Hi there,
I have successfully connected one Home+ from Heatpol radiator. I cannot add more.
When I try to add the failed radiators, the confirmation screen either says registered and ready or nothing. Even when marked registered and ready, they do not appear in the SUPLA app.
Can you please advise?
Thank you,
Peter
Cannot connect more than one radiator
This is probably a problem with a whole batch of devices that came out with an identical GUID number. A manual on how to fix this yourself will be available soon.
Hi there,
Can you please help me understand the timeframe around "soon" - is that a week, a month or three months? And how will I be made aware & access this guide?
Thank you.
Peter
Thank you.
Peter
This fix is now available.
1. Switch the heater to pairing mode by holding the lower button for at least 5 seconds
2. Connect to the WiFi network broadcast by the heater
3. Open the page http://192.168.4.1
4. Fill in the access data to the WiFi network
5. In the email field, enter: guidfix@heatpol.pl
6. In the server address field, enter: svr11.supla.org
7. Switch "Firmware update" to "YES"
8. Press the "Save & Restart" button. If there is no button, then "Save", then disconnect the heater from the power supply and reconnect it.
Wait a few minute, and try adding to your account from the application level using the standard procedure. After the update, the heater should have a different GUID and firmware version 2.8.63.
Unfortunately the firmware is not updated. It is still 2.7.12, although I've tried to update it twice.
And the GUID that appears in the web browser is still the same for at least two devices.
I can see in the logs that you are trying to update but there is another problem. I will check if it can be solved remotely. I will let you know.
Sorry it took so long. I think we have a workaround, but we need to test it first. I estimate it should be ready to use by 4/29.
