Esp8266 12 touch control relay
elmaya
Esp8266 12 relay 12 touch buttons with memory in case of lack of power and operates without internet connection
esp8266
Gpio 5(D1) -- SCL
Gpio 4(D2) -- SDA
Gpio 2(D4) -- Led (turn on when some sensor is touched)
Mcp23017
in VCC -- +3.3
in Gnd-a0-a1-a2 --GND
SCL -- esp Gpio 5(D1)
SDA -- esp Gpio 4(D2)
Gpio A0 -- Out 1
Gpio A1 -- Out 2
Gpio A2 -- Out 3
Gpio A3 -- Out 4
Gpio A4 -- Out 5
Gpio A5 -- Out 6
Gpio A6 -- Out 7
Gpio A7 -- Out 8
Gpio B0 -- Out 9
Gpio B1 -- Out 10
Gpio B2 -- Out 11
Gpio B3 -- Out 12
Mpr121
in VCC -- +3.3
in Gnd --GND
0-11 -- touch sensor
#include <FS.h>       // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <Adafruit_MCP23017.h>
#include <math.h>
#include <Adafruit_MPR121.h>
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h> //--------- https://github.com/tzapu/WiFiManager/tree/0.14 -------------
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <DoubleResetDetector.h>
extern "C"
#include "user_interface.h"
#define DRD_TIMEOUT 30 // Number of seconds after reset during which a  subseqent reset will be considered a double reset.
#define DRD_ADDRESS 0 // RTC Memory Address for the DoubleResetDetector to use
#define onboard_led 2  //D4 MPR121 active
DoubleResetDetector drd(DRD_TIMEOUT, DRD_ADDRESS);
int uno = 1;
bool pr_wifi = false;
bool start = true;
bool eep = LOW;          //             ---------------- Eeprom ------------------
int epr = 0;             //             ----------- Eepron read loops ------------
int s;                   //             ---------------- Status ------------------
uint8_t an;
int buttonValue = 0;
unsigned long wifi_checkDelay = 60000;  // wifi reconect delay
unsigned long wifimilis;
unsigned long eep_milis;
unsigned long an_milis;
#define BEGIN_PIN 100
#define BTN_COUNT 12
#ifndef _BV
#define _BV(bit) (1 << (bit))
#endif
Adafruit_MCP23017 mcp;
// You can have up to 4 on one i2c bus but one is enough for testing!
Adafruit_MPR121 cap = Adafruit_MPR121();
// Keeps track of the last pins touched
// so we know when buttons are 'released'
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
WiFiClient client;
char Supla_server[40];
char Location_id[15];
char Location_Pass[20];
byte mac[6];
//flag for saving data
bool initialConfig = false;
int timeout           = 120; // seconds to run for wifi config
void saveConfigCallback () {                 //callback notifying us of the need to save config
  shouldSaveConfig = true;
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 40);
  WiFiManagerParameter custom_Location_id("ID", "Location_id", Location_id, 15);
  WiFiManagerParameter custom_Location_Pass("Password", "Location_Pass", Location_Pass, 20);
  WiFiManager wifiManager;
  wifiManager.setBreakAfterConfig(true);
  wifiManager.addParameter(&custom_Location_id);
  wifiManager.addParameter(&custom_Location_Pass);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  wifiManager.setMinimumSignalQuality();
    wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("Supla_MPR121")) {
      Serial.println("Not connected to WiFi but continuing anyway.");
    } else {
      Serial.println("connected...yeey :)");    //if you get here you have connected to the WiFi
    strcpy(Location_id, custom_Location_id.getValue());
    strcpy(Location_Pass, custom_Location_Pass.getValue());
  WiFi.softAPdisconnect(true);   //  close AP
typedef struct {  //------------------------------------------- BTN ----------------------------------------------------
  int pin;
  int relay_pin;
  int channel;
  char last_val;
  int ms;
  unsigned long last_time;
  bool mem;
} _btn_t;
_btn_t btn[BTN_COUNT];
void supla_timer() {
  char v;
  unsigned long now = millis();
  for(int a=0;a<BTN_COUNT;a++)
    if (btn[a].pin > 0) {
        v = digitalRead(btn[a].pin);
        if (v != btn[a].last_val && now - btn[a].last_time ) {
           btn[a].last_val = v;
           btn[a].last_time = now;
           if (v==0)
              if ( btn[a].ms > 0 ) {
                     SuplaDevice.relayOn(btn[a].channel, btn[a].ms);
