Supla 3 Way switch esp8266
elmaya
Mon Nov 25, 2019 9:02 pm
Supla 3 Way Switch works as a direct replacement for the last switch in a 3-way circuit.
Allows control from the App, existing switches and the button connected to the device (toggle).
status memory in case of power failure.
Sensor Gpio 5 -- D1
Relay Gpio 4 -- D2
Button Gpio 0 -- D3
stsLed Gpio 2 -- D4
#include <FS.h>       // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>// V.1.6.1
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESPEFC.h>  // modification of ESP8266HTTPUpdateServer that includes erases flash and wifi credentials
#include <Ticker.h>      //for LED status
Ticker ticker;
extern "C"
#include "user_interface.h"
WiFiEventHandler gotIpEventHandler, disconnectedEventHandler;
//#define D0 16  //no internal pullup resistor
//#define D1  5
//#define D2  4
//#define D3  0  //must not be pulled low during power on/reset, toggles value during boot
//#define D4  2  //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15  //must not be pulled high during power on/reset
int relay_1 = 4;   //D2------------------- set relay1 Gpio -----
int button_1 = 0;  //D3------------------- set button1 Gpio ----
int fb_1_pin = 5;  //D1------------------- set fb1 Gpio
#define BTN_COUNT 1
#define status_led 2   //      ----------------------- status Led -----------------------
bool wifi_ok = false;
bool start = true;
bool eep = LOW;
int epr = 0;
int s;
int an;
int buttonValue = 0;
unsigned long eep_milis = 5000;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 5000;               // config delay 5 seconds           ----------        opóźnienie konfiguracji 5 sekund
bool tikOn = false;
WiFiClient client;
ESP8266WebServer httpServer(81);
ESPEFC httpUpdater;
const char* update_path = "/update";
char Supla_server[80];
char Location_id[15];
char Location_Pass[34];
char Supla_name[51];
char up_host[21];
char update_username[21];
char update_password[21];
byte mac[6];
bool initialConfig = false;
int timeout = 180;          // seconds to run the wifi config
void tick(){
  //toggle Led state
  int state = digitalRead(status_led);
  digitalWrite(status_led, !state);
void saveConfigCallback () {                 //callback notifying us of the need to save config
  shouldSaveConfig = true;
 ticker.attach(1.5, tick);
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 80);
  WiFiManagerParameter custom_Location_id("ID", "Location id", Location_id, 15);
  WiFiManagerParameter custom_Location_Pass("Password", "Location Pass", Location_Pass, 34);
  WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
  WiFiManagerParameter custom_update_username("updateUsername", "update username", update_username, 21,"required");
  WiFiManagerParameter custom_update_password("updatePassword", "update password", update_password, 21,"required");
  WiFiManager wifiManager;
  wifiManager.setBreakAfterConfig(true);
  wifiManager.addParameter(&custom_Location_id);
  wifiManager.addParameter(&custom_Location_Pass);
  wifiManager.addParameter(&custom_Supla_name);
  wifiManager.addParameter(&custom_update_username);
  wifiManager.addParameter(&custom_update_password);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  wifiManager.setMinimumSignalQuality(8);
  wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("Supla_3_Way")) {
      Serial.println("Not connected to WiFi but continuing anyway.");
    } else {
      Serial.println("connected...yeey :)");    //if you get here you have connected to the WiFi
    //read updated parameters
    strcpy(Location_id, custom_Location_id.getValue());
    strcpy(Location_Pass, custom_Location_Pass.getValue());
    strcpy(Supla_name, custom_Supla_name.getValue());
    strcpy(update_username, custom_update_username.getValue());
    strcpy(update_password, custom_update_password.getValue());
  WiFi.softAPdisconnect(true);   //  close AP
typedef struct {  //------------------------------------------- BTN ----------------------------------------------------
  int pin;
  int relay_pin;
  int fb_pin;
  int channel;
  char last_val;
  int ms;
  unsigned long last_time;
  bool FB;
  bool fb;
} _btn_t;
_btn_t btn[BTN_COUNT];
void supla_btn_init() {
  for(int a=0;a<BTN_COUNT;a++)
    if (btn[a].pin > 0) {
        pinMode(btn[a].pin-1, INPUT_PULLUP);
        btn[a].last_val = digitalRead(btn[a].pin-1);
        btn[a].last_time = millis();
        pinMode(btn[a].relay_pin-1,OUTPUT);
        pinMode(btn[a].fb_pin, INPUT_PULLUP);
        btn[a].fb = !(digitalRead(btn[a].fb_pin));
void togle_relay(int canal){
