thermostat with Oled display
elmaya
eradek wrote: Sun Apr 03, 2022 12:13 pm Hi Elmaya,
I am using your thermostat in couple of devices. Is there a chance for upgraded code for the old version without rotary encoder?
there is something. :D
temperature from 0º to 100º in steps of 1ºC.
additional relay (Gpio 4 "D2").
3 buttons for local control.
The additional relay allows configuration as a power switch, light switch or stairs timer.
The buttons have the following functions.
Gpio 12 "D6":
ON_CLICK_1 = toggle Auto/Manual mode,
ON_CLICK_2 = toggle manual On/Off,
ON_HOLD 1 second = toggle relay 2,
ON_HOLD 10 seconds = WiFiConfig.
Gpio 14 "D5":
ON_CLICK_1 = increases the desired temperature "preset" by 1ºC,
ON_HOLD = increases successively in steps of 1ºC.
Gpio 13 "D7":
ON_CLICK_1 = decreases the desired temperature "preset" by 1ºC,
ON_HOLD = decreases successively in steps of 1ºC.
Gpio 3 "RX" = DS18B20.
Gpio 5 "D1" = thermostat relay.
Gpio 4 "D2" = additional relay.
Gpio 0 "D3" = SDA "oled".
Gpio 2 "D4" = SCL "oled".
Gpio 14 "D5" = pushbutton temp +.
Gpio 12 "D6" = mode button.
Gpio 13 "D7" = pushbutton temp -.
Gpio 15 "D8" = Led auto/man mode, connected to GND through resistor "optional".
Gpio 16 "D0" = stateLed, connected to +3.3v through resistor "optional".
#define supla_lib_config_h_  // silences debug messages
#include "LittleFS.h"
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <EEPROM.h>
#include <ESP8266TrueRandom.h>
#include <SuplaDevice.h>              //  Supla device 2.4.1
#include <supla/sensor/DS18B20.h>
#include <supla/control/dimmer_base.h>
#include <supla/device/status_led.h>
#define STORAGE_OFFSET 512
#include <supla/storage/eeprom.h>
Supla::Eeprom eeprom(STORAGE_OFFSET);
Supla::ESPWifi wifi("SSID", "PASS");  //------ Do not change----wifimanager takes care------
#include "SSD1306Wire.h" //----- 0.96 Oled --- https://github.com/ThingPulse/esp8266-oled-ssd1306
SSD1306Wire  display(0x3c, 0, 2);  // D3-SDA  D4-SCL ----- 0.96 Oled ---
//#include "SH1106Wire.h" //----- 1.3 Oled ---
//SH1106Wire display(0x3c, 0, 2);  // D3-SDA  D4-SCL ----- 1.3 Oled ---
extern "C"
#include "user_interface.h"
//#define D0 16  //no internal pullup resistor
//#define D1  5
//#define D2  4
//#define D3  0  //must not be pulled low during power on/reset, toggles value during boot
//#define D4  2  //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15  //must not be pulled high during power on/reset
//#define RX  3  //High at boot
//#define TX  1  //must not be pulled low during power on/reset
int ds_pin = 3;          //RX --  3
int relay_pin = 5;       //D1 --  5
int relay2_pin = 4;      //D2 --  4
int button_pin = 12;     //D6 --  12
#define button2_pin 14   //D5 --  14
#define button3_pin 13   //D7 --  13
#define autoManLed  15   //D8 --  15
#define stateLed    16   //D0 --  16
bool relayOnLevel = HIGH; // "HIGH" for active high relay, "LOW" for active low relay.
bool Protected = false;   // if "true" disables the possibility of activating the relay in manual mode.
