Local (offline) solution for Varilight V-Pro Smart Wifi modules
gooseodyssey
Hi! I have Varilight V-Pro Smart WiFi dimmers and companion modules. I've got the Supla app working to control them. I followed the instructions in the Polish PDF to get Home Assistant working with MQTT and the Supla Cloud. This works well but sometimes it is slow and am I right in thinking that this requires an internet connection? Ideally I would have a local solution. Is there a way to connect locally to the V-Pro Smart WiFi modules? I think I read that they do not support direct MQTT connection, and it has to go via Supla Cloud? I also read that it is possible to run Supla locally? Thank you!
At the moment, there is no other option than running a local instance of supla cloud.
gooseodyssey
Thank you. Is there a guide somewhere on how to set up a local instance?
Return to “Help”
