Supla-Cloud-Server
bouali
i have sent it in private
bouali
thank you very much pzygmunt for your help i have solved the problem
emiliakowalski
THIS IS THE REASON MY APP IS NOT CONNECTING WITH THE SERVER PLEASE HELP ME OUT
emiliakowalski
can you help me bouli
bouali
emiliakowalski
why there is ssl 3 error i have tried to compile with new openssl version but failed give error no function of ssl3 method defined
cd /usr/src
sudo mkdir openssl
sudo wget https://www.openssl.org/source/openssl-1.0.1t.tar.gz
sudo tar zxvf openssl-1.0.1t.tar.gz
cd openssl-1.0.1t
sudo ./config --prefix=/usr/src/openssl shared
*edit Makefile and remove no-ssl2 flags
sudo make depend
sudo make install
sudo cp /usr/src/openssl/lib/*.so /usr/lib/supla-server/
sudo rm -rf cp /usr/src/openssl
emiliakowalski
solved
emiliakowalski
i used this command to create schema in supla database
$ php app/console doctrine:schema:create
used latest version supla 2.0
but app giving error of " BAD CREDENTIALS"
so i checked supla-server, error is there is no no such table in database do i need to create new tables manually.
There is no such table in database --------------supla.supla_v_device_accessid-------------
Use attached one.
Return to “Help”