long C_W_delay = 10000;   // ---------------------- config delay 10 seconds ---------------------------
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
char Supla_server[81] = ("svr?.supla.org");
char Email[81] = ("your@email");
char Supla_name[51] = ("Thermostat");
char term_hist[5] = ("1.0");
char Supla_status[51] = ("No server address");
char Router_SSID[32];
char Router_Pass[64];
bool initialConfig = false;
bool starting = true;
int s;
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16];
const char logo[] PROGMEM = "<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>";
double ThermostatTemperature = 20.0;
double actualTemp = -127.0;
float Term_Hist = 1.0;
int TempDisp_mtbs = 5000;
unsigned long TempDisp_lasttime;
int dimm_mtbs = 15000;
unsigned long dimm_lasttime;
bool WiFiConected = false;
bool dimm = false;
bool updateOled = false;
WiFiManager wifiManager;
Supla::Control::Relay *relay_0 = nullptr;
Supla::Control::Relay *relay_2 = nullptr;
Supla::Sensor::DS18B20 *DsTemp = nullptr;
Supla::Control::RGBWBase *miDimmToTemp = nullptr;
Supla::Device::StatusLed *LedS = nullptr;
const uint8_t logo32_glcd_bmp[] PROGMEM =  //logo supla 32
  0x00, 0x00, 0x00, 0x00, 0xC0, 0x1F, 0x00, 0x00, 0xE0, 0x7F, 0x00, 0x00,
  0xF0, 0x70, 0x00, 0x00, 0x30, 0xE0, 0x00, 0x00, 0x38, 0xC0, 0x00, 0x00,
  0x18, 0xC0, 0x01, 0x00, 0x18, 0xC0, 0x01, 0x00, 0x38, 0xC0, 0x00, 0x00,
  0x38, 0xE0, 0x01, 0x00, 0x70, 0xF0, 0x07, 0x00, 0xE0, 0x7F, 0x0E, 0x00,
  0xC0, 0x3F, 0x38, 0x00, 0x00, 0x1F, 0xE0, 0x0F, 0x00, 0x18, 0xC0, 0x1F,
  0x00, 0x18, 0xC0, 0x30, 0x00, 0x18, 0xC0, 0x30, 0x00, 0x30, 0xC0, 0x30,
  0x00, 0x30, 0x80, 0x1F, 0x00, 0x30, 0xC0, 0x0F, 0x00, 0x20, 0x60, 0x00,
  0x00, 0x60, 0x20, 0x00, 0x00, 0x60, 0x30, 0x00, 0x00, 0x40, 0x18, 0x00,
  0x00, 0xC0, 0x0D, 0x00, 0x00, 0xC0, 0x07, 0x00, 0x00, 0x60, 0x04, 0x00,
  0x00, 0x20, 0x0C, 0x00, 0x00, 0x20, 0x0C, 0x00, 0x00, 0x60, 0x06, 0x00,
  0x00, 0xC0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00
const uint8_t logo16_wifi_bmp[] PROGMEM =  //logo wifi 16
  0x00, 0x00, 0x00, 0x00, 0xE0, 0x07, 0x38, 0x1C, 0xC4, 0x23, 0x72, 0x4E,
  0x08, 0x10, 0xE4, 0x27, 0x10, 0x0C, 0x90, 0x09, 0x40, 0x02, 0x60, 0x06,
  0x40, 0x02, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00
const uint8_t logo16_wifi_off_bmp[] PROGMEM =  //logo wifi off 16
  0x01, 0x80, 0x02, 0x40, 0xE4, 0x27, 0x38, 0x1C, 0xD4, 0x6B, 0x73, 0xCE,
  0xD9, 0x93, 0xE4, 0x27, 0xB0, 0x0D, 0xD8, 0x1B, 0x60, 0x06, 0x70, 0x0E,
  0x48, 0x12, 0x84, 0x21, 0x02, 0x40, 0x01, 0x80
const uint8_t logo16_supla_bmp[] PROGMEM =  //logo supla 16
