thermostat with Oled display
MichNick
zzrr wrote: Sun Oct 30, 2022 8:52 pm Hi,
Could you please provide the source code for the same, but with regulation at least 0.5C. Super with 0.1C.
Thank you
Thanks for a good job on this project. In my project I also want to use 0.1C resolution.
zzrr
Hello everyone,
thermostat based on the elmaya project with a setting resolution of 0.1C.
SSD1306Wire display // D3-SDA D4-SCL ----- 0.96 Oled ---
int relay_pin = 5; // D1
int ds_pin = 4; // D2
int button_pin = 14; // D5
#define button2_pin 12 // D6
#define button3_pin 13 // D7
I changed the relay code for my own needs, maybe it will be useful to someone else. Settings every 0.1C and adjustable hysteresis. Controlling the thermostat every 0.1C and added a hysteresis setting in the range from 0 to 10C every 0.1C from the application level. The hysteresis is also visible on the display. There are three physical buttons. One click Auto/Manual, double click turns the relay on or off manually if the thermostat is set to manual. The other two buttons for setting the temperature, when pressed for a long time, change the temperature quickly. Hysteresis set in the application using a switch or dimmer.
For the main part of the code thanks to elmaya.
viewtopic.php?p=141788#p141788
gregor36
Hello, can you make adjustments to the displayed temperature on oled in the version with buttons?
shows 1.5C too much
zzrr
temp correct.png (125.57 KiB) Viewed 1602 times
gregor36
zzrr wrote: Mon Nov 21, 2022 11:00 pm temp correct.png
this changes the display in the app and not on oled
zzrr
gregor36 wrote: Tue Nov 22, 2022 3:15 pm
quote from datasheets:
"...Benefits and Features
• Measures Temperatures from -55°C to +125°C
(-67°F to +257°F)
• ±0.5°C Accuracy from -10°C to +85°C..."
in my opinion your DS18B20 is enclosed in a case and is heated by a microcontroller or power supply or something else.
if it's not closed, it's broken.
However if you want a fix in the code,
find:
class TermostatTemp : public Supla::Sensor::Thermometer
public:
TermostatTemp() {}
void onInit()
channel.setNewValue(getValue());
double getValue()
return ThermostatTemperature;
void iterateAlways()
if (millis() - lastReadTime > 2500)
lastReadTime = millis();
actualTemp = DsTemp->getValue();
change:
actualTemp = DsTemp->getValue() - 1,5;
also on the SUPLA portal
gregor36
I have the sensor on a 15cm cable, I tested 3 sensors and I have the same on each, it is possible that they are of poor quality.
the given example does not match "supla_Termostst_oled_dimm_V04.ino" and this is the software I use.
gregor36
zzrr wrote: Mon Nov 14, 2022 12:13 am Hello everyone,
int relay_pin = 5; // D1 -- 5
int ds_pin = 4; // D2 -- 4
int button_pin = 14; // D5 -- 14
#define button2_pin 12 // D6 -- 12
#define button3_pin 13 // D7 -- 13
#define supla_lib_config_h_ // silences debug messages
#include <LittleFS.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <EEPROM.h>
#include <ESP8266TrueRandom.h>
#include <SuplaDevice.h>
#include <supla/control/virtual_relay.h>
#include <supla/sensor/DS18B20.h>
#include <supla/control/dimmer_base.h>
#define STORAGE_OFFSET 512
#include <supla/storage/eeprom.h>
Supla::Eeprom eeprom(STORAGE_OFFSET);
Supla::ESPWifi wifi("SSID", "PASS"); //------ Do not change----wifimanager takes care------
#include "SSD1306Wire.h"             //----- 0.96 Oled --- https://github.com/ThingPulse/esp8266-oled-ssd1306
SSD1306Wire display(0x3c, 0, 2);     // D3-SDA  D4-SCL ----- 0.96 Oled ---
//#include "SH1106Wire.h"         //----- 1.3 Oled ---
// SH1106Wire display(0x3c, 0, 2); // D3-SDA  D4-SCL ----- 1.3 Oled ---
extern "C"
#include "user_interface.h"
//#define D0 16  //no internal pullup resistor
//#define D1  5
//#define D2  4  //DS18B20
//#define D3  0  //must not be pulled low during power on/reset, toggles value during boot
//#define D4  2  //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15  //must not be pulled high during power on/reset
//#define RX  3  //High at boot
//#define TX  1  //must not be pulled low during power on/reset
int relay_pin1 = 0;    // D0 --
bool relayOnLevel = HIGH; // "HIGH" for active high relay, "LOW" for active low relay.
