(0);
  read_guid();
  read_authkey();
  Serial.print("GUID : "); Serial.println(read_guid());
  Serial.print("AUTHKEY : "); Serial.println(read_authkey());
String read_guid(void) {
  String read_eeprom = "";
  int i, ii = 0;
  int eep_star = 301;
  int end_guid = eep_star + SUPLA_GUID_SIZE;
  String temp_read = "0x";
  for (i = eep_star; i < end_guid + 16;  i = i + 1) {
    temp_read += char(EEPROM.read(i));
    read_eeprom += char(EEPROM.read(i));
    if ( (i % 2) == 0) {
      char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      GUID[ii] = strtoul( _guid, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
String read_authkey(void) {
  int i, ii = 0;
  int eep_star = 341;
  int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
  for (i = eep_star; i < end_authkey + 16;  i = i + 1) {
      char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
void setup() {
  EEPROM.begin(1024);
  if (WiFi.SSID() == "") {
    initialConfig = true;
  guid_authkey();
  if (LittleFS.begin()) {
    Serial.println("mounted file system");
    if (LittleFS.exists("/config.json")) {
      Serial.println("reading config file");
      File configFile = LittleFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DeserializationError deserializeError = deserializeJson(json, buf.get());
        if (!deserializeError) {
          Serial.println("\nparsed json");
          if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
          if (json.containsKey("Email")) strcpy(Email, json["Email"]);
          if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
          if (json.containsKey("Router_SSID")) strcpy(Router_SSID, json["Router_SSID"]);
          if (json.containsKey("Router_Pass")) strcpy(Router_Pass, json["Router_Pass"]);
        } else {
          Serial.println("failed to load json config");
        configFile.close();
  } else {
    Serial.println("failed to mount FS");
  wifi_station_set_hostname(Supla_name);
  if (drd.detectDoubleReset()) {
    Serial.println("Double Reset Detected");
    ondemandwifiCallback ();
  if (initialConfig == true) {
    ondemandwifiCallback();
  auto relay_0 = new Supla::Control::Relay(100, true, 96);
  relay_0->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  //relay_0->keepTurnOnDuration();  //relay_0->setDefaultStateOff(); //relay_0->setDefaultStateOn(); //relay_0->setDefaultStateRestore();
  auto relay_1 = new Supla::Control::Relay(101, true, 96);
  relay_1->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  auto relay_2 = new Supla::Control::Relay(102, true, 96);
  relay_2->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  auto relay_3 = new Supla::Control::Relay(103, true, 96);
  relay_3->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  auto relay_4 = new Supla::Control::Relay(104, true, 96);
  relay_4->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  auto relay_5 = new Supla::Control::Relay(105, true, 96);
  relay_5->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  auto relay_6 = new Supla::Control::Relay(106, true, 96);
  relay_6->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  auto relay_7 = new Supla::Control::Relay(107, true, 96);
  relay_7->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  auto Button_0 = new Supla::Control::Button(5, true, true); // Button on pin XX with internal pullUp // and LOW is considered as "pressed" state
  auto Button_1 = new Supla::Control::Button(4, true, true);
  auto Button_2 = new Supla::Control::Button(2, true, true);
  auto Button_3 = new Supla::Control::Button(14, true, true);
  auto Button_4 = new Supla::Control::Button(12, true, true);
  auto Button_5 = new Supla::Control::Button(13, true, true);
  auto Button_6 = new Supla::Control::Button(3, true, true);
  auto Button_7 = new Supla::Control::Button(1, true, true);
  Button_0->addAction(Supla::TOGGLE, relay_0, Supla::ON_CHANGE);  // Biestable
  Button_1->addAction(Supla::TOGGLE, relay_1, Supla::ON_CHANGE);
  Button_2->addAction(Supla::TOGGLE, relay_2, Supla::ON_PRESS);   // Monoestable
  Button_3->addAction(Supla::TOGGLE, relay_3, Supla::ON_CHANGE);
  Button_4->addAction(Supla::TOGGLE, relay_4, Supla::ON_CHANGE);
  Button_5->addAction(Supla::TOGGLE, relay_5, Supla::ON_CHANGE);
  Button_6->addAction(Supla::TOGGLE, relay_6, Supla::ON_CHANGE);
  Button_7->addAction(Supla::TOGGLE, relay_7, Supla::ON_PRESS);
  new Supla::Sensor::NTC10K(A0);
  SuplaDevice.setName(Supla_name);
  SuplaDevice.setStatusFuncImpl(&status_func);
  wifi.enableSSL(false);
  wifi.setSsid(Router_SSID);
  wifi.setPassword(Router_Pass);
  SuplaDevice.begin(GUID, Supla_server, Email, AUTHKEY);
void loop() {
  drd.loop();
  SuplaDevice.iterate();
  delay(25);
new_hc595_8x8_NTC_DOUT_16Mbit.rar
piotrekk
elmaya wrote: Tue Sep 07, 2021 10:06 am 8 X 8 + NTC10k rewritten for the current Supla library.
