Thanks for a great job! You are the best.
Supla Button 4 direct links
is there any possibility for a slightly "lighter" version? I mean the version that could be run on the standard esp8266 eg esp-12f? Does it have to be 32Mb version? I admit that I have thought about such a program for a long time, but I do not understand why to send a small information to the server you need such an extensive program.
the code is there
you can compile in Arduino IDE for the modulo you prefer
Esp12f =4MB (32Mb)
Esp12f =4MB (32Mb)
OK. Thank you for your help when I program My ESP-12f through your * .bin file everything works fine.
Now I have to find out why when programming via My arduino IDE after programming I get an error "ets 8 January 2013, the first reason: 4, the launch mode: (1,6)" in the console.
Thanks again for your program. Now just wait for the official edition of Cloud 2.3.0 to my raspberry. A whole lot of fun
Hi Elmaya
i have an idea to use your software (Supla Button 6 Direct Links) for my own notifications (bulit in IFTTT). To do that, i would need to save IFTTT links in your software (instead of direct links from SUPLA):
Example for my IFTTT link:
https://maker.ifttt.com/trigger/EVENT1/ ... xxxxxxxxxx
where xxxxxxxxxxxxxxxxxxxxxx is my key in IFTTT (22 chars).
I tried to set in your software:
- SERVER NAME : maker.ifttt.com
- LINK1 : /trigger/EVENT1/with/key/xxxxxxxxxxxxxxxxxxxxx
but , there is a problem when i copy/paste string "/trigger/EVENT1/with/key/xxxxxxxxxxxxxxxxxxxxx" to your software becasue length of this string is 45 and it is truncated to 40 chars.
And i have a question : Is it possible to extend fields : LINK1..6 to 60 chars (instead of 40) ? Will it be working with url from IFTTT ? or with public links delivered by fracz for scenes from supla.fracz.com ? If yes , could you prepare (compiled version) of it ?
thx a lot !!
thx a lot !!
@ procekms89 check your Gpio connections.
@ wsosniak
char D_Link_1[60];
WiFiManagerParameter custom_D_Link_1("Link 1", "D_Link_1", D_Link_1, 60);
remember to erase your Esp8266 before flashing new firmware
@ wsosniak
char D_Link_1[60];
I check GPIO and program is running but I have next problem.
"failed to mount FS
Connected
Adres IP:
192.168.8.32 / 255.255.255.0 / 192.168.8.1
(RSSI): -71 dBm
I try clearing flash memory and programing ESP again. And nothing changes.
@ procekms89
which board manager? 2.4.2?
which board?
which board config?
maybe 1M(no SPIFFS)?
which board?
which board config?
I check everything and I found problem with board manager. In directory C:\Users"Your Username"\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266 I have two version this boards. I remove that second board and now is working correct.