  0x30, 0x00, 0x7C, 0x00, 0xC4, 0x00, 0x86, 0x00, 0x84, 0x00, 0xDC, 0x03,
  0x78, 0x36, 0x60, 0x78, 0x40, 0x48, 0x40, 0x38, 0x40, 0x04, 0x80, 0x06,
  0x80, 0x03, 0x40, 0x02, 0xC0, 0x03, 0x00, 0x01
const uint8_t logo_Power_off[] PROGMEM =  //Power off
  0xe0, 0xff, 0xff, 0xff, 0x03, 0x38, 0xfc, 0xff, 0xff, 0x0f, 0x0c, 0xf0,
  0xff, 0xff, 0x3f, 0x06, 0xe0, 0xff, 0xff, 0x3f, 0x02, 0xc0, 0xcf, 0x43,
  0x78, 0x03, 0xc0, 0x33, 0x43, 0x78, 0x01, 0xc0, 0x7b, 0x7b, 0xff, 0x01,
  0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0x7b,
  0x7b, 0xff, 0x03, 0xc0, 0x33, 0x7b, 0xff, 0x02, 0xc0, 0xcf, 0x7b, 0x7f,
  0x06, 0xe0, 0xff, 0xff, 0x7f, 0x0c, 0xf0, 0xff, 0xff, 0x3f, 0x18, 0xfc,
  0xff, 0xff, 0x1f, 0xf0, 0xff, 0xff, 0xff, 0x07,
const uint8_t logo_Power_on[] PROGMEM =  //Power on
  0xe0, 0xff, 0xff, 0xff, 0x07, 0x38, 0x00, 0x00, 0x30, 0x0c, 0x0c, 0x00,
  0x00, 0x18, 0x18, 0x06, 0x00, 0x00, 0x0c, 0x30, 0x02, 0x0e, 0x00, 0x06,
  0x60, 0x03, 0x9f, 0x19, 0x02, 0x40, 0x81, 0xb1, 0x1b, 0x03, 0xc0, 0x81,
  0xa0, 0x1a, 0x01, 0x80, 0x81, 0xa0, 0x1e, 0x01, 0x80, 0x81, 0xb1, 0x1c,
  0x01, 0xc0, 0x03, 0x9b, 0x18, 0x03, 0x40, 0x02, 0x8e, 0x18, 0x02, 0x60,
  0x06, 0x00, 0x00, 0x06, 0x20, 0x0c, 0x00, 0x00, 0x0c, 0x38, 0x38, 0x00,
  0x00, 0x18, 0x0c, 0xe0, 0xff, 0xff, 0xff, 0x07,
const uint8_t hand16_bmp[] PROGMEM =  //logo hand 16
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x03, 0x30, 0x02, 0x08, 0x3F,
  0x04, 0x40, 0x04, 0x7C, 0x02, 0x40, 0x02, 0x7C, 0x02, 0x60, 0x04, 0x3C,
  0x18, 0x10, 0xE0, 0x0F, 0x00, 0x00, 0x00, 0x00
const uint8_t logo16_2_on[] PROGMEM =  //logo 2 on 16
  0x00, 0x00, 0xE0, 0x07, 0xE0, 0x07, 0x18, 0x18, 0x00, 0x18, 0x00, 0x18,
  0x00, 0x18, 0x00, 0x06, 0x00, 0x06, 0x80, 0x01, 0x60, 0x00, 0x60, 0x00,
  0x18, 0x00, 0xF8, 0x1F, 0xF8, 0x1F, 0x00, 0x00
const uint8_t logo16_2_off[] PROGMEM =  //logo 2 off 16
  0x01, 0x80, 0xE2, 0x47, 0xE4, 0x27, 0x18, 0x18, 0x10, 0x18, 0x20, 0x1C,
  0x40, 0x1A, 0x80, 0x07, 0x80, 0x07, 0xC0, 0x03, 0x60, 0x04, 0x70, 0x08,
  0x18, 0x10, 0xFC, 0x3F, 0xFA, 0x5F, 0x01, 0x80
class ManualRelay : public Supla::Control::Relay {
  public:
    ManualRelay() : Relay(-1, true, 32) {}
    void onInit() {
      digitalWrite(relay_pin, !relayOnLevel);
      pinMode(relay_pin, OUTPUT);
    void turnOn(_supla_int_t duration) {
      if (!relay_0->isOn() && Protected) {
        channel.setNewValue(false);
        Serial.println("*** Protected!! relay will not be activated in manual mode ***");
      } else {
        digitalWrite(relay_pin, relayOnLevel);
        channel.setNewValue(true);
