ESP8266 - WIFI SOCKET
bouali
hello,
i need help , i have tested the firm-WiFiSocket-Firmware-, all things went very well. but the issue is i can't change the wifi (SSID/PWD) of station mode in esp8266 at the 192.168.4.1.
it seems to me that this is can be change only in the beginning, or the error in my flash firm.
thank.
Check flash size
bouali
thank you for your reply, but it worked for the first time, now the problem is the re-connection again to 192.168.4.1 i mean that esp8266 not run as a softap;
Return to “Help”
