how to change wifi without branching cable in esp8266
how can i turn the cart esp8266 to configuration mood ( turn on the wifi )
esp8266
Please describe in more detail what you are asking.
i want to change wifi access point ... so i need to turn config mode in the nodemcu on ... so i can connect to the cart then change the wifi
the problem is : i don't know how to turn on the config mode
i tried to press 10 times / 5 sec the reset button but the wifi dosent open
any idea ???
What firmware did you use there?
