thermostat with Oled display
elmaya
Michal81 wrote: Sat Feb 29, 2020 3:18 pm Help.
Elmay, can you tell me the reasons for the Error message when converting the USB power supply to the power supply?
Connected as in the picture:
the ERROR Conimukat appears
What is this, what does it mean?
The display shows errors as "E" with a number.
Michal81
elmaya wrote: Sat Feb 29, 2020 3:47 pm
I am sorry if I described it poorly.
The ERROR message appears.
elmaya
What cable length do you have for DS18B20?
test with a lower resistor of 2,2kohm for the DS18B20 probe.
Michal81
80 cm long nan sensor cable.
A resistor like the three design in the first post 4.7 kohm.
Are you suggesting inserting a smaller 2.2kohm ??
elmaya
yes, reduce the resistance of 4,7koh or use 2 in parallel,
you have a problem of electrical derivation, you can also connect the GND of the wemos to earth.
Perhaps it is also possible to solve it by turning the plug around (220v).
Michal81
elmaya - Is it possible for a cannon project with e.g. a display like this: https://pl.aliexpress.com/item/32994189 ... hweb201603_
I think it would be clearer and more readable than Oled.
By the way - a tile is created.Of course, this is still a small fix.
Everything can be assembled from ready elements and modules.
How it will come and act - I will have a pair to give away.
Of course, I'd like to put a 20x4 display .... lol ..
elmaya
What and how do you want to see on the 20x4 Display?
Michal81
I think I wrote the other way around. it was about 4x16 lib 4x20. I think that what is enough for the Oled display, but spread over 4 lines. This display seems to me to be more readable.
For example :
1. CURRENT TEMPERATURE: ----.
2. REQUIRED TEMPERATURE: ----.
3.WORK MODE: MANUAL / AUTOMATIC
4. DEVICE STATUS: On / Off, next to WiFi network status
Illustrative image:
Daro1003
Hello
I built a thermostat based on soft: Supla_Termostst_oled_H_C_0_96_DOUT_16Mbit.bin with display.
Everything works, unfortunately, the display is dead. The displays have two pieces with SCK and SDA markings probably because if I can ask you to generate a bin file for these displays I do not want to throw them in the bin because they will not be useful for anything else.
eradek
Michal81 wrote: Mon Mar 02, 2020 4:14 pm By the way - a tile is created.Of course, this is still a small fix.
Can you share GERBER for the tile?
Post Reply
