Supla universal IR emitter for 8 codes
Post Reply
elmaya
Supla universal IR emitter for 8 codes.
if someone wants to test.
Copy the codes of an existing IR remote control and allow you to send with Supla.
you have to connect an IR receiver to Gpio 14 (D5)
and an IR Led in Gpio 4 (D2) through an NPN transistor (eg BC547) as shown in the diagram.
WiFiConfig starts automatically the first start (subsequently you have to connect Gpio 0 (D3) to ground for at least 10 seconds and then the LED blinks and the module restarts in WiFiConfig mode after a few seconds)
once configured the WiFiConfig will connect to the Supla cloud where we set the channels to monostable (open door, etc.)
then we access the configuration page through the browser with the ip of the ESP8266 or with mDNS.
with IP:
if in WiFiConfig we have selected a port other than 80 we will have to specify it in the url" http://module_ip:port "Eg."http://192.168.1.104:80"
with mDNS:
to access we open in the browser http: // "Supla name" .local: port
where Supla name and port are the ones we have defined in WiFiConfig.
Eg. http: //supla_ir.local: 80
With an IR remote control we press a button (just a moment - the Esp8266 does not like repeated IR codes) the LED turns on for a moment indicating that it has received the IR code.
We update the page in the browser and we will see something like this:
remember to refresh the page after capturing some IR code.
now we can click on Test so that the module emits the code and check that it is fine.
If so, click on STORE
on the STORE page we select the channel "Supla1" to "Supla8" that correspond to the 8 channels in Supla
We can manage the saved codes in the Stored Codes.
do not use Chrome browser (it has the habit of opening several simultaneous connections and it does not work well with this module) windos users must have "Bonjour" installed for mDNS to work.
!! upload in 16Mbit QIO mode !!
IRController_mDNS_QIO_16Mbit.rar
(2.72 MiB) Downloaded 368 times
I confirm, it works as always. checked and tested on tv samsung tv ue50ju6072 and ie 40f5055
Screenshot_20200404-172640_SUPLA .jpg (125.41 KiB) Viewed 11002 times
elmaya
It also allows us to use links to send IR codes to facilitate this,
I added the "SHOW CODE" button that shows us the different possible links for the given IR code.
By copying any of the links to the browser, we send the corresponding IR code.
code link.png (86.18 KiB) Viewed 10960 times
To configure URLs to work with IFTTT, or other automation services where the device's HTML output will never be seen by a human, add "&simple=1" to the end of the URL to simplify submitted data and speed up response time.
Eg. http://192.168.1.114:80/msg?code=E0E030 ... 2&simple=1
(416.57 KiB) Downloaded 288 times
Contact:
Hi,
@elmaya, my TV + SAT set is turned on with one code and turned off with another. Could this be understood by assigning two codes to one channel in Supla?
elmaya
Robert Błaszczak wrote: Mon Apr 06, 2020 6:55 pm Hi,
no, 1 channel 1 code.
in your particular case it would be possible to modify the soft to use a Supla on/off channel to send 1 IR code with on (Supla) and another IR code with off (Supla).
in total it would have 1 on/off channel(light switch) + 6 monostable channels(open door).
in reality this soft is intended for other functions such as controlling the air conditioning or the like.
that's why the IR code copy function, for tv or similar, I think it is better to use html links that have a very simple structure.
Contact:
Use of the first channel on / off (light switch) would be more universal in my opinion. In case the remote control sends one code for on and off, the same code can be assigned twice. :D
Ps.
If I remember correctly, the air conditioning remote control (old Daikin) that I have in the company has two buttons - on and off.
elmaya
for 16 IR codes
All channels can be set as a light switch to contain 2 IR codes (SuplaX_On and SuplaX_Off) or for only 1 as a door opening (SuplaX_On).
IRController_16x_QIO_16Mbit.rar
(394.6 KiB) Downloaded 421 times
uchnast.michal
Software uploaded successful :)
What kind of IR receiver do You use, TSOP31236 - 36 kHz, TSOP4838 - 38kHz, TSOP 4840 - 40kHz is it important?
I have ordered https://allegro.pl/oferta/omega-zone-od ... 7156849865, ordered good?
e-talking............
Byłem tam - Supla Offline Party 2023
elmaya
I use VS1838.
almost all IR remote control use 38Khz
uchnast.michal wrote: Sat Apr 11, 2020 5:27 pm Software uploaded successful :)
I use tsop4838. Work very good
Screenshot_20200411-211243_SUPLA .jpg (143.95 KiB) Viewed 10645 times
Post Reply