                     Serial.println(" monostable");
                 } else {
                 if ( (btn[a].mem) == 1 ) {   //   ----------------- == 1 if channel is false... == 0 if channel is true -----------------------
                  SuplaDevice.relayOff(btn[a].channel);
                  Serial.print("BTN Switsh off relay ");
                  Serial.println(btn[a].relay_pin);
                 } else {
                  SuplaDevice.relayOn(btn[a].channel, 0);
                  Serial.print("BTN Switsh on relay ");
void supla_btn_init() {
        pinMode(btn[a].pin, INPUT_PULLUP);
        btn[a].last_val = digitalRead(btn[a].pin);
        btn[a].last_time = millis();
int supla_DigitalRead(int channelNumber, uint8_t pin) {
      if (channelNumber == 0){
        if (btn[0].mem ==0) return 0;
        else return 1;
      if (channelNumber == 1){
        if (btn[1].mem ==0) return 0;
        else return 1;
      if (channelNumber == 2){
        if (btn[2].mem ==0) return 0;
        else return 1;
      if (channelNumber == 3){
        if (btn[3].mem ==0) return 0;
        else return 1;
      if (channelNumber == 4){
        if (btn[4].mem ==0) return 0;
        else return 1;
      if (channelNumber == 5){
        if (btn[5].mem ==0) return 0;
        else return 1;
      if (channelNumber == 6){
        if (btn[6].mem ==0) return 0;
        else return 1;
      if (channelNumber == 7){
        if (btn[7].mem ==0) return 0;
        else return 1;
      if (channelNumber == 8){
        if (btn[8].mem ==0) return 0;
        else return 1;
      if (channelNumber == 9){
        if (btn[9].mem ==0) return 0;
        else return 1;
      if (channelNumber == 10){
        if (btn[10].mem ==0) return 0;
        else return 1;
      if (channelNumber == 11){
        if (btn[11].mem ==0) return 0;
        else return 1;
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {  //------------------------------------------------  Virtual ----------------------------
       btn[0].mem =val;
       mcp.digitalWrite(0, val);
       btn[1].mem =val;
       mcp.digitalWrite(1, val);
       btn[2].mem =val;
       mcp.digitalWrite(2, val);
       btn[3].mem =val;
       mcp.digitalWrite(3, val);
       btn[4].mem =val;
       mcp.digitalWrite(4, val);
       btn[5].mem =val;
       mcp.digitalWrite(5, val);
       btn[6].mem =val;
       mcp.digitalWrite(6, val);
       btn[7].mem =val;
       mcp.digitalWrite(7, val);
       btn[8].mem =val;
       mcp.digitalWrite(8, val);
       btn[9].mem =val;
       mcp.digitalWrite(9, val);
       btn[10].mem =val;
       mcp.digitalWrite(10, val);
       btn[11].mem =val;
       mcp.digitalWrite(11, val);
  return;
void Eeprom_save() {                  //----------EEPROM write  ---------------------- EEprom
        if (start){
          return;
      for(int i=0;i<BTN_COUNT;i++) {  //  ---check relay except it have delay (staircase)
         if ( btn[i].ms > 0 ) {
                     continue;
         } else {
        eep = (btn[i].mem);                    //  --- read relay state
        if (eep != EEPROM.read(i)){            //  --- compare relay state with memorized state
         EEPROM.write(i,eep);                  //  --- if different write memory
         Serial.print("EEPROM.");
         Serial.print(i);
         Serial.print(" write.");
         Serial.print((eep));
         Serial.print(" channel ");
         Serial.println((btn[i].channel));
         EEPROM.commit();
void Eepron_read() {                  //----------EEPROM read  ---------------------- EEprom
        eep = EEPROM.read(epr);               //  ---read relay state
         Serial.print(epr);
         Serial.print(" read.");
         Serial.println((btn[epr].channel));
        if (eep == HIGH){                    //  --- if 1 send relay on
          SuplaDevice.relayOn(epr, 0);       //  --- only one channel in each pass
void status_func(int status, const char *msg) {     //    ------------------------ Status --------------------------
 s=status;                                          //    -- to check if we are registered and ready before restore from memory
