How to get Supla devices in Home Assistant without MQTT?
Hi pzygmunt. Just wanted to say a huge thank you for getting my Supla heater working in HA. I think the issue I had was not being able to SSH into HA to setup the conf file.
Is everything working as you expected now?
EDIT:
Hello, I am looking for a help how to use SUPLA (ZAMEL SRW-01 for blinds control) in Home Assistant if I already have MQTT set up for another device. The other device connects to the Mosqitto broker via local network to port 1883. When I setup the MQTT as described for supla, will I loose the other device connection?
Also, can I use the SRW-01 with the local only mqtt and not use supla cloud at all ? Is there any tutorial for this local LAN sollution?
There are 3 scenarios to choose from:
1. Connect mqttX.supla.org to your broker (bridge mode)
2. Connect the HA to mqttX.supla.org
3. Connect SRW directly to your local broker.
Instructions for 1 and 2 https://drive.google.com/file/d/10HTT6j ... KQwb3/view
In the case of point 3, switch SRW to configuration mode, and then on page http://192.168.4.1 change the protocol from Supla to MQTT.
Hello, thank you, I will go with the option no 3.
I was able to setup SRW-01 to mqtt mode.
Now, what I must do on the homeassistant side to control the blinds?
EDIT: Ok, it is working, no action necessary on the HA side, auto discovery works fine
SBW-02 nemá na palubě MQTT, ale pokud jej připojíte z cloud.supla.org, bude k dispozici prostřednictvím brokera MQTT mqttX.supla.org.
Ano, ale mám již jiné přístoje na Zigbee2mqtt - Mosquito Broker.
Je nějaké řešení, jak dostat do HA tento ZAMEL SBW-02?
Nemusíte se vzdávat vlastního brokera. Můžete vytvořit most mezi svým vlastním brokerem a mqttX.supla.org