        Serial.println("*** relay On ***");
    void turnOff(_supla_int_t duration) {
      Serial.println("*** relay Off ***");
    bool isOn() {
      if (relayOnLevel) {
        return digitalRead(relay_pin);
      } else {
        return !digitalRead(relay_pin);
}; ManualRelay *relay_1 = nullptr;
class TermostatTemp : public Supla::Sensor::Thermometer {
  public:
    TermostatTemp() {}
    void onInit() {
      channel.setNewValue(getValue() );
    double getValue() {
      return ThermostatTemperature;
    void iterateAlways() {
      if ( millis() - lastReadTime > 2500) {
        lastReadTime = millis();
        actualTemp = DsTemp->getValue();
        if (relay_0->isOn()) {
          if (((relay_1->isOn()) && ( actualTemp >= ThermostatTemperature)) || ( actualTemp < -100.0)) {
            relay_1->turnOff(0);
          } else if ((!relay_1->isOn()) && ( actualTemp <= (ThermostatTemperature - Term_Hist))) {
            relay_1->turnOn(0);
}; TermostatTemp *TerTemp = nullptr;
class TermostatSet : public Supla::Control::Relay {
  public:
    TermostatSet() : Relay(-1, true, 32) {}
    void onInit() {
      // do nothing here
      ThermostatTemperature += 1.0;
      if (ThermostatTemperature > 100.0) ThermostatTemperature = 100.0;
      miDimmToTemp->setRGBW(-1, -1, -1, -1, (ThermostatTemperature));
      updateOled = true;
      ThermostatTemperature -= 1.0;
      if (ThermostatTemperature < 0.0) ThermostatTemperature = 0.0;
      updateOled = true;
    bool isOn() {
      return false;
}; TermostatSet *TerSet = nullptr;
enum addedActions {unDimm};
class addedActionsClass : public Supla::ActionHandler {
  public: addedActionsClass() {};
    void handleAction(int event, int action) {
      if (action == unDimm) {
        if (dimm) {
          dimm = false ;
          dimm_lasttime = millis();
          display.setContrast(200, 241, 64);
        } else {
addedActionsClass *custAct = new addedActionsClass;
class DimmToTemp : public Supla::Control::DimmerBase {
  public:
    DimmToTemp() { }
    void setRGBWValueOnDevice(uint32_t red,
                              uint32_t green,
                              uint32_t blue,
                              uint32_t colorBrightness,
                              uint32_t brightness) {
      float dimmTemp = map(brightness, 0, 1023, 0, 100);
      ThermostatTemperature = dimmTemp;
void saveConfigCallback () {
  shouldSaveConfig = true;
  // Enables custom LED sequence based on given durations.
  // Automatic sequence change will be disabled.
  // (1000, 0) = LED ON.