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(115200);
  //Wire.begin(0,10);
  EEPROM.begin(512);
  mcp.begin();      // use default address 0
  mcp.pinMode(0, OUTPUT);
  mcp.pinMode(1, OUTPUT);
  mcp.pinMode(2, OUTPUT);
  mcp.pinMode(3, OUTPUT);
  mcp.pinMode(4, OUTPUT);
  mcp.pinMode(5, OUTPUT);
  mcp.pinMode(6, OUTPUT);
  mcp.pinMode(7, OUTPUT);
  mcp.pinMode(8, OUTPUT);
  mcp.pinMode(9, OUTPUT);
  mcp.pinMode(10, OUTPUT);
  mcp.pinMode(11, OUTPUT);
  pinMode(onboard_led, OUTPUT);
  digitalWrite(onboard_led, HIGH);
  if (!cap.begin(0x5A)) {
    Serial.println("MPR121 not found, check wiring?");
    while (1);
  Serial.println("MPR121 found!");
  if (WiFi.SSID()==""){  //Serial.println("We haven't got any access point credentials, so get them now");
    initialConfig = true;
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        DynamicJsonBuffer jsonBuffer;
        //json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(Location_id, json["Location_id"]);
          strcpy(Location_Pass, json["Location_Pass"]);
        } else {
          Serial.println("failed to load json config");
      } else {
        Serial.println("failed to mount FS");
   if (drd.detectDoubleReset()) {
    Serial.println("Double Reset Detected");
    ondemandwifiCallback ();
  } else {
    Serial.println("No Double Reset Detected");
   WiFi.mode(WIFI_STA);
   uint8_t mac[WL_MAC_ADDR_LENGTH];
   WiFi.macAddress(mac);
   char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
                                 mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
                                 mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
  SuplaDevice.addRelay(101, false);
  SuplaDevice.addRelay(102, false);
  SuplaDevice.addRelay(103, false);
  SuplaDevice.addRelay(104, false);
  SuplaDevice.addRelay(105, false);
  SuplaDevice.addRelay(106, false);
  SuplaDevice.addRelay(107, false);
  SuplaDevice.addRelay(108, false);
  SuplaDevice.addRelay(109, false);
  SuplaDevice.addRelay(110, false);
  SuplaDevice.addRelay(111, false);
  SuplaDevice.addRelay(112, false);
  memset(btn, 0, sizeof(btn));
  btn[0].pin =22;          // pin gpio buton  0 = no buton
  btn[0].relay_pin =101;  // pin gpio Relay
  btn[0].channel =0;      // channel
  btn[0].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[0].mem =0;
  btn[1].pin =22;          // pin gpio buton  0 = no buton
  btn[1].relay_pin =102;  // pin gpio Relay
  btn[1].channel =1;      // channel
  btn[1].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[1].mem =0;
  btn[2].pin =22;          // pin gpio buton  0 = no buton
  btn[2].relay_pin =103;  // pin gpio Relay
  btn[2].channel =2;      // channel
  btn[2].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[2].mem =0;
  btn[3].pin =22;         // pin gpio buton  0 = no buton
  btn[3].relay_pin =104;  // pin gpio Relay
  btn[3].channel =3;      // channel
  btn[3].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[3].mem =0;
  btn[4].pin =22;         // pin gpio buton  0 = no buton
  btn[4].relay_pin =105;  // pin gpio Relay
  btn[4].channel =4;      // channel
  btn[4].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[4].mem =0;
  btn[5].pin =22;         // pin gpio buton  0 = no buton
  btn[5].relay_pin =106;  // pin gpio Relay
  btn[5].channel =5;      // channel
  btn[5].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[5].mem =0;
  btn[6].pin =22;         // pin gpio buton  0 = no buton
  btn[6].relay_pin =107;    // pin gpio Relay
  btn[6].channel =6;      // channel
  btn[6].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[6].mem =0;
  btn[7].pin =22;          // pin gpio buton  0 = no buton
  btn[7].relay_pin =108;  // pin gpio Relay
  btn[7].channel =7;      // channel
  btn[7].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[7].mem =0;
  btn[8].pin =22;          // pin gpio buton  0 = no buton
  btn[8].relay_pin =109;  // pin gpio Relay
  btn[8].channel =8;      // channel
  btn[8].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[8].mem =0;