             if (digitalRead(btn[canal].relay_pin-1) == LOW){
                digitalWrite(btn[canal].relay_pin-1, HIGH);
              }else{
                digitalWrite(btn[canal].relay_pin-1, LOW);
void supla_timer() {
    for(int z=0;z<BTN_COUNT;z++){
      btn[z].FB = digitalRead(btn[z].fb_pin);
      if (btn[z].FB !=  btn[z].fb){
        SuplaDevice.channelValueChanged(z,!btn[z].FB);
        Serial.print("FB: ");
        Serial.println(btn[z].FB);
        btn[z].fb = btn[z].FB;
void iti_bot(){
  char v;
  unsigned long now = millis(); {
        v = digitalRead(btn[a].pin-1);
        if (v != btn[a].last_val && now - btn[a].last_time ) {
           btn[a].last_val = v;
           btn[a].last_time = now;
           delay(75);
           if (v==0){
              togle_relay(a);
              Serial.println("Boton");
int supla_DigitalRead(int channelNumber, uint8_t pin) {
     return !(btn[channelNumber].fb) ;
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
   if (val != btn[channelNumber].fb) return;
   if (val == btn[channelNumber].fb) {togle_relay(channelNumber);}
  return;
void Eeprom_save() {                  //----------EEPROM write  ---------------------- EEprom
        if (start){
          return;
      for(int e=0;e<BTN_COUNT;e++) {  //  ---check relay except it have delay (staircase)
         if ( btn[e].ms > 0 ) {
                     continue;
         } else {
        eep = (btn[e].fb);                    //  --- read relay state
        if (eep != EEPROM.read(e)){            //  --- compare relay state with memorized state
         EEPROM.write(e,eep);                  //  --- if different write memory
         Serial.print("EEPROM.");
         Serial.print(e);
         Serial.print(" write.");
         Serial.println((eep));
         EEPROM.commit();
void Eepron_read() {                  //----------EEPROM read  ---------------------- EEprom
       if ( btn[epr].ms > 0 ) {
                     return;
         } else {
         eep = EEPROM.read(epr);               //  ---read relay state
         Serial.print(epr);
         Serial.print(" read.");
         Serial.print((eep));
         Serial.print(" channel ");
         Serial.println((btn[epr].channel));
         SuplaDevice.channelValueChanged(epr,!(digitalRead(btn[epr].fb_pin)));
        if (eep != digitalRead(btn[epr].fb_pin)){ togle_relay(epr); }
void status_func(int status, const char *msg) {     //    ------------------------ Status --------------------------
 s=status;                                          //    -- to check if we are registered and ready before restore from memory
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(115200);
  delay(100);
  Serial.println("");
  pinMode(status_led,OUTPUT);
  digitalWrite(status_led, LOW);
  EEPROM.begin(512);
  gotIpEventHandler = WiFi.onStationModeGotIP([](const WiFiEventStationModeGotIP& event){
     Serial.println("");
     Serial.println("CONNECTED");
     Serial.print("local IP: "); Serial.println(WiFi.localIP());
     Serial.print("subnetMask: "); Serial.println(WiFi.subnetMask());
     Serial.print("gatewayIP: "); Serial.println(WiFi.gatewayIP());
     long rssi = WiFi.RSSI(); Serial.print("Signal Strength (RSSI): "); Serial.print(rssi); Serial.println(" dBm");
     wifi_ok = true;
     httpUpdater.setup(&httpServer, update_path, update_username, update_password);
     httpServer.begin();
  disconnectedEventHandler = WiFi.onStationModeDisconnected([](const WiFiEventStationModeDisconnected& event){
    Serial.println("Station disconnected");
    wifi_ok = false;
  if (WiFi.SSID()==""){
    initialConfig = true;
  WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
   uint8_t mac[WL_MAC_ADDR_LENGTH];
   WiFi.macAddress(mac);
   char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
                                 mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
                                 mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
  SuplaDevice.addRelay(101, false);
  memset(btn, 0, sizeof(btn));
  btn[0].pin =button_1 +1;          // pin gpio buton  +1
  btn[0].relay_pin =relay_1 +1;  // pin gpio Relay   +1
  btn[0].fb_pin =fb_1_pin;
  btn[0].channel =0;      // channel
  btn[0].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[0].FB =0;
  btn[0].fb =0;
  supla_btn_init();
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        DynamicJsonBuffer jsonBuffer;
        json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(Location_id, json["Location_id"]);
