SOnOff TH10 not booting with Supla. Help!
MilanGajic
Hello everyone,
I'm new to this forum and to Supla ...and I have a little problem.
I've been trying to flash Supla (sonoff_th10_user1.1024.new.2.bin) to my Sonoff th10, but I just can't get it to boot after flashing.
I'm using NodeMCU and the flashing seems to go allright.
When it's done, I unplug the FTDI adapter and connect it to mains (230V).
The TH10 does not boot, no blinking leds, no WiFi AP, button does not work.
If I reflash Tasmota everything works just fine.
Thank you in advance for any help.
Best regards,
Milan
2019-11-13 22_26_34-Clipboard.jpg (148.83 KiB) Viewed 4506 times
lesny8
You used the wrong address for the firmware file and didn't upload the chip initialization file. Follow the readme.txt file.
https://github.com/SUPLA/ESP8266/tree/master/sonoff_th
Edit:
Use FlashDownloadTools
MilanGajic
Ok, thank you lesny8.
I actually just figured it out myself and followed the guide here:
https://www.smartnydom.pl/wgrywanie-fir ... do-sonoff/
Unfortunately still the same issue :(
I tried DOUT and QIL
2019-11-13 22_56_25-NODEMCU FIRMWARE PROGRAMMER.jpg (62.48 KiB) Viewed 4492 times
2019-11-13 22_55_58-Instructies voor het uploaden van Supla naar Sonoff_ stap voor stap - Smart'ny H.jpg
2019-11-13 22_55_58-Instructies voor het uploaden van Supla naar Sonoff_ stap voor stap - Smart'ny H.jpg (53.73 KiB) Viewed 4492 times
2019-11-13 22_56_42-NODEMCU FIRMWARE PROGRAMMER.jpg (52.82 KiB) Viewed 4492 times
lesny8
Upload one more file:
esp_init_data_default.bin---->0xfc000
In the readme.txt file is written:
boot_v1.5.bin -------->0x00000
sonoff_th10_user1.1024.new.2.bin---->0x01000
BAUDRATE: 115200
Flash Size: 1MByte (8Mbit)
Flash speed: 40Mhz
SPI Mode: DIO
Upload all files on these settings.
MilanGajic
@lesny8:
i tried using the flash_download_tools, but got the same results:
2019-11-13 23_23_19-ESP8266 DOWNLOAD TOOL V3.6.6.jpg (99.79 KiB) Viewed 4485 times
reflashed TASMOTA ... still works :?
lesny8
Clean the chip using the Erase button and then upload all three files with the settings as I wrote.
MilanGajic
lesny8 wrote: Wed Nov 13, 2019 10:36 pm Upload one more file:
BAUDRATE: 115200
Flash speed: 40Mhz
SPI Mode: DIO
readme says this:
SUPLA FOR ITEAD SONOFF TH10/16
TH10
TH16
sonoff_th16_user1.1024.new.2.bin---->0x01000
BAUDRATE: 115200
Flash Size: 1MByte
Flash speed: 40Mhz
SPI Mode: QIO
esp_init_data_default.bin is not in the ZIP file ... where do I get it?
can i just use the one from here: https://github.com/SUPLA/ESP8266/tree/master/sonoff
I downloaded from this link (provided on the Supla download page):
https://drive.google.com/file/d/0B3DJSA ... RXSWM/view
And
FLASH SIZE - 8Mbit
MilanGajic wrote: Wed Nov 13, 2019 10:44 pm
BAUDRATE: 115200
Flash speed: 40Mhz
SPI Mode: DIO
Yes
MilanGajic
flashed again ... still nothing :(
2019-11-13 23_51_41-ESP8266 DOWNLOAD TOOL V3.6.6.jpg (100.51 KiB) Viewed 4471 times
Post Reply
Return to “Help”