  LedS->setCustomSequence(1000, 0); // void setCustomSequence(int onDurationMs, int offDurationMs);
  display.clear();
  display.setTextAlignment(TEXT_ALIGN_CENTER);
  display.setFont(ArialMT_Plain_10);
  display.drawString(64, 16, "wifi config connect");
  display.drawString(64, 28, "to wifi hotspot");
  display.setFont(ArialMT_Plain_16);
  display.drawString(64, 44, "Thermostat");
  display.display();
  wifi.setSsid("");
  wifi.setPassword("");
  wifiManager.setConfigPortalBlocking(true);
  wifiManager.setCleanConnect(true);
  wifiManager.setBreakAfterConfig(true);
  wifiManager.setCustomHeadElement(logo);
  wifiManager.setMinimumSignalQuality(8);
  wifiManager.setConfigPortalTimeout(300);
  std::vector<const char *> menu = {"wifi", "wifinoscan", "sep", "update", "sep", "info", "restart"};
  wifiManager.setMenu(menu);
  wifiManager.setTitle("&#66&#121&#46&#46&#69&#108&#77&#97&#121&#97");
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81, "required");
  WiFiManagerParameter custom_Email("email", "Email", Email, 81, "required");
  WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51, "required");
  WiFiManagerParameter custom_term_hist("histerisis", "Histerisis", term_hist, 5, "required");
  WiFiManagerParameter custom_html_id21("<div><h4> - Supla State -   ");
  WiFiManagerParameter custom_html_id22(Supla_status);
  WiFiManagerParameter custom_html_id23("</h4></div>");
  wifiManager.addParameter(&custom_Email);
  wifiManager.addParameter(&custom_Supla_name);
  wifiManager.addParameter(&custom_term_hist);
  wifiManager.addParameter(&custom_html_id21);
  wifiManager.addParameter(&custom_html_id22);
  wifiManager.addParameter(&custom_html_id23);
  if (!wifiManager.startConfigPortal("Thermostat")) {
    Serial.println("Not connected to WiFi but continuing anyway.");
  } else {
    Serial.println("connected...yeey :)");
  strcpy(Email, custom_Email.getValue());
  strcpy(Supla_name, custom_Supla_name.getValue());
  strcpy(term_hist, custom_term_hist.getValue());
  wifiManager.getWiFiSSID().toCharArray(Router_SSID, 33);
  wifiManager.getWiFiPass().toCharArray(Router_Pass, 65);
  if (strcmp(Supla_server, "get_new_guid_and_authkey") == 0) {
    Serial.println("new guid & authkey.");
    EEPROM.write(300, 0);
    EEPROM.commit();
    delay(100);
    ESP.reset();
  if (shouldSaveConfig) {
    DynamicJsonDocument json(1024);
    json["Email"] = Email;
    json["Supla_name"] = Supla_name;
    json["term_hist"] = term_hist;
    json["Router_SSID"] = Router_SSID;
    json["Router_Pass"] = Router_Pass;
    File configFile = LittleFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    serializeJsonPretty(json, Serial);
    serializeJson(json, configFile);
    configFile.close();
    WiFi.mode(WIFI_STA);
    delay(5000);
    ESP.restart();
  WiFi.softAPdisconnect(true);
  if (initialConfig == true) {
    delay(5000);
    ESP.restart();
  LedS->setAutoSequence(); // Restores automatic LED sequence change based on device state.
void status_func(int status, const char *msg) {    //    ------------------------ Status --------------------------
  if (s != status) {
    s = status;
    if (s != 10) {
      strcpy(Supla_status, msg);
void TH_Overlay() {
  display.clear();
  if (actualTemp > -100) {
    display.setFont(Arimo_Bold_32);
    //display.setFont(ArialMT_Plain_24);
    display.drawString(64, 14, String(actualTemp, 1) + "ºC");
  } else {
    display.drawString(64, 14, "-----");
  display.drawString(64, 48, "Preset " + String(ThermostatTemperature, 1) + "ºC");
    display.drawString(61, 0, "Auto");
  } else {
    display.drawXbm(52, 0, 16, 16, hand16_bmp);
  if (!WiFiConected) {
    display.drawXbm(22, 0, 16, 16, logo16_wifi_off_bmp);// -------------------------------------------------- oled no wifi --------
  } else {
    if (s == STATUS_REGISTERED_AND_READY) {
