Using SUPLA with my own created Hardware
scropion86
Hi
i have interest to use SUPLA with my OWN hardware , i build it and already used it and Running for more that month.
mainly is use BLYNK http://www.blynk.cc/ , or MQTT based control.
here is the my board http://egyiot.xyz/pcb-design/egyiot-esp ... iot-board/
Relay 1 - GPIO4
Relay 2 - GPIO13
Relay 3 - GPIO16
LED RGB
RED - GPIO14
Green - GPIO12
Blue - GPIO5
Please guide me how to write the sketch that will work with my board.
Hi. Which functions you need ?
scropion86
3 Relays on/Off and 1 RGB color selector
I will prepare dedicated firmware for you. Do you have some name for your board ?
Which GPIO I can use as cfg button ?
scropion86
thank you so much , My Board called EgyIOT , and i didn't set an Config button , i just have the RESERT and GPIO2 to pulled up with button to boot in Boatloader mode , but i think it can be used as config button after board started .
send me the FW and i will test it , also do you have any tutorial to write my own FW in Arduino IDE or Platformio
scropion86
do you have a Libaray that can be used in Arduino IDE , API documentation to your Cloud , Restfull API ?
Arduino - you can use this: https://github.com/SUPLA/arduino but is not dedicated for support Arduino+ESP8266
API - at this moment API is not avaiable. I plan provide it in the future
You can test now dedicated firmware that I build for you. RGB is not yet implemented. I need more time.
Binary: https://github.com/SUPLA/ESP8266/tree/master/EgyIOT
Sources: https://github.com/SUPLA/supla-core/tre ... SP8266_IOT
scropion86
thanks for your effort , i will test it an let you know.
scropion86
HI
very sorry for my mistake ,
the GPIO2 is puled UP by default and the button is connected to GPIO0 to pull it Down.
the device should go to Config. mode if GPIO0 is Low for 5 second.
because of that the FW didn't work and never go to Config mode.
here is part of my schematic.
scropion86
after flashing the FW , i connected GND to GpIO2 for more than 5 second and still not able to go in Config. mode
Return to “General discussion”