  btn[9].pin =22;          // pin gpio buton  0 = no buton
  btn[9].relay_pin =110;  // pin gpio Relay
  btn[9].channel =9;      // channel
  btn[9].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[9].mem =0;
  btn[10].pin =22;          // pin gpio buton  0 = no buton
  btn[10].relay_pin =111;  // pin gpio Relay
  btn[10].channel =10;      // channel
  btn[10].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[10].mem =0;
  btn[11].pin =22;         // pin gpio buton  0 = no buton
  btn[11].relay_pin =112;  // pin gpio Relay
  btn[11].channel =11;      // channel
  btn[11].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[11].mem =0;
  SuplaDevice.setDigitalReadFuncImpl(&supla_DigitalRead);    //            ------Send Value to server -------
  SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite);   //        -------  Read Value from server   -------
  SuplaDevice.setTimerFuncImpl(&supla_timer);
  SuplaDevice.setStatusFuncImpl(&status_func);    //   ----------------------------- Status -----------------------------
  SuplaDevice.setName("Supla_MPR121");
  int LocationID = atoi(Location_id);
                    Supla_server,      // SUPLA server address
                    LocationID,        // Location ID
                    Location_Pass);    // Location Password
void loop() {
  drd.loop();
  if (start){
    // read_initial_relay_state
    for(int i=0;i<BTN_COUNT;i++){      //  ---check relay except der have delay (staircase)
     if ( (btn[i].ms) > 0 ) {
                     continue;
         } else {
        eep = EEPROM.read(i);               //  ---read relay state
       if (eep > uno ){
         EEPROM.write(i,0);
         Serial.println("epp correct");
         EEPROM.commit();
         Serial.print("Recover.");
         Serial.print(i);
         btn[i].mem =eep;
         mcp.digitalWrite(btn[i].channel, eep);// set single pin
    start = false;
  if (initialConfig){
                     continue;
     } else {
        EEPROM.write(i,0);
    ondemandwifiCallback () ;
  if (shouldSaveConfig) {
    Serial.println("saving config");
    json["Location_id"] = Location_id;
    json["Location_Pass"] = Location_Pass;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    ESP.restart();
    delay(5000);
  if (WiFi.status() != WL_CONNECTED) {
    WiFi_up();
    pr_wifi = true;
  else if ((WiFi.status() == WL_CONNECTED)  && (pr_wifi)){
    Serial.println("");
    Serial.println("CONNECTED");
    Serial.print("local IP: ");
    Serial.print("subnetMask: ");
    Serial.print("gatewayIP: ");
    long rssi = WiFi.RSSI();
    Serial.print("Signal Strength (RSSI): ");
    Serial.print(rssi);
    Serial.println(" dBm");
    pr_wifi = false;
  SuplaDevice.iterate();
  MPR121_switch();
  if (millis() > eep_milis){
     Eeprom_save() ;   //        ------------------------------Eepron save callback -----------------------------
     eep_milis = eep_milis + 5000 ;
  switch (s) {    //    ------------------------------------------------ Status ------------------------------------
    case 17:      // -----     STATUS_REGISTERED_AND_READY
    if (epr<BTN_COUNT){
     Eepron_read() ;                // ------------------------------- Eeprom read callback -------------------------------
     epr = epr+1;                   // -------- 1 loop for each output ----------
    break;
    case 10:      // --------------------- REGISTER_IN_PROGRESS  ----------------------
    epr = 0 ;
    break;
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
       WiFi_up();
          SuplaDeviceCallbacks cb;
          cb.get_temperature = NULL;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
void WiFi_up(){ // conect to wifi
 unsigned long ahora = millis();
  if (ahora >= wifimilis)  {
  Serial.println("CONNECTING WIFI");
  WiFi.begin();
  wifimilis = (millis() + wifi_checkDelay) ;
void MPR121_switch(){
  // Get the currently touched pads
  currtouched = cap.touched();
  yield();
  for (uint8_t i=0; i<12; i++) {
    // it if *is* touched and *wasnt* touched before, alert!