#include <EEPROM.h>
//#define D1  5
//#define D2  4
//#define D5 14
//#define D6 12
//#define D7 13
int s;
  public:
      if (pin > 99) {
      else {
      if (pin > 99) {
      } else {
} CustomControl;
  } else {
    EEPROM.commit();
    delay(100);
    ESP.reset();
    if (!configFile) {
    configFile.close();
    delay(5000);
    ESP.restart();
  if (s != status) {
    s = status;
    if (s != 10) {
    int eep_gui = 301;
    int eep_aut = 341;
    EEPROM.commit();
    delay(0);
  read_guid();
  read_authkey();
  int i, ii = 0;
  int eep_star = 301;
      temp_read = "0x";
      ii++;
  return read_eeprom;
  int i, ii = 0;
  int eep_star = 341;
      temp_read = "0x";
      ii++;
  return read_eeprom;
void setup() {
  EEPROM.begin(1024);
  guid_authkey();
      if (configFile) {
        } else {
        configFile.close();
  } else {
void loop() {
  drd.loop();
  delay(25);
home
how did a friend make such a cool plate?
jak zrobił kolega taką fajną płytkę ?
Une enquГЄte terminГ©e sans affecter la qualitГ© de vie propriГ©tГ©s musculaires cardiaques, pulmonaires et sanguines..
piotrekk
home wrote: Tue Feb 22, 2022 12:36 pm jak zrobił kolega taką fajną płytkę ?
if you want to solder it yourself, I can provide gerberas, I did not draw the diagram
jeśli chcesz sam taką polutować to mogę udostępnić gerbery, schematu nie rysowałem
Please use English here.
home
piotrekk wrote: Tue Feb 22, 2022 9:11 pm
Piotr, please share the files, thank you
Bernix
elmaya wrote: Fri Jan 25, 2019 6:53 pm 16 push button, 16 relay
PORTS SETTINGS:
GPIO5 /D1 Switching_Relay_Button Channel 1- On the port must be pull-up. Active - connect to GND
GPIO4 /D2 Switching_Relay_Button Channel 2- On the port must be pull-up. Active - connect to GND
GPIO2 /D4 Switching_Relay_Button Channel 3- On the port must be pull-up. Active - connect to GND
GPI14 /D5 Switching_Relay_Button Channel 4- On the port must be pull-up. Active - connect to GND
GPIO12/D6 Switching_Relay_Button Channel 5- On the port must be pull-up. Active - connect to GND
GPIO13/D7 Switching_Relay_Button Channel 6- On the port must be pull-up. Active - connect to GND
GPIO3 /RX Switching_Relay_Button Channel 7- On the port must be pull-up. Active - connect to GND
GPIO1 /TX Switching_Relay_Button Channel 8- On the port must be pull-up. Active - connect to GND
Channel 9 to 16 A0 with resistive divider 8 x 1kohm
GPIO15/D8 shift registers, data pin 14 on 74595
GPIO16/D0 shift registers, clock pin 11 on 74595
GPIO0 /D3 shift registers, latch pin 12 on 74595
fisrt shift registers Q7´pin 9 ,to second shift registers data pin 14
#include <FS.h>       // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ShiftRegister74HC595.h>   //https://github.com/Simsso/ShiftRegister74HC595
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
ShiftRegister74HC595 sr (2, 15, 16, 0); // create shift register object (number of shift registers, data pin 14 on 74595, clock pin 11 on 74595, latch pin 12 on 74595)
#include <math.h>
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h> //--------- https://github.com/tzapu/WiFiManager/tree/0.14 -------------
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
extern "C"
#include "user_interface.h"
#define DRD_TIMEOUT 30 // Number of seconds after reset during which a  subseqent reset will be considered a double reset.