bool Protected = false;   // if "true" disables the possibility of activating the relay in manual mode.
long C_W_delay = 10000;   // ---------------------- config delay 10 seconds ---------------------------
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
char Supla_server[81] = ("svrXX.supla.org"); //  jeśli nie działa config wpisać
char Email[81] = ("xxx@xx.xx");             //  jeśli nie działa config wpisać
char Supla_name[51] = ("Thermostat");
char term_hist[5] = ("1.0");
char Supla_status[51] = ("No server address");
char Router_SSID[32];  //  jeśli nie działa config uzupełnić       char Router_SSID[32] = "xxxxxxxxxxxx"
char Router_Pass[64];  //  jeśli nie działa config uzupełnić       char Router_Pass[64] = "xxxxxxxxxxxx"
bool initialConfig = false;
bool starting = true;
int s;
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16];
static const char logo[] PROGMEM = "<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>";
double ThermostatTemperature = 20.5;
double actualTemp = -127.0;
double Term_Hist = 1.0;
bool doSaveTermSetTemp = false;
bool WiFiConected = false;
bool dimm = false;
unsigned long TempDisp_mtbs = 5000U;
unsigned long TempDisp_lasttime;
unsigned long dimm_mtbs = 15000U;
unsigned long dimm_lasttime;
WiFiManager wifiManager;
Supla::Control::VirtualRelay *relay_0 = nullptr;
Supla::Sensor::DS18B20 *DsTemp = nullptr;
Supla::Control::RGBWBase *miDimmToTemp_hist = nullptr;
const uint8_t logo32_glcd_bmp[] PROGMEM = // logo supla 32
        0x00, 0x00, 0x00, 0x00, 0xC0, 0x1F, 0x00, 0x00, 0xE0, 0x7F, 0x00, 0x00,
        0xF0, 0x70, 0x00, 0x00, 0x30, 0xE0, 0x00, 0x00, 0x38, 0xC0, 0x00, 0x00,
        0x18, 0xC0, 0x01, 0x00, 0x18, 0xC0, 0x01, 0x00, 0x38, 0xC0, 0x00, 0x00,
        0x38, 0xE0, 0x01, 0x00, 0x70, 0xF0, 0x07, 0x00, 0xE0, 0x7F, 0x0E, 0x00,
        0xC0, 0x3F, 0x38, 0x00, 0x00, 0x1F, 0xE0, 0x0F, 0x00, 0x18, 0xC0, 0x1F,
        0x00, 0x18, 0xC0, 0x30, 0x00, 0x18, 0xC0, 0x30, 0x00, 0x30, 0xC0, 0x30,
        0x00, 0x30, 0x80, 0x1F, 0x00, 0x30, 0xC0, 0x0F, 0x00, 0x20, 0x60, 0x00,
        0x00, 0x60, 0x20, 0x00, 0x00, 0x60, 0x30, 0x00, 0x00, 0x40, 0x18, 0x00,
        0x00, 0xC0, 0x0D, 0x00, 0x00, 0xC0, 0x07, 0x00, 0x00, 0x60, 0x04, 0x00,
        0x00, 0x20, 0x0C, 0x00, 0x00, 0x20, 0x0C, 0x00, 0x00, 0x60, 0x06, 0x00,
        0x00, 0xC0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00};
const uint8_t logo16_wifi_bmp[] PROGMEM = // logo wifi 16
        0x00, 0x00, 0x00, 0x00, 0xE0, 0x07, 0x38, 0x1C, 0xC4, 0x23, 0x72, 0x4E,
        0x08, 0x10, 0xE4, 0x27, 0x10, 0x0C, 0x90, 0x09, 0x40, 0x02, 0x60, 0x06,
        0x40, 0x02, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00};
const uint8_t logo16_supla_bmp[] PROGMEM = // logo supla 16
        0x30, 0x00, 0x7C, 0x00, 0xC4, 0x00, 0x86, 0x00, 0x84, 0x00, 0xDC, 0x03,
        0x78, 0x36, 0x60, 0x78, 0x40, 0x48, 0x40, 0x38, 0x40, 0x04, 0x80, 0x06,
        0x80, 0x03, 0x40, 0x02, 0xC0, 0x03, 0x00, 0x01};
const uint8_t logo_Power_off[] PROGMEM = // Power off
        0xe0,
        0xff,
        0xff,
        0xff,
        0x03,
        0x38,
        0xfc,
        0xff,
        0xff,
        0x0f,
        0x0c,
        0xf0,
        0xff,
        0xff,
        0x3f,
        0x06,
        0xe0,
        0xff,
        0xff,
        0x3f,
        0x02,
        0xc0,
        0xcf,
        0x43,
        0x78,
        0x03,
