Adding more RPi's in one setup
odin56
Is raspberry pi supports already dht22 ?
like ;
[CHANNEL_1]
type=3020
gpio1=22
0xFF
See thread: viewtopic.php?f=11&t=174.
I hope there is no need to translate ;-)
I have some issues with DHT-22 sensor, but DHT-11 works fine.
odin56 wrote:Is raspberry pi supports already dht22 ?
like ;
[CHANNEL_1]
type=3020
gpio1=22
Cfg example:
[CHANNEL_1]
type=DHT22
w1=22
w1 determines the number of GPIO port where the sensor is connected.
Then you must use the new version of supla-dev.
To use it you must:
cd
git clone https://github.com/SUPLA/raspberry
sudo /etc/init.d/supla-dev stop
sudo sudo cp raspberry/ext01/usr/sbin/supla-dev /usr/sbin/
sudo /etc/init.d/supla-dev start
odin56
thanks for your help. now i adding dht22 sensor but if gives only ones stats.
"Timestamp,"Date and time (CET)",Temperature,Humidity
1466109460,"2016-06-16 22:37:40",24.7000,51.0990"
and now it shows only " -°C -%"
i trying 4,7k and 5,1k resistor betweer power and data line.
and i have a different problem too, so if i put delays off in my phone, delays goes on, on the raspberry, so when phone says "light on" delays on the table is off, so how i can chance it like both on?
and have you some list of updated supported type of raspberry?
1000 - sensor normal open
2000 - RELAYHFD4 - gates, doors etc.
2010 - RELAYG5LA1A - gates, doors, lights, power
2020 - 2x2XRELAYG5LA1A - roller shutter
3000 - thermometer DS18B20
edit.
now DHT22 works fine, it updated every 10min.
Please use latest version of /usr/sbin/supla-dev it is avaiable at
odin56
thanks for newest version!
is dimmer supported soon on raspberry?
Yes, it will be soon supported
odin56
Hi.
how soon you get dimmer available on raspberry?
Return to “Help”