int uno = 1;
bool eep = LOW;          //             ---------------- Eeprom ------------------
bool startEeprom = true; //             ---------------- Eeprom ------------------
int epr = 0;             //             ----------- Eepron read loops ------------
int s;                   //             ---------------- Status ------------------
int an;
int buttonValue = 0;
unsigned long svr_update = 1800000; //mean time between update  30 minutes
unsigned long svr_update_lasttime;   //last time update
unsigned long wifi_checkDelay = 60000;  // wifi reconect delay
unsigned long wifimilis;
unsigned long eep_milis;
unsigned long an_milis;
#define BEGIN_PIN 100
#define BTN_COUNT 16
WiFiClient client;
char Supla_server[40];
char Location_id[15];
char Location_Pass[20];
byte mac[6];
//flag for saving data
int timeout           = 120; // seconds to run for wifi config
void saveConfigCallback () {                 //callback notifying us of the need to save config
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 40);
  WiFiManagerParameter custom_Location_id("ID", "Location_id", Location_id, 15);
  WiFiManagerParameter custom_Location_Pass("Password", "Location_Pass", Location_Pass, 20);
  wifiManager.addParameter(&custom_Location_id);
  wifiManager.addParameter(&custom_Location_Pass);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  wifiManager.setMinimumSignalQuality();
    wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("Supla16x16")) {
      Serial.println("failed to connect and hit timeout");
      delay(3000);
      ESP.restart();
      delay(5000);
    strcpy(Location_id, custom_Location_id.getValue());
    strcpy(Location_Pass, custom_Location_Pass.getValue());
  WiFi.softAPdisconnect(true);   //  close AP
typedef struct {  //------------------------------------------- BTN ----------------------------------------------------
  int pin;
  int relay_pin;
  int channel;
  char last_val;
  int ms;
  unsigned long last_time;
  bool mem;
} _btn_t;
_btn_t btn[BTN_COUNT];
void supla_timer() {
  char v;
  unsigned long now = millis();
  for(int a=0;a<BTN_COUNT;a++)
    if (btn[a].pin > 0) {
        v = digitalRead(btn[a].pin);
        if (v != btn[a].last_val && now - btn[a].last_time ) {
           btn[a].last_val = v;
           btn[a].last_time = now;
           if (v==0)
              if ( btn[a].ms > 0 ) {
                     SuplaDevice.relayOn(btn[a].channel, btn[a].ms);
                     Serial.println(" monostable");
                 } else {
                 if ( (btn[a].mem) == 1 ) {   //   ----------------- == 1 if channel is false... == 0 if channel is true -----------------------
                  SuplaDevice.relayOff(btn[a].channel);
                  Serial.print("BTN Switsh off relay ");
                  Serial.println(btn[a].relay_pin);
                 } else {
                  SuplaDevice.relayOn(btn[a].channel, 0);
                  Serial.print("BTN Switsh on relay ");
void supla_btn_init() {
        pinMode(btn[a].pin, INPUT_PULLUP);
        btn[a].last_val = digitalRead(btn[a].pin);
        btn[a].last_time = millis();
int supla_DigitalRead(int channelNumber, uint8_t pin) {
      if (channelNumber == 0){
        if (btn[0].mem ==0) return 0;
        else return 1;
      if (channelNumber == 1){
        if (btn[1].mem ==0) return 0;
        else return 1;
      if (channelNumber == 2){
        if (btn[2].mem ==0) return 0;
        else return 1;
      if (channelNumber == 3){
        if (btn[3].mem ==0) return 0;
        else return 1;
      if (channelNumber == 4){
        if (btn[4].mem ==0) return 0;
        else return 1;
      if (channelNumber == 5){
        if (btn[5].mem ==0) return 0;
        else return 1;
      if (channelNumber == 6){
        if (btn[6].mem ==0) return 0;
        else return 1;
      if (channelNumber == 7){
