WiFi Connection Change
Post Reply
MS-CST
Fri Mar 08, 2019 8:34 am
Hello,
I got a Question. I´m starting to install the SUPLA Modules in my House. It works pretty good.
But we are going to get a new Internet Connection in the next months. Can i change the Connection ID and Password of each SUPLA Module on PC or did
i need to CONFIG every Module New ? This would take a long long time.
Fri Mar 08, 2019 10:34 am
You can:
A. change each module settings manually (including taking them out of the wall to enable config mode if necessary - but usually you can do it by pressing config button 10 times or keeping it pressed by 5 seconds) or
B. create your new network with the same SSID and password - some routers allow to create virtual networks so you can have one for Supla (ie. hidden SSID) and another for home users
Post Reply
Return to “General discussion”
