RPI image guide
Even supla-dev on the same raspberry does not want to connect ?
alv
You are doing something wrong. Lets do it again.
1. stop supla-server
2. export LD_LIBRARY_PATH=/usr/lib/supla-server
3. /usr/sbin/supla-server -D
4. open second tty, and bring printout: lsof -P -T -p PID_OF_SUPLA-SERVER
pid you can get typing: pgrep supla-server
DrDice
alv wrote:You are doing something wrong. Lets do it again.
pi@raspberrypi:~ $ sudo /etc/init.d/supla-server stop
[ ok ] Stopping supla-server (via systemctl): supla-server.service.
pi@raspberrypi:~ $
pi@raspberrypi:~ $ export LD_LIBRARY_PATH=/usr/lib/supla-server
pi@raspberrypi:~ $ /usr/sbin/supla-server -D
Illegal instruction
pi@raspberrypi:~ $ sudo /usr/sbin/supla-server -D
ERR[1469296417.391055] error:14076102:SSL routines:SSL23_GET_CLIENT_HELLO:unsupported protocol
DEBUG[1469296417.393443] Connection Finished
ERR[1469296422.395594] error:14076102:SSL routines:SSL23_GET_CLIENT_HELLO:unsupported protocol
DEBUG[1469296422.397814] Connection Finished
on second tty:
pi@raspberrypi:~ $ pgrep supla-server
8495
pi@raspberrypi:~ $ lsof -P -T -p 8495
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
supla-ser 8495 supla cwd unknown /proc/8495/cwd (readlink: Permission denied)
supla-ser 8495 supla rtd unknown /proc/8495/root (readlink: Permission denied)
supla-ser 8495 supla txt unknown /proc/8495/exe (readlink: Permission denied)
supla-ser 8495 supla NOFD /proc/8495/fd (opendir: Permission denied)
pi@raspberrypi:~ $ sudo lsof -P -T -p 8495
supla-ser 8495 supla cwd DIR 179,2 4096 1404 /home/pi
supla-ser 8495 supla rtd DIR 179,2 4096 2 /
supla-ser 8495 supla txt REG 179,2 137360 10403 /usr/sbin/supla-server
supla-ser 8495 supla mem REG 179,2 38612 1975 /lib/arm-linux-gnueabihf/libnss_nis-2.19.so
supla-ser 8495 supla mem REG 179,2 71628 1964 /lib/arm-linux-gnueabihf/libnsl-2.19.so
supla-ser 8495 supla mem REG 179,2 30592 1965 /lib/arm-linux-gnueabihf/libnss_compat-2.19.so
supla-ser 8495 supla mem REG 179,2 46820 1967 /lib/arm-linux-gnueabihf/libnss_files-2.19.so
supla-ser 8495 supla mem REG 179,2 91888 2011 /lib/arm-linux-gnueabihf/libz.so.1.2.8
supla-ser 8495 supla mem REG 179,2 9820 1938 /lib/arm-linux-gnueabihf/libdl-2.19.so
supla-ser 8495 supla mem REG 179,2 1242776 1930 /lib/arm-linux-gnueabihf/libc-2.19.so
supla-ser 8495 supla mem REG 179,2 122308 1990 /lib/arm-linux-gnueabihf/libpthread-2.19.so
supla-ser 8495 supla mem REG 179,2 117520 1943 /lib/arm-linux-gnueabihf/libgcc_s.so.1
supla-ser 8495 supla mem REG 179,2 435804 1956 /lib/arm-linux-gnueabihf/libm-2.19.so
supla-ser 8495 supla mem REG 179,2 809612 10087 /usr/lib/arm-linux-gnueabihf/libstdc++.so.6.0.20
supla-ser 8495 supla mem REG 179,2 3128748 35832 /usr/lib/arm-linux-gnueabihf/libmysqlclient.so.18.0.0
supla-ser 8495 supla mem REG 179,2 1414392 38188 /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
supla-ser 8495 supla mem REG 179,2 296724 38189 /usr/lib/arm-linux-gnueabihf/libssl.so.1.0.0
supla-ser 8495 supla mem REG 179,2 26672 1993 /lib/arm-linux-gnueabihf/librt-2.19.so
supla-ser 8495 supla mem REG 179,2 18920 9986 /usr/lib/arm-linux-gnueabihf/libarmmem.so
supla-ser 8495 supla mem REG 179,2 134448 1895 /lib/arm-linux-gnueabihf/ld-2.19.so
supla-ser 8495 supla 0u CHR 136,0 0t0 3 /dev/pts/0
supla-ser 8495 supla 1u CHR 136,0 0t0 3 /dev/pts/0
supla-ser 8495 supla 2u CHR 136,0 0t0 3 /dev/pts/0
supla-ser 8495 supla 3u IPv4 51134 0t0 TCP *:2016
supla-ser 8495 supla 4u IPv4 51135 0t0 TCP *:2015
supla-ser 8495 supla 5u 0000 0,11 0 3644 anon_inode
supla-ser 8495 supla 6u 0000 0,11 0 3644 anon_inode
supla-ser 8495 supla 7u unix 0xd8a2fd40 0t0 51140 /tmp/supla-server-ctrl.sock
pi@raspberrypi:~ $
alv
did you already try with bash script?
eg.
echo -e "#!/bin/bash \nexport LD_LIBRARY_PATH=/usr/lib/supla-server \n/usr/sbin/supla-server -D" >> /home/pi/supla-server_debug.sh
chmod +x /home/pi/supla-server_debug.sh
You set the library for pi user, but app is starting as supla
DrDice
alv wrote:did you already try with bash script?
eg.
./supla-server_debug.sh: line 3: 9696 Illegal instruction /usr/sbin/supla-server -D
DrDice
When I scan the local IP with nmap, I only get this:
Starting Nmap 7.12 ( https://nmap.org ) at 2016-07-24 21:11 CEST
Nmap scan report for raspberrypi.local (192.168.0.59)
Host is up (0.014s latency).
Other addresses for raspberrypi.local (not scanned): fe80::28:94d4:b841:7e72
Not shown: 997 closed ports
PORT STATE SERVICE
22/tcp open ssh
80/tcp open http
443/tcp open https
Seems like port 2015 and 2016 is missing, or am I wrong?
DrDice
pzygmunt wrote:Even supla-dev on the same raspberry does not want to connect ?
No. Supla-dev wont connect. Tried to start supla-dev -D and it just keeps saying connecting
Strange. If you use this image
https://www.supla.org/download/SUPLA-SERVER-RBPI.zip
everything should work fine just after boot.
DrDice
pzygmunt wrote:Strange. If you use this image
I will try it once more :-)
I have just tested the current RPI image and the port 2015 and 2016 only show up in nmap when running the server in debug mode, despite the ssl errors
1. Flash SD Card.
2. Just boot
3. Open web browser and type IP address of raspberry
4. Sign in
5. Send to me screenshot of "IO Devices" tab.
Return to “Help”