      display.drawXbm(22, 0, 16, 16, logo16_supla_bmp);// ------------------------------------------------ oled supla ok --------
    } else if (s != 10) {
      display.drawString(30, 0, String(s));
  if (relay_1->isOn()) {
    display.drawXbm(86, 0, 40, 16, logo_Power_on);// -------------------------------------------------- Relay on  ---------
  } else {
    display.drawXbm(86, 0, 40, 16, logo_Power_off);// ------------------------------------------------- Relay off  --------
  if (relay_2->isOn()) {
    display.drawXbm(1, 0, 16, 16, logo16_2_on);// -------------------------------------------------- Relay 2 on  ---------
  } else {
    display.drawXbm(1, 0, 16, 16, logo16_2_off);// ------------------------------------------------- Relay 2 off  --------
  display.display();
  TempDisp_lasttime = millis();
void guid_authkey(void) {
  if (EEPROM.read(300) != 60) {
    int eep_gui = 301;
    ESP8266TrueRandom.uuid(uuidNumber);
    String uuidString = "";
    for (int i = 0; i < 16; i++) {
      int topDigit = uuidNumber[i] >> 4;
      int bottomDigit = uuidNumber[i] & 0x0f;
      uuidString += "0123456789abcdef"[topDigit];
      uuidString += "0123456789abcdef"[bottomDigit];
    int length_uuid = uuidString.length();
    for (int i = 0; i < length_uuid; ++i) {
      EEPROM.put(eep_gui + i, uuidString[i]);
    int eep_aut = 341;
    String uuidString2 = "";
      uuidString2 += "0123456789abcdef"[topDigit];
      uuidString2 += "0123456789abcdef"[bottomDigit];
    int length_uuid2 = uuidString2.length();
    for (int i = 0; i < length_uuid2; ++i) {
      EEPROM.put(eep_aut + i, uuidString2[i]);
    EEPROM.write(300, 60);
    EEPROM.commit();
    delay(0);
  read_guid();
  read_authkey();
  //Serial.print("GUID : ");Serial.println(read_guid());
  //Serial.print("AUTHKEY : ");Serial.println(read_authkey());
String read_guid(void) {
  String read_eeprom = "";
  int i, ii = 0;
  int eep_star = 301;
  int end_guid = eep_star + SUPLA_GUID_SIZE;
  String temp_read = "0x";
  for (i = eep_star; i < end_guid + 16;  i = i + 1) {
    temp_read += char(EEPROM.read(i));
    read_eeprom += char(EEPROM.read(i));
    if ( (i % 2) == 0) {
      char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      GUID[ii] = strtoul( _guid, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
String read_authkey(void) {
  int i, ii = 0;
  int eep_star = 341;
  int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
  for (i = eep_star; i < end_authkey + 16;  i = i + 1) {
      char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
void setup() {
  wifi_set_sleep_type(NONE_SLEEP_T);
  pinMode(button_pin, INPUT_PULLUP);
  Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY, 1);
  display.init();
  display.flipScreenVertically();
  display.clear();
  display.drawString(42, 6, "Supla");
  display.drawString(33, 40, "Thermostat");
  display.drawXbm(0, 16, 32, 32, logo32_glcd_bmp );
  display.display();
  delay(10);
  EEPROM.begin(1024);
    initialConfig = true;
  guid_authkey();
  if (LittleFS.begin()) {  // ------------------------- wificonfig read -----------------
    if (LittleFS.exists("/config.json")) {
      File configFile = LittleFS.open("/config.json", "r");
      if (configFile) {
        DeserializationError deserializeError = deserializeJson(json, configFile);
        if (!deserializeError) {
          Serial.println("\nparsed json");
          if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
          if (json.containsKey("Email")) strcpy(Email, json["Email"]);
          if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
          if (json.containsKey("term_hist")) {
            strcpy(term_hist, json["term_hist"]);
            Term_Hist = (String(term_hist).toFloat());
            if (Term_Hist < 0.1) {
              Term_Hist = 0.1;
            else if (Term_Hist > 10.0) {