        0xc0,
        0x33,
        0x43,
        0x78,
        0x01,
        0xc0,
        0x7b,
        0x7b,
        0xff,
        0x01,
        0x80,
        0xfd,
        0x42,
        0xf8,
        0x01,
        0x80,
        0xfd,
        0x42,
        0xf8,
        0x01,
        0x80,
        0x7b,
        0x7b,
        0xff,
        0x03,
        0xc0,
        0x33,
        0x7b,
        0xff,
        0x02,
        0xc0,
        0xcf,
        0x7b,
        0x7f,
        0x06,
        0xe0,
        0xff,
        0xff,
        0x7f,
        0x0c,
        0xf0,
        0xff,
        0xff,
        0x3f,
        0x18,
        0xfc,
        0xff,
        0xff,
        0x1f,
        0xf0,
        0xff,
        0xff,
        0xff,
        0x07,
const uint8_t logo_Power_on[] PROGMEM = // Power on
        0xe0,
        0xff,
        0xff,
        0xff,
        0x07,
        0x38,
        0x00,
        0x00,
        0x30,
        0x0c,
        0x0c,
        0x00,
        0x00,
        0x18,
        0x18,
        0x06,
        0x00,
        0x00,
        0x0c,
        0x30,
        0x02,
        0x0e,
        0x00,
        0x06,
        0x60,
        0x03,
        0x9f,
        0x19,
        0x02,
        0x40,
        0x81,
        0xb1,
        0x1b,
        0x03,
        0xc0,
        0x81,
        0xa0,
        0x1a,
        0x01,
        0x80,
        0x81,
        0xa0,
        0x1e,
        0x01,
        0x80,
        0x81,
        0xb1,
        0x1c,
        0x01,
        0xc0,
        0x03,
        0x9b,
        0x18,
        0x03,
        0x40,
        0x02,
        0x8e,
        0x18,
        0x02,
        0x60,
        0x06,
        0x00,
        0x00,
        0x06,
        0x20,
        0x0c,
        0x00,
        0x00,
        0x0c,
        0x38,
        0x38,
        0x00,
        0x00,
        0x18,
        0x0c,
        0xe0,
        0xff,
        0xff,
        0xff,
        0x07,
const uint8_t hand16_bmp[] PROGMEM = // logo hand 16
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x03, 0x30, 0x02, 0x08, 0x3F,
        0x04, 0x40, 0x04, 0x7C, 0x02, 0x40, 0x02, 0x7C, 0x02, 0x60, 0x04, 0x3C,
        0x18, 0x10, 0xE0, 0x0F, 0x00, 0x00, 0x00, 0x00};
class ManualRelay : public Supla::Control::Relay
public:
  ManualRelay() : Relay(-1, true, 32) {}
  void onInit()
    digitalWrite(relay_pin, !relayOnLevel);
    pinMode(relay_pin, OUTPUT);
  void turnOn(_supla_int_t duration)
    if (!relay_0->isOn() && Protected)
      channel.setNewValue(false);
      Serial.println("*** Protected!! relay will not be activated in manual mode ***");
    else
      digitalWrite(relay_pin, relayOnLevel);
      channel.setNewValue(true);
      Serial.println("*** relay On ***");
  void turnOff(_supla_int_t duration)
    Serial.println("*** relay Off ***");
  bool isOn()
    if (relayOnLevel)
      return digitalRead(relay_pin);
    else
      return !digitalRead(relay_pin);
ManualRelay *relay_1 = nullptr;
class TermostatSet : public Supla::Control::Relay
public:
  TermostatSet() : Relay(-1, true, 32) {}
  void onInit()
    // do nothing here
    ThermostatTemperature += 0.1;
    if (ThermostatTemperature > 100.0)
      ThermostatTemperature = 100.0;
    doSaveTermSetTemp = true;
    ThermostatTemperature -= 0.1;
    if (ThermostatTemperature < 0.0)
      ThermostatTemperature = 0.0;
  bool isOn()
