Hello,
I want all gpio should be off while reset or restart esp. but unable to put all 4 gpio at low while restart, in wifisocket firmware.
where to change in below please let me know.
<<<<<<<<<<<<code>>>>>>>>>>>>>>>>>>>>>
https://github.com/SUPLA/supla-espressi ... fisocket.c
or i need to change in this
https://github.com/SUPLA/supla-espressi ... esp_gpio.c
want to all 4 gpio off while restart esp (wifisocket firmware
Remove all RELAY_FLAG_RESTORE flags.
Add here
https://github.com/SUPLA/supla-espressi ... ket.c#L112
supla_esp_gpio_hi(B_RELAY1_PORT, 0);
supla_esp_gpio_hi(B_RELAY2_PORT, 0);
supla_esp_gpio_hi(B_RELAY3_PORT, 0);
supla_esp_gpio_hi(B_RELAY4_PORT, 0);
Add here
hi did not work out
<<<<<<<<<<<<existing code>>>>>>>>>>>>>>>>>>>>>>>>>>
supla_relay_cfg[0].gpio_id = B_RELAY1_PORT;
supla_relay_cfg[0].flags = RELAY_FLAG_RESTORE_FORCE;
supla_relay_cfg[0].channel = 0;
#ifdef __BOARD_wifisocket_x4
supla_relay_cfg[1].gpio_id = B_RELAY2_PORT;
supla_relay_cfg[1].flags = RELAY_FLAG_RESTORE;
supla_relay_cfg[1].channel = 1;
supla_relay_cfg[2].gpio_id = B_RELAY3_PORT;
supla_relay_cfg[2].flags = RELAY_FLAG_RESTORE;
supla_relay_cfg[2].channel = 2;
supla_relay_cfg[3].gpio_id = B_RELAY4_PORT;
supla_relay_cfg[3].flags = RELAY_FLAG_RESTORE;
supla_relay_cfg[3].channel = 3;
#endif
<<<<<<<<<<<<<<<<<<<<<<<modified code>>>>>>>>>>>>>>>>>>>>>>>>>
#endif
#endif
#endif
hello please let me know what i am doing wrong.
Thankyou
Thankyou
Those relays are operated by hi or lo signal ?
with native code it was like when start or reset or restart two gpios high and two gpios low what i wanted that it should be low or off when restart or reset the esp but it is still 2 gpios high and 2 low at startup.
what to do
what to do
but can you let me know is my code right
