Android App
ElCid
I have remove all my post. You asked me to post here for help. You did not help. Then you tried to use these posts to cover the bad rating i gave due to App not working.
Contact:
Officially, we do not support TV boxes.
Here you can find an unofficial version with unlocked landspace mode. (Not all windows work correctly in this mode)
https://drive.google.com/file/d/1PKG0Up ... p=drivesdk
Ethernet - We do not block communication via Ethernet. Please check your router settings if it blocks ports 2016,2015,443. They should not be blocked.
ElCid
Contact:
You must unlock the ability to install applications outside of Google Play. As I mentioned. Supla officially does not support TV. We plan to introduce TV support in the future.
ElCid
Contact:
ElCid
Contact:
Landscape mode still does not work? As I said before. The application does not officially support this mode yet. We do not support (yet) watches and TVs.
ElCid
Contact:
The application does not officially support Landscape mode. (Applies to all devices)
Post Reply
Return to “Help”