    return false;
TermostatSet *TerSet = nullptr;
public:
  TermostatTemp() {}
  void onInit()
  double getValue()
      if (relay_0->isOn())
        if (((relay_1->isOn()) && (actualTemp >= ThermostatTemperature)) || (actualTemp < -100.0))
          relay_1->turnOff(0);
        else if ((!relay_1->isOn()) && (actualTemp <= (ThermostatTemperature - Term_Hist)))
          relay_1->turnOn(0);
TermostatTemp *TerTemp = nullptr;
class TermostatSet_hist : public Supla::Control::Relay
public:
  TermostatSet_hist() : Relay(-1, true, 32) {}
  void onInit()
    // do nothing here
    Term_Hist += 0.1;
    if (Term_Hist > 10.0)
      Term_Hist = 10.0;
    miDimmToTemp_hist->setRGBW(-1, -1, -1, -1, (Term_Hist * 10));
    Term_Hist -= 0.1;
    if (Term_Hist <= 0.0)
      Term_Hist = 0.0;
  bool isOn()
    return false;
TermostatSet_hist *TerSet_hist = nullptr;
class TermostatTemp_hist : public Supla::Sensor::Thermometer
public:
  TermostatTemp_hist() {}
  void onInit()
  double getValue()
    return Term_Hist;
    Term_Hist = Term_Hist;
TermostatTemp_hist *TerTemp_hist = nullptr;
enum addedActions
  unDimm
class addedActionsClass : public Supla::ActionHandler
public:
  addedActionsClass(){};
  void handleAction(int event, int action)
    if (action == unDimm)
      if (dimm)
        dimm = false;
        dimm_lasttime = millis();
        display.setContrast(200, 241, 64);
      else
addedActionsClass *custAct = new addedActionsClass;
class DimmToTemp_hist : public Supla::Control::DimmerBase
public:
  DimmToTemp_hist() {}
  void setRGBWValueOnDevice(uint32_t red,
                            uint32_t green,
                            uint32_t blue,
                            uint32_t colorBrightness,
                            uint32_t brightness)
    float dimmTemp_hist = map(brightness, 0, 1023, 0, 100);
    Term_Hist = dimmTemp_hist * 0.1;
void saveConfigCallback()
  shouldSaveConfig = true;
void ondemandwifiCallback()
  display.clear();
  display.setTextAlignment(TEXT_ALIGN_CENTER);
  display.setFont(ArialMT_Plain_10);
  display.drawString(64, 16, "wifi config connect");
  display.drawString(64, 28, "to wifi hotspot");
  display.setFont(ArialMT_Plain_16);
  display.drawString(64, 44, "Thermostat");
  display.display();
  wifi.setSsid("");
  wifi.setPassword("");
  wifiManager.setConfigPortalBlocking(true);
  wifiManager.setCleanConnect(true);
  wifiManager.setBreakAfterConfig(true);
  wifiManager.setCustomHeadElement(logo);
  wifiManager.setMinimumSignalQuality(8);
  wifiManager.setConfigPortalTimeout(300);
  std::vector<const char *> menu = {"wifi", "wifinoscan", "sep", "update", "sep", "info", "restart"};
  wifiManager.setMenu(menu);
  wifiManager.setTitle("&#66&#121&#46&#46&#69&#108&#77&#97&#121&#97");
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81, "required");
  WiFiManagerParameter custom_Email("email", "Email", Email, 81, "required");
  WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51, "required");
  WiFiManagerParameter custom_term_hist("histerisis", "Histerisis", term_hist, 5, "required");
  WiFiManagerParameter custom_html_id21("<div><h4> - Supla State -   ");
  WiFiManagerParameter custom_html_id22(Supla_status);
  WiFiManagerParameter custom_html_id23("</h4></div>");
  wifiManager.addParameter(&custom_Email);
  wifiManager.addParameter(&custom_Supla_name);