        if (btn[7].mem ==0) return 0;
        else return 1;
      if (channelNumber == 8){
        if (btn[8].mem ==0) return 0;
        else return 1;
      if (channelNumber == 9){
        if (btn[9].mem ==0) return 0;
        else return 1;
      if (channelNumber == 10){
        if (btn[10].mem ==0) return 0;
        else return 1;
      if (channelNumber == 11){
        if (btn[11].mem ==0) return 0;
        else return 1;
      if (channelNumber == 12){
        if (btn[12].mem ==0) return 0;
        else return 1;
      if (channelNumber == 13){
        if (btn[13].mem ==0) return 0;
        else return 1;
      if (channelNumber == 14){
        if (btn[14].mem ==0) return 0;
        else return 1;
      if (channelNumber == 15){
        if (btn[15].mem ==0) return 0;
        else return 1;
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {  //------------------------------------------------  Virtual ----------------------------
       btn[0].mem =val;
       sr.set(0, val); // set single pin
       btn[1].mem =val;
       sr.set(1, val); // set single pin
       btn[2].mem =val;
       sr.set(2, val); // set single pin
       btn[3].mem =val;
       sr.set(3, val); // set single pin
       btn[4].mem =val;
       sr.set(4, val); // set single pin
       btn[5].mem =val;
       sr.set(5, val); // set single pin
       btn[6].mem =val;
       sr.set(6, val); // set single pin
       btn[7].mem =val;
       sr.set(7, val); // set single pin
       btn[8].mem =val;
       sr.set(8, val); // set single pin
       btn[9].mem =val;
       sr.set(9, val); // set single pin
       btn[10].mem =val;
       sr.set(10, val); // set single pin
       btn[11].mem =val;
       sr.set(11, val); // set single pin
       btn[12].mem =val;
       sr.set(12, val); // set single pin
       btn[13].mem =val;
       sr.set(13, val); // set single pin
       btn[14].mem =val;
       sr.set(14, val); // set single pin
       btn[15].mem =val;
       sr.set(15, val); // set single pin
  return;
void Eeprom_save() {                  //----------EEPROM write  ---------------------- EEprom
    if (startEeprom == true){             // ----- don't change memorized state until connected and restored all the channels
      return;
      for(int i=0;i<BTN_COUNT;i++) {  //  ---check relay except it have delay (staircase)
         if ( btn[i].ms > 0 ) {
                     continue;
         } else {
        eep = (btn[i].mem);                    //  --- read relay state
        if (eep != EEPROM.read(i)){            //  --- compare relay state with memorized state
         EEPROM.write(i,eep);                  //  --- if different write memory
         Serial.print("EEPROM.");
         Serial.print(i);
         Serial.print(" write.");
         Serial.println((eep));
         Serial.print(" channel ");
         Serial.println((btn[i].channel));
         EEPROM.commit();
void Eepron_read() {                  //----------EEPROM read  ---------------------- EEprom
   // for(int i=0;i<BTN_COUNT;i++){      //  ---check relay except der have delay (staircase)
     //if ( (btn[i].ms) > 0 ) {
                //     continue;
        // } else {
        eep = EEPROM.read(epr);               //  ---read relay state
         Serial.print(epr);
         Serial.print(" read.");
         Serial.println((btn[epr].channel));
        if (eep == HIGH){                    //  --- if 1 send relay on
          SuplaDevice.relayOn(epr, 0);       //  --- only one channel in each pass
    if (epr == (BTN_COUNT-1)) {
      startEeprom = false;                //  --- once finished we do not need more
void status_func(int status, const char *msg) {     //    ------------------------ Status --------------------------
 s=status;                                          //    -- to check if we are registered and ready before restore from memory
