Home Assistant MQTT Broker Not Working
is it possible to use v-pro dimmers via supla using mqtt? i am already using zigbee2mqtt. will i need to create a bridge? i currently feel confused by that prospect. if you could help id be very grateful
I followed the instructions in the Polish PDF. I was able to get my lights to work by entering the MQTT details directly into the MQTT configuration (Step I in the PDF). But I use Zigbee2MQTT for Zigbee devices already so I think I need to bridge two brokers? I tried step II in the PDF but it doesn't seem to do anything, I can't see any Supla devices anywhere. Could someone help me? THank you
You need to install a local broker to which you connect zigbee devices, and additionally set up a bridge to the mqttX.supla.org broker in it.
What is in the instructions in section II should work for you.
thank you. the pdf instructions worked for me! the issue was that i had translated the pdf into english and that broke some of the code. when i copied the code from the polish pdf, it worked!
Hi,
can you give me the manual in PDF (in Polish)? I want to connect SONOFF Basic R2 with thermometers and so far I can't.
Thanks
Thanks
Hejka, podpinam się z tematem
W czoraj zostałem szczęśliwym posiadaczem HA green.
Mam problem z integracją supli, do brokera mqtt, dane wpisałem tak:
Pośrednik: mqttxx.supla.org
Port: 8883
Nazwa użytkownika: (pobrane z danych brokera mqtt supla)
Hasło: (pobrane z danych brokera mqtt supla)
Cały czas dostaję błąd, poniżej log. Dodatkowo zaznaczam, że cały czas parametry pośrednik, port, nazwa usera i hasło wracają do fabrycznych. Czy możecie pomóc.
Z góry dziękuję.
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2025.2.5",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.13.1",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Warsaw",
"os_name": "Linux",
"os_version": "6.6.73-haos",
"supervisor": "2025.02.1",
"host_os": "Home Assistant OS 14.2",
"docker_version": "27.2.0",
"chassis": "embedded",
"run_as_root": true
"custom_components": {},
"integration_manifest": {
"domain": "mqtt",
"name": "MQTT",
"after_dependencies": [
"hassio"
"codeowners": [
"emontnemery",
"jbouwh",
"bdraco"
"config_flow": true,
"dependencies": [
"file_upload",
"http"
"documentation": "https://www.home-assistant.io/integrations/mqtt",
"iot_class": "local_push",
"quality_scale": "platinum",
"requirements": [
"paho-mqtt==1.6.1"
"single_config_entry": true,
"is_built_in": true,
"overwrites_built_in": false
"setup_times": {
"null": {
"setup": 0.0007139990002542618
"01JMSS53QAHZVHAK3P38NVEE3J": {
"wait_import_packages": -4.94480835000013,
"config_entry_setup": 4.983353792999878
"data": {
"connected": true,
"mqtt_config": {
"data": {
"broker": "core-mosquitto",
"discovery": true,
"password": "**REDACTED**",
"port": 1883,
"username": "**REDACTED**"
"options": {}
"devices": [],
"mqtt_debug_info": {
"entities": [],
"triggers": []
Port: 8883
Z góry dziękuję.
"home_assistant": {
"dev": false,
"hassio": true,
"docker": true,
"arch": "aarch64",
"os_name": "Linux",
"run_as_root": true
"domain": "mqtt",
"name": "MQTT",
"hassio"
"codeowners": [
"emontnemery",
"jbouwh",
"bdraco"
"dependencies": [
"file_upload",
"http"
"requirements": [
"paho-mqtt==1.6.1"
"setup_times": {
"null": {
"data": {
"connected": true,
"mqtt_config": {
"data": {
"discovery": true,
"port": 1883,
"options": {}
"devices": [],
"entities": [],
"triggers": []