    if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
      Serial.print(i); Serial.println(" touched");
      yield();
      if ((i) == 0 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 1 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 2 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 3 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 4 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 5 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 6 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 7 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 8 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 9 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 10 ){ an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 11 ){ an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
    // if it *was* touched and now *isnt*, alert!
    if (!(currtouched & _BV(i)) && (lasttouched & _BV(i)) ) {
      Serial.print(i); Serial.println(" released");
  // reset our state
  lasttouched = currtouched;
  delay (50);
void MPR121Relay(){
   if ( btn[an].ms > 0 ) {
                     SuplaDevice.relayOn(btn[an].channel, btn[an].ms);
                 } else {
                 if ( (btn[an].mem) == 1 ) {   //   ----------------- == 1 if channel is false... == 0 if channel is true -----------------------
                  SuplaDevice.relayOff(btn[an].channel);
                  Serial.println(btn[an].relay_pin);
                 } else {
                  SuplaDevice.relayOn(btn[an].channel, 0);
             delay (50);
// CFG MODE - SWITCH
To bring the device into configuration mode, in this case press Reset_Button 2 times
When in configuration mode, the device goes into Access Point mode.
In order to enter or change the settings, you need to:
- Sign in at https://cloud.supla.org (registration is free of charge)
- Connect to WiFi called "Supla_MPR121” from any computer with a wireless network card and Internet browser.
- Open access page: http://192.168.4.1
- Enter user name and password to the WiFi through which the device will get Internet access.
- Enter Server address, Location ID and Location Password, which will be provided once you sign in at cloud.supla.org
supla_23017_MRP121_DOUT_16Mbit.rar
compiled firmware
(1.26 MiB) Downloaded 407 times
peterson13
Well done! :idea:
selo
Does not work for me. Can you give arduino sketch file. Thanks.
elmaya
selo wrote: Wed Dec 18, 2019 1:02 am Does not work for me. Can you give arduino sketch file. Thanks.
it works perfectly. :lol:
I use every day, check your connections.
selo
elmaya wrote: Wed Dec 18, 2019 8:00 am it works perfectly. :lol:
Of course it's works perfectly :). I'm making a mistake somewhere.
My wemos d1 goes not to accesspoint mode after i press reset button 2 times, it blinks every 2 seconds. I have tested with other wemos, same problem. I have checked wirings and not see any error. In arduino serial monitor it prints following:
Soft WDT reset
ctx: cont
sp: 3ffffd50 end: 3fffffd0 offset: 01b0
>>>stack>>>
3fffff00:  3fff0c04 0000001f 3fff0c04 40213668
3fffff10:  3fff0c04 3ffefd68 3fff0c04 40213885
3fffff20:  3ffe93c0 3ffefd64 00000000 40213885
3fffff30:  3ffe9274 00000001 3fff0c04 402138b0
3fffff40:  3fff0c04 0000005a 3fff0c04 40213924
3fffff50:  4020912f 3ffefd68 3fff0c04 402091f1
3fffff60:  feefeffe feefeffe feefeffe feefeffe
3fffff70:  feefeffe feefeffe feefeffe feefeffe
3fffff80:  feefeffe feefeffe feefeffe feefeffe
3fffff90:  feefeffe feefeffe feefeffe feefeffe
3fffffa0:  feefeffe feefeffe feefeffe 3fff0cdc
3fffffb0:  3fffdad0 00000000 3fff0cd4 402148f0
3fffffc0:  feefeffe feefeffe 3ffe8650 40100739
<<<stack<<<
 ets Jan  8 2013,rst cause:1, boot mode:(3,7)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
⸮MPR121 not found, check wiring?
Can you help me. Thanks.
elmaya
clearly describes Mpr121 not found.
what model of Mpr121 you are using, maybe an image of the module.
selo
elmaya wrote: Wed Dec 18, 2019 11:52 am clearly describes Mpr121 not found.
This one:
elmaya
ADD connected to ground?
has to be
selo
elmaya wrote: Wed Dec 18, 2019 12:19 pm ADD connected to ground?
has to be
Yes, ADD is with GND 0 Ohm.
Can the wemos go to access point mode without attachting to mpr21 and mcp23017?
elmaya
selo wrote: Wed Dec 18, 2019 3:24 pm
has to be
no
Post Reply