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(115200);
  EEPROM.begin(512);
  } else {
    Serial.println("No Double Reset Detected");
  if (WiFi.SSID()==""){  //Serial.println("We haven't got any access point credentials, so get them now");
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    if (SPIFFS.exists("/config.json")) {
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        //json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {
          strcpy(Location_id, json["Location_id"]);
          strcpy(Location_Pass, json["Location_Pass"]);
        } else {
      } else {
   uint8_t mac[WL_MAC_ADDR_LENGTH];
   WiFi.macAddress(mac);
   char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
                                 mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
                                 mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
  SuplaDevice.addRelay(101, false);
  SuplaDevice.addRelay(102, false);
  SuplaDevice.addRelay(103, false);
  SuplaDevice.addRelay(104, false);
  SuplaDevice.addRelay(105, false);
  SuplaDevice.addRelay(106, false);
  SuplaDevice.addRelay(107, false);
  SuplaDevice.addRelay(108, false);
  SuplaDevice.addRelay(109, false);
  SuplaDevice.addRelay(110, false);
  SuplaDevice.addRelay(111, false);
  SuplaDevice.addRelay(112, false);
  SuplaDevice.addRelay(113, false);
  SuplaDevice.addRelay(114, false);
  SuplaDevice.addRelay(115, false);
  SuplaDevice.addRelay(116, false);
  memset(btn, 0, sizeof(btn));
  btn[0].pin =5;          // pin gpio buton  0 = no buton
  btn[0].relay_pin =101;  // pin gpio Relay
  btn[0].channel =0;      // channel
  btn[0].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[0].mem =0;
  btn[1].pin =4;          // pin gpio buton  0 = no buton
  btn[1].relay_pin =102;  // pin gpio Relay
  btn[1].channel =1;      // channel
  btn[1].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[1].mem =0;
  btn[2].pin =2;          // pin gpio buton  0 = no buton
  btn[2].relay_pin =103;  // pin gpio Relay
  btn[2].channel =2;      // channel
  btn[2].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[2].mem =0;
  btn[3].pin =14;         // pin gpio buton  0 = no buton
  btn[3].relay_pin =104;  // pin gpio Relay
  btn[3].channel =3;      // channel
  btn[3].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[3].mem =0;
  btn[4].pin =12;         // pin gpio buton  0 = no buton
  btn[4].relay_pin =105;  // pin gpio Relay
  btn[4].channel =4;      // channel
  btn[4].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[4].mem =0;
  btn[5].pin =13;         // pin gpio buton  0 = no buton
  btn[5].relay_pin =106;  // pin gpio Relay
  btn[5].channel =5;      // channel
  btn[5].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[5].mem =0;
  btn[6].pin =3;          // pin gpio buton  0 = no buton
  btn[6].relay_pin =107;  // pin gpio Relay
  btn[6].channel =6;      // channel
  btn[6].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[6].mem =0;
  btn[7].pin =1;          // pin gpio buton  0 = no buton
  btn[7].relay_pin =108;  // pin gpio Relay
  btn[7].channel =7;      // channel
  btn[7].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[7].mem =0;
  btn[8].pin =22;          // pin gpio buton  0 = no buton
  btn[8].relay_pin =109;  // pin gpio Relay
  btn[8].channel =8;      // channel
  btn[8].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[8].mem =0;
  btn[9].pin =22;         // pin gpio buton  0 = no buton
  btn[9].relay_pin =110;  // pin gpio Relay
  btn[9].channel =9;      // channel
  btn[9].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[9].mem =0;
  btn[10].pin =22;         // pin gpio buton  0 = no buton
  btn[10].relay_pin =111;  // pin gpio Relay
  btn[10].channel =10;     // channel
