Hello there.
Which domain and IP address must be set in the whitelist?
Thanks in advance. BR, Kucza.
Whitelist settings for Chinese cellphone operator.
Please clarify your question.
Hello.
Communication of the Electric Energy monitor is blocked by the Chinese cellular operator.
We need some data for their whitelist like IP address for ongoing communication, which domain, etc.
BR, Kucza.
MEW01 https://supla.zamel.com/en/product/wi-f ... er-3-ph-n/
BR, Kucza.
MEW connects to our servers using TCP port 2016. IP address may change. You will find the server address in the settings at http://192.168.4.1
Hello pzygmund.pzygmunt wrote: Fri Jun 27, 2025 3:41 pm MEW connects to our servers using TCP port 2016. IP address may change. You will find the server address in the settings at http://192.168.4.1
OK, thank you.
When IP address is changing, then would be best set whole IP address range, and I cannot go to China to check which address should be set in the Whitelist.
Plase, would you tell us whole address range for that?
BR, Oldřich.
There is no such possibility. When migrating servers we do not know what address will be sent to the new machine.
