thermostat with Oled display
Michal81
Thank you. My work is on, I look forward to Monday - bin without a window, inverted heating / cooling.
And the peak of happiness would be with hysteresis below the set temperature.
I wish you a nice day.
elmaya
Well, it's Monday. :lol:
without window sensor on Gpio9.
with the two lines edited.
Supla_Termostst_oled_H_C_0_96_DOUT_16Mbit.rar
(275.95 KiB) Downloaded 365 times
Supla_Termostst_oled_H_C_1_3_DOUT_16Mbit.rar
(275.9 KiB) Downloaded 347 times
Michal81
Hi.
Thanks for the files.
I tried to play with the code myself yesterday.
Uploading your code from Arduino - the program says: "WARNING: the SuplaDevice library works on avr architecture (/ architectures) and may not be compatible with the current board that works on esp8266 architecture (/ architectures)."
Either there is nothing in the configuration panels, or there is only a part (e.g. without wifi network), or only wifi networks without other settings.
Question: is there a library missing or is it wrong?
Regards.
Michal81
Libraries :
elmaya
libraries are in the first post.
link
https://en-forum.supla.org/download/file.php?id=7272
The warning is normal.
to come up with Arduino select some size of Flash that has SPIFFS
Michal81
New files BIN. work GREAT
I have libraries from the first post.
I will try to delete and load new libraries again.
Michal81
I changed libraries - it works.
I am full of admiration for the project.
The choice of hot and cooling menus also works great.
Add as much as you can to yesterday's files still adruino files so that you can play with the code yourself and edit.
Michal81
Hello.
Here is the device inserted into the work enclosure.
230V power supply required
In the plans - development of a plate to connect all elements and cut-to-size fittings.
There was a problem - I used such a power supply - 5V, 0.6A.
Connected to the pins: 5V and G on the Wemos board.
After touching the temperature sensor - the ERROR Conimukat appears and the relay switches off. After a while the message disappears, the relay switches on .... in a few seconds again Error ....
When powered by usb - no error occurs.
What could be the reason?
jaros12
Hi,
@elmaya, my version of Nodemcu doesn't work on Gpio9. I changed to RX and it's OK. Earlier I thought that RX did not work because I waited too short for the sensor to change state. A minor inconvenience - changing the software only with the window open ;)
Michal81
Help.
Elmay, can you tell me the reasons for the Error message when converting the USB power supply to the power supply?
Connected as in the picture:
podloczenie zasilacza.jpg (334.29 KiB) Viewed 6368 times
Post Reply