  wifiManager.addParameter(&custom_term_hist);
  wifiManager.addParameter(&custom_html_id21);
  wifiManager.addParameter(&custom_html_id22);
  wifiManager.addParameter(&custom_html_id23);
  if (!wifiManager.startConfigPortal("Thermostat"))
    Serial.println("Not connected to WiFi but continuing anyway.");
  else
    Serial.println("connected...yeey :)");
  strcpy(Email, custom_Email.getValue());
  strcpy(Supla_name, custom_Supla_name.getValue());
  strcpy(term_hist, custom_term_hist.getValue());
  wifiManager.getWiFiSSID().toCharArray(Router_SSID, 33);
  wifiManager.getWiFiPass().toCharArray(Router_Pass, 65);
  if (strcmp(Supla_server, "get_new_guid_and_authkey") == 0)
    Serial.println("new guid & authkey.");
    EEPROM.write(300, 0);
    EEPROM.commit();
    delay(100);
    ESP.reset();
  if (shouldSaveConfig)
    DynamicJsonDocument json(1024);
    json["Email"] = Email;
    json["Supla_name"] = Supla_name;
    json["term_hist"] = term_hist;
    json["Router_SSID"] = Router_SSID;
    json["Router_Pass"] = Router_Pass;
    File configFile = LittleFS.open("/config.json", "w");
    if (!configFile)
      Serial.println("failed to open config file for writing");
    serializeJsonPretty(json, Serial);
    serializeJson(json, configFile);
    configFile.close();
    WiFi.mode(WIFI_STA);
    delay(5000);
    ESP.restart();
  WiFi.softAPdisconnect(true); //  close AP
  if (initialConfig == true)
    delay(5000);
    ESP.restart();
void status_func(int status, const char *msg)
{ //    ------------------------ Status --------------------------
  if (s != status)
    s = status;
    if (s != 10)
      strcpy(Supla_status, msg);
void TH_Overlay()
  display.clear();
  if (actualTemp > -100)
    // display.setFont(Arimo_Bold_32);
    display.setFont(ArialMT_Plain_24);
    display.drawString(64, 19, String(actualTemp, 1) + "ºC");
  else
    display.drawString(64, 19, "-----");
    display.drawString(38, 48, "T " + String(ThermostatTemperature, 1) + "ºC");
    display.drawString(61, 0, "Auto");
  else
    display.drawXbm(52, 0, 16, 16, hand16_bmp);
  if (TerSet_hist->isOn())
    display.drawString(105, 48, "H " + String(Term_Hist, 1) + "ºC");
    // display.drawString(61, 0, "Auto");
  else
    // display.drawXbm(52, 0, 16, 16, hand16_bmp);
  if (WiFiConected)
    display.drawXbm(1, 0, 16, 16, logo16_wifi_bmp); // -------------------------------------------------- oled wifi ok  --------
    if (s == STATUS_REGISTERED_AND_READY)
      display.drawXbm(22, 0, 16, 16, logo16_supla_bmp); // ------------------------------------------------ oled supla ok --------
    else if (s != 10)
      display.drawString(30, 0, String(s));
  if (relay_1->isOn())
    display.drawXbm(86, 0, 40, 16, logo_Power_on); // -------------------------------------------------- Relay on  ---------
  else
    display.drawXbm(86, 0, 40, 16, logo_Power_off); // ------------------------------------------------- Relay off  --------
  display.display();
  TempDisp_lasttime = millis();
void guid_authkey(void)
  if (EEPROM.read(300) != 60)
    int eep_gui = 301;
    ESP8266TrueRandom.uuid(uuidNumber);
    String uuidString = "";
    for (int i = 0; i < 16; i++)
      int topDigit = uuidNumber[i] >> 4;
      int bottomDigit = uuidNumber[i] & 0x0f;
      uuidString += "0123456789abcdef"[topDigit];
      uuidString += "0123456789abcdef"[bottomDigit];