  btn[10].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[10].mem =0;
  btn[11].pin =22;         // pin gpio buton  0 = no buton
  btn[11].relay_pin =112;  // pin gpio Relay
  btn[11].channel =11;     // channel
  btn[11].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[11].mem =0;
  btn[12].pin =22;         // pin gpio buton  0 = no buton
  btn[12].relay_pin =113;  // pin gpio Relay
  btn[12].channel =12;     // channel
  btn[12].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[12].mem =0;
  btn[13].pin =22;         // pin gpio buton  0 = no buton
  btn[13].relay_pin =114;  // pin gpio Relay
  btn[13].channel =13;     // channel
  btn[13].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[13].mem =0;
  btn[14].pin =22;         // pin gpio buton  0 = no buton
  btn[14].relay_pin =115;  // pin gpio Relay
  btn[14].channel =14;     // channel
  btn[14].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[14].mem =0;
  btn[15].pin =22;         // pin gpio buton  0 = no buton
  btn[15].relay_pin =116;  // pin gpio Relay
  btn[15].channel =15;     // channel
  btn[15].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[15].mem =0;
  supla_btn_init();
  SuplaDevice.setDigitalReadFuncImpl(&supla_DigitalRead);    //            ------Send Value to server -------
  SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite);   //        -------  Read Value from server   -------
  SuplaDevice.setTimerFuncImpl(&supla_timer);
  SuplaDevice.setStatusFuncImpl(&status_func);    //   ----------------------------- Status -----------------------------
  SuplaDevice.setName("Supla16x16");
  int LocationID = atoi(Location_id);
                    Supla_server,      // SUPLA server address
                    LocationID,        // Location ID
                    Location_Pass);    // Location Password
// read_initial_relay_state
                     continue;
         } else {
        eep = EEPROM.read(i);               //  ---read relay state
       if (eep > uno ){
         EEPROM.write(i,uno);
         Serial.println("epp correct");
         EEPROM.commit();
         Serial.print("Recover.");
         Serial.print(i);
         sr.set(btn[i].channel, eep); // set single pin
void loop() {
  drd.loop();
  if (initialConfig){
        EEPROM.write(i,0);
    ondemandwifiCallback () ;
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["Location_id"] = Location_id;
    json["Location_Pass"] = Location_Pass;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    Serial.println("config saved");
    ESP.restart();
    delay(5000);
  if (WiFi.status() != WL_CONNECTED) {
    WiFi_up();
  //if (millis() > an_milis){
   analog_switch();
    //an_milis = an_milis + 200;
  if (millis() > eep_milis){
     Eeprom_save() ;   //        ------------------------------Eepron save callback -----------------------------
     eep_milis = eep_milis + 5000 ;
  switch (s) {    //    ------------------------------------------------ Status ------------------------------------
  case 17:      // -----     STATUS_REGISTERED_AND_READY
  if (epr<BTN_COUNT){
  Serial.print("Eepron_read...");
  Serial.println(epr);
   Eepron_read() ;                // ------------------------------- Eeprom read callback -------------------------------
   epr = epr+1;                   // -------- 1 loop for each output 8 in total ----------
    break;
    case 10:      // --------------------- REGISTER_IN_PROGRESS  ----------------------
    epr = 0 ;
     startEeprom = true;
    break;
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
       WiFi_up();
          SuplaDeviceCallbacks cb;
          cb.get_temperature = NULL;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
void WiFi_up(){ // conect to wifi
  if (millis() > wifimilis)  {
  WiFi.begin();
  for (int x = 10; x > 0; x--)
    if (x == 1){
    wifimilis = (millis() + wifi_checkDelay) ;
