gui generique builder 4.6.14
Hello everyone I hope you are doing well. I encountered a problem with the new version I generated a flash which does not work on my esp8266 nodemcu, the same flash which I had generated with version 4.6.13 which works well. i just want to add buttons and roller shutters
Please write more details. What options did you select? What exactly isn't working?
the problem is that after configuring the esp in the android application everything goes well but the esp is not visible in the cloud I repeat the configuration but it does not work. I did the same thing with the program generated with the old version and it worked fine
I chose the relay option and the first 4 (frequency, config, update, gui) 1mo
If you have changed options, added any, or added fewer than before, there may be a channel conflict.
When you enter CONFIG page, does some recent status show you?
Widzimy się na Supla Offline Party Season 2025
Last state : no connection to the network
LAST STATE "Brak połączenia z siecią" means No network connection.
This means that you have something misconfigured to connect to your WiFi network.
BTW. You can generate the firmware in another available language, e.g. English ou en français
Changing the Builder language also changes the language in GUI-Generic
The translation may contain errors, for which we apologize.You do not have the required permissions to view the files attached to this post.
send me the device configuration. I will check.
i tried 2 different esp01 and they cant connect to wifi