              Term_Hist = 10.0;
          if (json.containsKey("Router_SSID")) strcpy(Router_SSID, json["Router_SSID"]);
          if (json.containsKey("Router_Pass")) strcpy(Router_Pass, json["Router_Pass"]);
        } else {
        configFile.close();
  } else {
    Serial.println("failed to mount FS");
  wifi_station_set_hostname(Supla_name);
  if (initialConfig) {
    ondemandwifiCallback();
  relay_0 = new Supla::Control::Relay(autoManLed, true, 32);
  relay_0->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  relay_0->setDefaultStateRestore();
  relay_0->disableChannelState();
  relay_1 = new ManualRelay();
  relay_1->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  relay_1->setDefaultStateOff();
  relay_1->disableChannelState();
  DsTemp = new Supla::Sensor::DS18B20(ds_pin);
  TerTemp = new TermostatTemp();
  TerTemp->disableChannelState();
  TerSet = new TermostatSet();
  TerSet->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
  TerSet->disableChannelState();
  relay_0->addAction(Supla::TURN_OFF, relay_1, Supla::ON_TURN_OFF);
  miDimmToTemp = new DimmToTemp();
  miDimmToTemp->disableChannelState();
  auto button_2 = new Supla::Control::Button(button2_pin, true, true);
  auto button_3 = new Supla::Control::Button(button3_pin, true, true);
  button_2->setHoldTime(500);
  button_3->setHoldTime(500);
  button_2->repeatOnHoldEvery(200);
  button_3->repeatOnHoldEvery(200);
  button_2->addAction(unDimm, custAct, Supla::ON_PRESS);
  button_3->addAction(unDimm, custAct, Supla::ON_PRESS);
  button_2->addAction(Supla::TURN_ON, TerSet, Supla::ON_PRESS);
  button_3->addAction(Supla::TURN_OFF, TerSet, Supla::ON_PRESS);
  button_2->addAction(Supla::TURN_ON, TerSet, Supla::ON_HOLD);
  button_3->addAction(Supla::TURN_OFF, TerSet, Supla::ON_HOLD);
  relay_2 = new Supla::Control::Relay(relay2_pin, true, 224);
  relay_2->getChannel()->setDefault(SUPLA_CHANNELFNC_LIGHTSWITCH);
  relay_2->disableChannelState();
  relay_2->setDefaultStateRestore();
  relay_2->keepTurnOnDuration();
  auto button_1 = new Supla::Control::Button(button_pin, true, true);
  button_1->setMulticlickTime(800, false);
  button_1->setHoldTime(1000);
  button_1->addAction(Supla::TOGGLE, relay_0, Supla::ON_CLICK_1);
  if (!Protected)button_1->addAction(Supla::TOGGLE, relay_1, Supla::ON_CLICK_2);
  button_1->addAction(unDimm, custAct, Supla::ON_PRESS);
  button_1->addAction(Supla::TOGGLE, relay_2, Supla::ON_HOLD);
  LedS = new Supla::Device::StatusLed(stateLed, true);
  // StatusLed(uint8_t outPin, bool invert)
  // Use inverted logic for GPIO output, when:
  // false -> HIGH=ON,  LOW=OFF
  // true  -> HIGH=OFF, LOW=ON
  LedS->setMode(Supla::LED_OFF_WHEN_CONNECTED);
  // LED_ON_WHEN_CONNECTED /* default ,
  // LED_OFF_WHEN_CONNECTED,
  // LED_ALWAYS_OFF
  SuplaDevice.setName(Supla_name);
  wifi.setSsid(Router_SSID);
  wifi.setPassword(Router_Pass);
  SuplaDevice.setStatusFuncImpl(&status_func);
  wifi.enableSSL(false);
  SuplaDevice.begin(GUID, Supla_server, Email, AUTHKEY);
void loop() {
  int C_W_read = digitalRead(button_pin); {
    if (C_W_read != last_C_W_state) {
      time_last_C_W_change = millis();
    if ((millis() - time_last_C_W_change) > C_W_delay) {
      if (C_W_read != C_W_state) {
        C_W_state = C_W_read;
        if (C_W_state == LOW) {
          ondemandwifiCallback () ;
    last_C_W_state = C_W_read;
  SuplaDevice.iterate();
  delay(20);
  if (((millis() -  TempDisp_lasttime) > TempDisp_mtbs) || (updateOled))  {
    WiFiConected = (WiFi.status() == WL_CONNECTED);
    TempDisp_mtbs = 500;
    if (updateOled){
      updateOled = false;
    TH_Overlay();
  if ((millis() - dimm_lasttime) > dimm_mtbs) {
    if (!dimm) {
      display.setContrast(50, 50, 30);
      display.display();
      dimm = true ;
eradek
Sweet, thanks a lot!
endrju761@gmail.com
Wgrałem termostat z rotary enkoderem.
