How to Calculate Historical Power Consumption For a Given Period
Juddy14
Hi,
I am kind of confused by the values shown on the graph in Cloud vs CSV/API output.
In this case, I've selected 26.03.2025 19:00-26.03.2025 20:00.
Cloud - total power consumption 0.28574 kWh
CSV/API - total power consumption 155408-139120=16288/100000=0.16288 kWh
No matter what I try, I can't get to the same result as in the Cloud.
How do I calculate the total power consumption from the values in CSV/API?
What if the API returns only just one row, how do I get the total power consumption then?
JSON data from REST API
        "date_timestamp": 1743012107,
        "phase1_fae": 10246,
        "phase1_rae": null,
        "phase1_fre": null,
        "phase1_rre": 4020,
        "phase2_fae": 122636,
        "phase2_rae": null,
        "phase2_fre": null,
        "phase2_rre": 11418,
        "phase3_fae": 6238,
        "phase3_rae": null,
        "phase3_fre": null,
        "phase3_rre": 18144,
        "fae_balanced": 139120,
        "rae_balanced": null
        "date_timestamp": 1743012708,
        "phase1_fae": 10982,
        "phase1_rae": null,
        "phase1_fre": null,
        "phase1_rre": 4714,
        "phase2_fae": 123912,
        "phase2_rae": null,
        "phase2_fre": null,
        "phase2_rre": 12750,
        "phase3_fae": 7342,
        "phase3_rae": null,
        "phase3_fre": null,
        "phase3_rre": 20760,
        "fae_balanced": 142236,
        "date_timestamp": 1743013729,
        "phase1_fae": 11836,
        "phase1_rae": null,
        "phase1_fre": null,
        "phase1_rre": 5808,
        "phase2_fae": 125948,
        "phase2_rae": null,
        "phase2_fre": null,
        "phase2_rre": 14956,
        "phase3_fae": 9120,
        "phase3_rae": null,
        "phase3_fre": null,
        "phase3_rre": 25118,
        "fae_balanced": 146904,
        "date_timestamp": 1743014329,
        "phase1_fae": 12284,
        "phase1_rae": null,
        "phase1_fre": null,
        "phase1_rre": 6426,
        "phase2_fae": 127132,
        "phase2_rae": null,
        "phase2_fre": null,
        "phase2_rre": 16276,
        "phase3_fae": 10178,
        "phase3_rae": null,
        "phase3_fre": null,
        "phase3_rre": 27696,
        "fae_balanced": 149594,
        "date_timestamp": 1743014929,
        "phase1_fae": 12432,
        "phase1_rae": null,
        "phase1_fre": null,
        "phase1_rre": 6946,
        "phase2_fae": 128520,
        "phase2_rae": null,
        "phase2_fre": null,
        "phase2_rre": 17836,
        "phase3_fae": 11566,
        "phase3_rae": null,
        "phase3_fre": null,
        "phase3_rre": 30392,
        "fae_balanced": 152518,
        "date_timestamp": 1743015530,
        "phase1_fae": 12486,
        "phase1_rae": null,
        "phase1_fre": null,
        "phase1_rre": 7436,
        "phase2_fae": 129764,
        "phase2_rae": null,
        "phase2_fre": null,
        "phase2_rre": 19326,
        "phase3_fae": 13158,
        "phase3_rae": null,
        "phase3_fre": null,
        "phase3_rre": 33178,
        "fae_balanced": 155408,
CSV data from the Cloud
Timestamp;Date and time;Phase 1 Forward active Energy kWh;Phase 1 Reverse active Energy kWh;Phase 1 Forward reactive Energy kvarh;Phase 1 Reverse reactive Energy kvarh;Phase 2 Forward active Energy kWh;Phase 2 Reverse active Energy kWh;Phase 2 Forward reactive Energy kvarh;Phase 2 Reverse reactive Energy kvarh;Phase 3 Forward active Energy kWh;Phase 3 Reverse active Energy kWh;Phase 3 Forward reactive Energy kvarh;Phase 3 Reverse reactive Energy kvarh;Forward active Energy kWh - total;Reverse active Energy kWh - total;Active Energy kWh - Arithmetic balance;Forward active Energy kWh - Vector balance;Reverse active Energy kWh - Vector balance
1743012107;2025-03-26 19:01:47;0.10246;;;0.0402;1.22636;;;0.11418;0.06238;;;0.18144;1.3912;0;1.3912;1.3912;
1743012708;2025-03-26 19:11:48;0.10982;;;0.04714;1.23912;;;0.1275;0.07342;;;0.2076;1.42236;0;1.42236;1.42236;
1743013729;2025-03-26 19:28:49;0.11836;;;0.05808;1.25948;;;0.14956;0.0912;;;0.25118;1.46904;0;1.46904;1.46904;
1743014329;2025-03-26 19:38:49;0.12284;;;0.06426;1.27132;;;0.16276;0.10178;;;0.27696;1.49594;0;1.49594;1.49594;
1743014929;2025-03-26 19:48:49;0.12432;;;0.06946;1.2852;;;0.17836;0.11566;;;0.30392;1.52518;0;1.52518;1.52518;
1743015530;2025-03-26 19:58:50;0.12486;;;0.07436;1.29764;;;0.19326;0.13158;;;0.33178;1.55408;0;1.55408;1.55408;
What does the smartphone app show for the same range?
Juddy14
This is what the APP shows
Change the data type to one bar and tap it.
Juddy14
This is what's shown when I tap on the first bar
Juddy14
Initially, I thought I would just sum all the rows from the following columns:
0.10246
0.10982
0.11836
0.12284
0.12432
0.12486
1.22636
1.23912
1.25948
1.27132
1.2852
1.29764
0.06238
0.07342
0.0912
0.10178
0.11566
0.13158
and that would be the total consumption, but this is not the case because the numbers are incrementally larger.
But even if subtract the first row from the last row of each column, and then sum it up, you still don't get the same result.
0.12486-0.10246=0.0224
1.29764-1.22636=0.07128
0.13158-0.06238=0.0692
0.16288
Cloud and applications operate on the same data, which you can download in XLS. It may be a time shift issue. UTC vs. your time zone. PM me the channel id and email address of the account and I'll take a look at the database.
Juddy14
I've just sent you a PM.
The issue is unlikely to be in the time zone because the data on the graph seems to match the rows in CSV, which can be downloaded via the cloud. The exactly same data I also obtained through your REST API.
Juddy14 wrote: Fri Mar 28, 2025 5:47 am I've just sent you a PM.
Cloud and Supla apps on mobile, show energy as an increment from the previous measurement.
Data, you fetched, is 10 min too late, that's why you don't see first bar of data in csv/api.
First bar contain delta value of between state at 19:01 and state at 18:51. If you'll get it in csv or via api, it should give you values as shown on charts.
Juddy14
You are right, I seem to get the right values if I choose 18:50 instead of 19:00.
So let's say I want to get data from 26.03.2025 19:00 to 26.03.2025 20:00.
Does it mean that I need to query 26.03.2025 18:50 to 26.03.2025 20:00 i.e. always subtract 10 minutes from the start date?
Is that correct?
Thanks for your help.
Return to “Help”
