wifisocket_x4 v2.0 - led CFG mode Do not blink
vuhazu
I use Supla-IOT-SDK build wifisocket_x4 v2.0 form VM VitualBox
I do not see the configuration for led CFG form wifisocket.c & wifisocket.h
After building and loading the software into ESP8266 - it ok but led CFG mode is not available
http://s1029.photobucket.com/user/babyd ... 1.jpg.html
http://s1029.photobucket.com/user/babyd ... 7.jpg.html
what should I do for CFG led blink when ESP8266 CFG mode
Thanks
Espablo
It's a LED for ESP-12
Add there
https://github.com/SUPLA/supla-espressi ... cket.h#L25
#define LED_RED_PORT    2
vuhazu
Espablo wrote: Sun May 28, 2017 6:19 pm It's a LED for ESP-12
Add there
I've been tried but not run because i used GPIO 15
i change it to GPIO 16 it's ok
I don't know why GPIO 15 does not work
#ifndef WIFISOCKET_H_
#define WIFISOCKET_H_
#define CFGBTN_TYPE_SELECTION
#ifdef __BOARD_wifisocket_x4
#define USE_GPIO16_OUTPUT
#define LED_RED_PORT 15
#else
#ifndef __BOARD_wifisocket_esp01
#define DS18B20
#define TEMPERATURE_CHANNEL 1
#define LED_RED_PORT 13
#define LED_GREEN_PORT 12
#define LED_BLUE_PORT 14
#endif
#endif
void ICACHE_FLASH_ATTR supla_esp_board_send_channel_values_with_delay(void *srpc);
#endif
Espablo
vuhazu
thanks, it worked very well
Return to “Help”