    int length_uuid = uuidString.length();
    for (int i = 0; i < length_uuid; ++i)
      EEPROM.put(eep_gui + i, uuidString[i]);
    int eep_aut = 341;
    String uuidString2 = "";
      uuidString2 += "0123456789abcdef"[topDigit];
      uuidString2 += "0123456789abcdef"[bottomDigit];
    int length_uuid2 = uuidString2.length();
    for (int i = 0; i < length_uuid2; ++i)
      EEPROM.put(eep_aut + i, uuidString2[i]);
    EEPROM.write(300, 60);
    EEPROM.commit();
    delay(0);
  read_guid();
  read_authkey();
String read_guid(void)
  String read_eeprom = "";
  int i, ii = 0;
  int eep_star = 301;
  int end_guid = eep_star + SUPLA_GUID_SIZE;
  String temp_read = "0x";
  for (i = eep_star; i < end_guid + 16; i = i + 1)
    temp_read += char(EEPROM.read(i));
    read_eeprom += char(EEPROM.read(i));
    if ((i % 2) == 0)
      char *_guid = strcpy((char *)malloc(temp_read.length() + 1), temp_read.c_str());
      GUID[ii] = strtoul(_guid, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
String read_authkey(void)
  int i, ii = 0;
  int eep_star = 341;
  int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
  for (i = eep_star; i < end_authkey + 16; i = i + 1)
    if ((i % 2) == 0)
      char *_authkey = strcpy((char *)malloc(temp_read.length() + 1), temp_read.c_str());
      AUTHKEY[ii] = strtoul(_authkey, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
void setup()
  wifi_set_sleep_type(NONE_SLEEP_T);
  pinMode(button_pin, INPUT_PULLUP);
  Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY, 1);
  display.init();
  display.flipScreenVertically();
  display.clear();
  display.drawString(42, 6, "Supla");
  display.drawString(33, 40, "Thermostat");
  display.drawXbm(0, 16, 32, 32, logo32_glcd_bmp);
  display.display();
  delay(10);
  EEPROM.begin(1024);
    initialConfig = true;
  guid_authkey();
  if (LittleFS.begin())
  { // ------------------------- wificonfig read -----------------
    if (LittleFS.exists("/config.json"))
      File configFile = LittleFS.open("/config.json", "r");
      if (configFile)
        DeserializationError deserializeError = deserializeJson(json, configFile);
        if (!deserializeError)
          Serial.println("\nparsed json");
          if (json.containsKey("Supla_server"))
          if (json.containsKey("Email"))
            strcpy(Email, json["Email"]);
          if (json.containsKey("Supla_name"))
            strcpy(Supla_name, json["Supla_name"]);
          if (json.containsKey("term_hist"))
            strcpy(term_hist, json["term_hist"]);
            Term_Hist = (String(term_hist).toFloat());
            if (Term_Hist < 0.1)
              Term_Hist = 0.1;
            else if (Term_Hist > 10.0)
              Term_Hist = 10.0;
          if (json.containsKey("Router_SSID"))
            strcpy(Router_SSID, json["Router_SSID"]);
          if (json.containsKey("Router_Pass"))
            strcpy(Router_Pass, json["Router_Pass"]);
        else
        configFile.close();
  else
    Serial.println("failed to mount FS");
  Serial.print("Term_Hist: ");
  Serial.println(Term_Hist);
  wifi_station_set_hostname(Supla_name);
    ondemandwifiCallback();
  TerSet_hist = new TermostatSet_hist();
  TerSet_hist->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  TerSet_hist->disableChannelState();
  TerTemp_hist = new TermostatTemp_hist();