    if (WiFi.status() == WL_CONNECTED)
     break;
    else
     yield();
     delay(500);
      Serial.print(".");
  if (WiFi.status() == WL_CONNECTED){
    Serial.println("");
    Serial.println("CONNECTED");
    Serial.print("local IP: ");
    Serial.print("subnetMask: ");
    Serial.print("gatewayIP: ");
    long rssi = WiFi.RSSI();
    Serial.print("Signal Strength (RSSI): ");
    Serial.print(rssi);
    Serial.println(" dBm");
  else
    Serial.println("");
    Serial.println("not connected");
void analog_switch(){
  buttonValue = analogRead(A0); //Read analog value from A0 pin
  if (buttonValue<=50){   //For no button:
  delay (100);
  return;
  else
   delay (50);
   Serial.print ("analog read: ");
   Serial.println(buttonValue);
  if (buttonValue>=113 && buttonValue<=153){ //For 1st button:
    Serial.println("read: 9 ");
    an = 8;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=256 && buttonValue<=296){//For 2nd button:
    Serial.println("read: 10 ");
    an = 9;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=389  && buttonValue<=429){//For 3rd button:
    Serial.println("read: 11 ");
    an = 10;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=525  && buttonValue<=565){//For 4th button:
    Serial.println("read: 12 ");
    an = 11;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=654  && buttonValue<=694){//For 5rd button:
    Serial.println("read: 13 ");
    an = 12;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=796  && buttonValue<=836){//For 6th button:
    Serial.println("read: 14 ");
    an = 13;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=930  && buttonValue<=970){//For 7rd button:
    Serial.println("read: 15 ");
    an = 14;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=1000 ){//For 8th button:
    Serial.println("read: 16 ");
    an = 15;
    analogRelay() ;
    delay (500);
    return;
void analogRelay(){
   if ( btn[an].ms > 0 ) {
                     SuplaDevice.relayOn(btn[an].channel, btn[an].ms);
                 } else {
                 if ( (btn[an].mem) == 1 ) {   //   ----------------- == 1 if channel is false... == 0 if channel is true -----------------------
                  SuplaDevice.relayOff(btn[an].channel);
                  Serial.println(btn[an].relay_pin);
                 } else {
                  SuplaDevice.relayOn(btn[an].channel, 0);
             delay (500);
Initial parameters for "ESP Falsh Download Tool":
CreystalFreq 26M
SPI SPEED 40 MHz
SPI MODE QIO
BAUDRATE 11520
FLASH SIZE 32Mbit (4MByte)
supla_595_reset_to_Config16_x16.bin ------------> 0x00000
// CFG MODE - SWITCH
To bring the device into configuration mode, in this case press Reset_Button 2 times
When in configuration mode, the device goes into Access Point mode.
In order to enter or change the settings, you need to:
- Sign in at https://cloud.supla.org (registration is free of charge)
- Connect to WiFi called (Supla16x16) from any computer with a wireless network card and Internet browser.
- Open access page: http://192.168.4.1
- Enter user name and password to the WiFi through which the device will get Internet access.
- Enter Server address, Location ID and Location Password, which will be provided once you sign in at cloud.supla.org
Hi.
Question for my friend Elmaya. Will this arrangement work with Supla? I just managed to find this great product on AliExpress, check it out!
PLN 92.09 | ESP8266 WIFI 16 Relay Module ESP-12F Development Board Power Supply 5V/12V/24V 10A
https://a.aliexpress.com/_EwFVd9p and whether the software from this post will work. It's about controlling the blinds.
Sorry for the English, it's from a translator.
vicam
Hi
Could someone compile the software for this module from aliexpres for me?
https://pl.aliexpress.com/item/10050074 ... pt=glo2pol
Return to “Ideas and concepts”
