I've set up an MQTT broker on Supla Cloud, but I cannot connect to it via Home Assistant.
I'm trying to do it by following option 1 on https://drive.google.com/file/d/10HTT6j ... jwdMPKQwb3
No matter what credentials/options I try in Home Assistant, I always get "Failed to Connect" with no extra information.
I'm assuming Home Assistant wants the following:
mqtt74.supla.org
8883
[MQTT Broker Username]
[MQTT Broker Password]
Not using any advanced options.
I'm not sure what to try next.
Is there a way to verify the broker with some other test app/cli, to at least know if the problem is on the HA side or the Supla side?
Thanks,
Richard
Connect to MQTT Broker via Home Assistant
Try to connect with MQTT explorer first.
- Attachments
- Zrzut ekranu 2023-01-10 o 14.21.47.png (105.78 KiB) Viewed 1851 times
Thanks, using MQTT Explorer worked.
Then I tried to add the device again and tried setting the advanced option about validating the certificate to "Auto" and it worked!
All sorted - thanks!
