Current WiFi Network data timeout
HappyDave
If I try and add my dimmer with the app I get this error message.
Phone is on wifi and working so what's up. Is your server down?
All servers are working properly. This message means Android did not return wifi data.
1. Enable location permissions for the Supla app.
2. Enable "Turn On Wi-Fi Automatically"
HappyDave
Ok, so for me the problem was I had turned off location access completely. Now works fine.
It might be an idea for the app to check if it has this permission and warn if not rather then saying data timeout?
The application checks these permissions, but for some reason, after disabling them, in some cases the message does not appear. Which version of Android do you have?
HappyDave
Return to “Help”
