Gate Module
I built the gate module firmware from ESP8266-IOT-SDK and flashed it on the nodemcu board. An led was blinking but there was no SSID broadcast. What am I doing wrong? Thank You in advance.
You should switch the device to the config mode.
I tried it but it didn't came to configuration mode.
Do you have pullup on cfg pin ?
I don't have any external pullup. I re-flashed the firmware now it works.
You should have external pullup on cfg pin.
I tried WeMos_gate_x2_DS18B20 in which cfg button is used to switch relay. But its not switching the relay. I provided the pullup to the cfg port. Also cfg button does not brings the device to the config mode.
Any guidance?
Thank you in advance.
Any guidance?
To bring the device into configuration
mode, press and hold button for at least 5 sec.
