Set bathroom lights to turn on in dim state
Smartypants
I'm in the middle of a home renovation in UK and am pretty much decided on getting Varilight v pro smart dimmers for the entire house.
One of the features I need is that if I turn on the bathroom lights at night, they should turn on at 10 percent brightness so it's easy on the eyes. I also want to be able to turn up the brightness through the physical dimmer if required. Would this be possible using the supla app?
I have basic home automation skills and am can potentially work with home assistant if that will do the job.
Thanks!
You can turn the lights on at any percentage of brightness with the app, but the button on the wall always turns the lights on at the level they were before you turned them off. We plan to introduce a schedule feature that would allow you to change the brightness settings without turning on the lights, but it's not ready at the moment.
Smartypants
Thanks, do you know if this will be possible with Home Assistant?
You can integrate a dimmer with HA but it will still not be possible to change the brightness without turning on the light.
Return to “Help”