          strcpy(Location_Pass, json["Location_Pass"]);
          strcpy(Supla_name, json["Supla_name"]);
          strcpy(update_username, json["update_username"]);
          strcpy(update_password, json["update_password"]);
        } else {
          Serial.println("failed to load json config");
  } else {
    Serial.println("failed to mount FS");
  wifi_station_set_hostname(Supla_name);
  SuplaDevice.setDigitalReadFuncImpl(&supla_DigitalRead);
  SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite);
  SuplaDevice.setTimerFuncImpl(&supla_timer);
  SuplaDevice.setStatusFuncImpl(&status_func);
  SuplaDevice.setName(Supla_name);
  int LocationID = atoi(Location_id);
  SuplaDevice.begin(GUID,
                    mac,
                    Supla_server,
                    LocationID,
                    Location_Pass);
  // read_initial_relay_state
    for(int i=0;i<BTN_COUNT;i++){
     if ( (btn[i].ms) > 0 ) {
                     continue;
         } else {
        eep = EEPROM.read(i);
       if (eep >= 2 ){
         EEPROM.write(i,0);
         Serial.println("epp correct");
         EEPROM.commit();
         Serial.print("Recover.");
         Serial.print(i);
         if (eep != digitalRead(btn[i].fb_pin)){
          togle_relay(i);
           Serial.println("restore output");
    start = false;
void loop() {
  iti_bot();
  if (initialConfig){
        EEPROM.write(i, 1);
      EEPROM.commit();
    ondemandwifiCallback () ;
  if (shouldSaveConfig) {
    Serial.println("saving config");
    json["Location_id"] = Location_id;
    json["Location_Pass"] = Location_Pass;
    json["Supla_name"] = Supla_name;
    json["update_username"] = update_username;
    json["update_password"] = update_password;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {Serial.println("failed to open config file for writing");}
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    ticker.detach();
    digitalWrite(status_led, HIGH);
    ESP.restart();
    delay(5000);
  if (millis() > eep_milis){
     Eeprom_save() ;   //        ------------------------------Eepron save callback -----------------------------
     eep_milis = millis() + 5000 ;
  switch (s) {    //    ------------------------------------------------ Status ------------------------------------
  case 17:      // -----     STATUS_REGISTERED_AND_READY
    if (epr<BTN_COUNT){
   Eepron_read() ;                // ------------------------------- Eeprom read callback -------------------------------
   epr = epr+1;// -------- 1 loop for each output  ----------
    break;
   case 10:      // --------------------- REGISTER_IN_PROGRESS  ----------------------
    epr = 0 ;
    break;
  int C_W_read = digitalRead(btn[0].pin-1);{
   if (C_W_read != last_C_W_state) {
     time_last_C_W_change = millis();
   if ((millis() - time_last_C_W_change) > C_W_delay) {
     if (C_W_read != C_W_state) {
       Serial.println("Triger sate changed");
       C_W_state = C_W_read;
       if (C_W_state == LOW) {
   last_C_W_state = C_W_read;
  if (wifi_ok){
     SuplaDevice.iterate();
      delay(50);
      httpServer.handleClient();
// Supla.org ethernet layer
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
          SuplaDeviceCallbacks cb;
          cb.get_temperature = NULL;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
AC line detector:https://learn.edwinrobotics.com/230v110 ... 266-thing/
supla_3_way_DOUT_16Mbit.rar
Compiled firmware
(637.09 KiB) Downloaded 37 times
Luca.supla
Mon Dec 23, 2019 5:49 pm
good evening everyone
interesting project i am trying to download the file without success
Can anyone help me?
elmaya
Mon Dec 23, 2019 7:10 pm
Can anyone help me?
Download is fine.
surely you have an old version of rar, update.
Luca.supla
Mon Dec 23, 2019 8:06 pm
Thanks so much!
Luca.supla
Mon Dec 23, 2019 8:14 pm
Since there are also possible to have the file for arduino ide
elmaya
Mon Dec 23, 2019 8:36 pm
in the future.
I am compiling the codes with the new supla library and until it is completely due to constant changes there will be no code otherwise I will be correcting for someone every day
xmichal88x
Sat Jan 11, 2020 10:16 pm
Hi.
Is it possible to modify the program for 4 channels?
elmaya
Sat Jan 11, 2020 10:22 pm
There are not enough free Gpio for 4.
You can do 2 or even 3 with some limitation.
xmichal88x
Sat Jan 11, 2020 10:38 pm
Could you modify the program for 2 channels?
Can the stsLED only light up during setup?
elmaya
Mon Jan 13, 2020 10:18 pm
I guess you understand the meaning of this that appears in the upper right
Post Reply
