Hello,
I have SMART VALVE PEVEKO assigned to my Supla Cloud account and PEVEKO FLOOD SENSORS. I'm trying to create a push notification via "Reactions" that sends me a notification the moment the valve closes. Another notification when the valve opens. When I press the "Save changes" button in Supla Cloud "Reactions" I get a "Missing trigger field definition" error in both cases.
If I select the trigger "When flooding is detected", I can save it, but then when I test it with my Peveko flood sensors, no notification comes.
If I select the trigger "When the valve is manually closed", this can also be saved and in this case the notification works.
Could you help me please? I need at least a functional notification when an automatic valve closure occurs. Thanks, Jakub
Supla Cloud Reactions
Fixed. Will be out in the next release.
