Changing the package name of the Android application in Android Studio
eht
Hello everyone,
I hope you're doing well. I'm new here.
I designed an electronic card using Supla services and I also wanted to customize the mobile application's appearance with my colors. So, I downloaded the source code provided by Supla and after modifying it in Android Studio, everything worked correctly.
However, I wanted to perform a final step by changing the package name, and that's where I encountered a problem. After changing the package name of the Android application in Android Studio, and after compiling and installing it on my mobile phone, it seemed successful. Then, I filled in the following information - email address, ID, password, and server address - then clicked OK, but the application remains stuck on "connecting".
Can you help me? Is it possible to change the package name of the Android application? If so, I request your assistance.
Best regards,
Eric
Changing the package name will cause native (JNI) code to stop working. You would also have to modify it and recompile it.
https://github.com/SUPLA/supla-core/tre ... ndroid/jni
Remember to share the sources of the modified application.
If you want to modify the application and install it alongside the official one, all you need to do is change the application ID here
https://github.com/SUPLA/supla-android/ ... le.kts#L19
eht
pzygmunt wrote: Sun Feb 26, 2023 11:29 am Changing the package name will cause native (JNI) code to stop working. You would also have to modify it and recompile it.
Thank you very much for your response and for the link to the native code (JNI) that needs to be modified in case of a package name change. I will try to modify and recompile the native code in addition to the Java code of the application. And I will certainly share the sources of the modified application. Thanks again for your help.
eht
lesny8 wrote: Sun Feb 26, 2023 11:33 am If you want to modify the application and install it alongside the official one, all you need to do is change the application ID here
Thank you very much for your response and for the link to the configuration file where I can change the application ID. I will try to modify the application ID and install it alongside the official application. Thanks again for your help.
Return to “General discussion”