  TerTemp_hist->disableChannelState();
  EEPROM.get(381, ThermostatTemperature);
  if ((ThermostatTemperature > 125.0) || isnan(ThermostatTemperature))
    ThermostatTemperature = 20.0;
    EEPROM.put(381, ThermostatTemperature);
    EEPROM.commit();
  relay_0 = new Supla::Control::VirtualRelay(32);
  relay_0->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  relay_0->setDefaultStateRestore();
  relay_0->disableChannelState();
  relay_1 = new ManualRelay();
  relay_1->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  relay_1->setDefaultStateOff();
  relay_1->disableChannelState();
  DsTemp = new Supla::Sensor::DS18B20(ds_pin);
  TerTemp = new TermostatTemp();
  TerTemp->disableChannelState();
  TerSet = new TermostatSet();
  TerSet->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  TerSet->disableChannelState();
  auto button_1 = new Supla::Control::Button(button_pin, true, true);
  button_1->setMulticlickTime(800, false);
  button_1->addAction(Supla::TOGGLE, relay_0, Supla::ON_CLICK_1);
  if (!Protected)
    button_1->addAction(Supla::TOGGLE, relay_1, Supla::ON_CLICK_2);
  button_1->addAction(unDimm, custAct, Supla::ON_PRESS);
  relay_0->addAction(Supla::TURN_OFF, relay_1, Supla::ON_TURN_OFF);
  miDimmToTemp_hist = new DimmToTemp_hist();
  miDimmToTemp_hist->disableChannelState();
  auto button_2 = new Supla::Control::Button(button2_pin, true, true);
  auto button_3 = new Supla::Control::Button(button3_pin, true, true);
  button_2->setHoldTime(500);
  button_3->setHoldTime(500);
  button_2->repeatOnHoldEvery(30);
  button_3->repeatOnHoldEvery(30);
  button_2->addAction(unDimm, custAct, Supla::ON_PRESS);
  button_3->addAction(unDimm, custAct, Supla::ON_PRESS);
  button_2->addAction(Supla::TURN_ON, TerSet, Supla::ON_PRESS);
  button_3->addAction(Supla::TURN_OFF, TerSet, Supla::ON_PRESS);
  button_2->addAction(Supla::TURN_ON, TerSet, Supla::ON_HOLD);
  button_3->addAction(Supla::TURN_OFF, TerSet, Supla::ON_HOLD);
  SuplaDevice.setName(Supla_name);
  wifi.setSsid(Router_SSID);
  wifi.setPassword(Router_Pass);
  SuplaDevice.setStatusFuncImpl(&status_func);
  wifi.enableSSL(false);
  SuplaDevice.begin(GUID, Supla_server, Email, AUTHKEY);
void loop()
  int C_W_read = digitalRead(button_pin);
    if (C_W_read != last_C_W_state)
      time_last_C_W_change = millis();
    if ((millis() - time_last_C_W_change) > C_W_delay)
      if (C_W_read != C_W_state)
        C_W_state = C_W_read;
        if (C_W_state == LOW)
    last_C_W_state = C_W_read;
  SuplaDevice.iterate();
  delay(5);
  if (doSaveTermSetTemp)
    EEPROM.commit();
  if ((millis() - TempDisp_lasttime) > TempDisp_mtbs)
    WiFiConected = (WiFi.status() == WL_CONNECTED);
    TempDisp_mtbs = 500;
    TH_Overlay();
  if ((millis() - dimm_lasttime) > dimm_mtbs)
    if (dimm == false)
      display.setContrast(50, 50, 30);
      display.display();
      dimm = true;
fatal error: LittleFS.h: No such file or directory
zzrr
I also had a problem with libraries. For me, the LittleFS library works as in the attachment.
LittleFS.rar
(192.26 KiB) Downloaded 107 times
gregor36
zzrr wrote: Sat Nov 26, 2022 1:47 pm I also had a problem with libraries. For me, the LittleFS library works as in the attachment.
/Documents/Arduino/libraries/LittleFS/src/LittleFS.h:34:25: fatal error: flash_utils.h: No such file or directory
compilation terminated.
Post Reply
