Varilight disconnecting after 1 day
Contact:
INSERT INTO `esp_update` (`device_id`, `device_name`, `platform`, `latest_software_version`, `fparam1`, `fparam2`, `fparam3`, `fparam4`, `protocols`, `host`, `port`, `path`, `is_synced`) VALUES
(0, 'VARILIGHT V-PRO SMART', 1, '2.8.55', 5, 0, 1, 0, 1, 'updates.supla.org', 80, 'download/vl_dimmer_pic13_2855_user2.2048_DIO.new.5.sdk3x.bin', 0),
(0, 'VARILIGHT V-PRO SMART', 1, '2.8.53', 5, 1, 1, 0, 1, 'updates.supla.org', 80, 'download/vl_dimmer_pic13_2855_user1.2048_DIO.new.5.sdk3x.bin', 0);
ArmElec
pzygmunt wrote: Thu Feb 02, 2023 2:35 pm v2.8.52 does not yet include this fix. We are currently testing the unofficial version 2.8.55, which I can share with you if you send me
your email address of the account.
To update the dimmer, you need switch it to configuration mode by holding the knob min. for 5 sec. Then you need to connect to a WiFi network with a name starting with the phrase "SUPLA". After connecting to wifi, open http://192.168.4.1 and set "Firmware update" to YES. Finally, press the knob.
Hello, I too am facing the same issues - my ‘smart’ dimmer never lasts more than a day or two without needing a power cycle to reconnect.
I have carried out various steps mentioned in this thread, including updating firmware and reducing maximum brightness - nothing helps.
Would you be able to send me the 55 version to try please?
Thank you.
Contact:
I have attached the update to version 2.8.55 for your dimmer. Please update again.
ArmElec
pzygmunt wrote: Thu Feb 16, 2023 7:09 pm I have attached the update to version 2.8.55 for your dimmer. Please update again.
Sorry I’m not entirely sure what you mean? I’ve just checked it again and I’m still on ver .52
Contact:
You need to put the dimmer in configuration mode.
Then connect to its WiFi network.
Go to http://192.168.4.1
Set "Firmware update" to "Yes".
Press "Save"
Exit setup mode
ArmElec
pzygmunt wrote: Thu Feb 16, 2023 10:15 pm You need to put the dimmer in configuration mode.
Press "Save"
Exit setup mode
Thanks, I’ve done that several times but the firmware never changes, it is still on .52
https://ibb.co/TghVcRb
Contact:
It looks like your browser did not refresh the page. From what I can see, the dimmer has been updated to version 2.8.55. You can also check it at cloud.supla.org.
ArmElec
pzygmunt wrote: Fri Feb 17, 2023 9:46 am It looks like your browser did not refresh the page. From what I can see, the dimmer has been updated to version 2.8.55. You can also check it at cloud.supla.org.
Thank you. Yes it appears to now be on .55 via the link you posted, however it has disconnected again. See here - https://ibb.co/VNqXZZN
I’ve even tried swapping to a different Wi-Fi network, that hasn’t helped.
These ‘smart’ dimmers are proving to be more hassle than they’re worth!
Contact:
Go to the dimmer settings from the application and place a screenshot here. From the main window, tap the (i) icon and post a screenshot here.
ArmElec
pzygmunt wrote: Fri Feb 17, 2023 7:13 pm Go to the dimmer settings from the application and place a screenshot here. From the main window, tap the (i) icon and post a screenshot here.
Thank you for your help so far, here’s the screenshots as requested -
Image Image
Post Reply
Return to “Help”
