Varilight V-Pro Smart Secondary Controller Bug
pdunne
Hi,
I have a lighting setup with varilight v-pro smart dimmers. The circuit has one master dimmer, a secondary dimmer and a momentary switch. The problem I'm having is that the secondary dimmer works fine unless the lights get to 100% brightness at which point no inputs from the secondary dimmer change brightness or on/off state of the lights. The momentary switch is still able to change the brightness and turn the circuit on/off in this circumstance as is the master dimmer and the app, but the secondary dimmer just does nothing.
Any ideas?
Return to “Help”
