Using SUPLA with my own created Hardware
Please try now.
I have changed cfg btn from GPIO2 to GPIO0
Anyway you should see anything on the consle.
Use for example Putty to monitor serial port.
You should set 74880 baudrate.
scropion86
Hi,
now it's working fine but!!
1-nothing on serial serial monitor on any usable Bud rate , only some trash on start booting.
2- the app didn't get the set of buttons by default i have to go to SUPLA cloud and set the function of each IO - channel - is that the default process or something wrong in my setup /FW.
3- when updating any info like button description or type the App and the Board reset.
4-no RGB color picker , and dimmer not working for me - is it 255 or 1023 resolution?
5- the Cloud console very informative but the design is not user friendly - complicated for the majority .
again over all it's great looking and nicely presented App , still missing the way to allow the user to create his own Custom FW , which can allow read some other web API data using Restful for example.
Hi.
1. You should connect RX, TX and GDN from FTDI to ESP. (check GND)
2. For your device there is no default settings. If you tell me which functions you need on which channel as defaults then I reconfigure environment for your device.
3. This should work this way
4. I wrote to you that this function is not implemented yet. Give me more time.
5. ....
scropion86
thanks alot
for the serials monitor , i know how to connect it but i tried and get nothing i will try to use different TTL USB device.
i will send you some question please check your inbox.
You can download firmware with RGB support
https://github.com/SUPLA/ESP8266/tree/master/EgyIOT
scropion86
thanks for taking time to made this , i will give it a try today and i will let you know.
scropion86
looking at the updated source files i figured that some changes still required before testing, as in that file https://github.com/SUPLA/supla-core/blo ... _devconn.c i see that all PWM values are used with resolution between 0 - 255 and that OK with 16bit MCU , but you know that ESP8266 is 32bit so the PWM resolution between should be 0 - 1023.
please change it so i can test it
thanks
This is not PWM resolution it is color range (0-255).
PWM period is set to 1Khz so duty range is 0-22222
https://github.com/SUPLA/supla-core/blo ... _pwm.c#L21
https://github.com/SUPLA/supla-core/blo ... _pwm.c#L51
Look at ESP8266 chip documentation.
scropion86
sorry i was thinking it's for the PWM not the color range.
How your tests ?
Return to “General discussion”