Po boocie nie rozgłasza sieci , d5 10s jest termostat.
Potem:
Creating OneWire bus for pin: 4
Initializing OneWire bus at pin 4
OneWire(pin 4) Parasite power is OFF
OneWire(pin 4) Found 0 devices:
Device address not provided. Using device from index 0
Supla - starting initialization
Storage initialization
readStorage: 8; Read: [53 55 50 4C 41 1 0 1 ]
Storage: Number of sections 1
Reading section: 0
readStorage: 7; Read: [3 F 0 0 0 0 0 ]
Section type: 3; size: 15
Validating storage state section with current device configuration
Storage state section validation completed. Loading elements state...
readStorage: 4; Read: [0 0 0 0 ]
readStorage: 1; Read: [0 ]
Relay[0]: restored relay state: OFF
Channel(2) value changed to -275.0
Channel(3) value changed to 20.0
Initializing network layer
WiFi: establishing connection with SSID: ""
Using Supla protocol version 16
Current status: [8] No connection to network
Connection fail counter overflow. Trying to setup network interface again
WiFi: resetting WiFi connection
*wm:[2] Added Parameter: server
*wm:[2] Added Parameter: email
*wm:[2] Added Parameter: name
*wm:[2] Added Parameter: step
*wm:[2] Added Parameter: histerisis
*wm:[2] Starting Config Portal
*wm:[2] Disabling STA
*wm:[2] Enabling AP
*wm:[1] StartAP with SSID:  Thermostat
*wm:[2] AP has anonymous access!
*wm:[1] AP IP address: 192.168.4.1
*wm:[1] Starting Web Portal
*wm:[2] HTTP server started
*wm:[2] Config Portal Running, blocking, waiting for clients...
*wm:[2] Portal Timeout In 300 seconds
*wm:[2] Portal Timeout In 298 seconds
*wm:[2] <- Request redirected to captive portal
*wm:[2] <- HTTP Root
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (3):
epc1=0x4000bf64 epc2=0x00000000 epc3=0x00000000 excvaddr=0x402701c9 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffa90 end: 3fffffc0 offset: 0190
3ffffc20:  3fff55e4 00000cc0 00000000 00000000
3ffffc30:  402701c9 0000002b 3ffffc80 00000000
3ffffc40:  00000000 3ffefa70 3ffffcbc 4020afaf
3ffffc50:  00000000 3fff3194 3ffffc80 4021e568
3ffffc60:  3ffffc80 3ffefba8 3ffefa70 4021e591
3ffffc70:  3ffefb70 3ffefba8 3ffefa70 402118b6
3ffffc80:  3fff4fcc 002b002f 80000000 4020fb9c
3ffffc90:  00000000 69746365 00000000 40235e8f
3ffffca0:  40212a00 3ffefa70 00007530 00000000
3ffffcb0:  3fff1c64 3fff3358 00000000 3fff55e4
3ffffcc0:  0cc00ccf 80000000 0000197b 00000000
3ffffcd0:  3ffefb70 00000001 3fff3304 40222448
3ffffce0:  00000721 00000000 00000000 401000e9
3ffffcf0:  00000000 00000000 3fff5034 4020d2c1
3ffffd00:  00000000 3fff1c64 3fff1c1c 402102fc
3ffffd10:  00000000 00000000 00000000 69746365
3ffffd20:  00000000 00000000 4010051d 00000000
3ffffd30:  0002b477 00000000 00000000 00000001
3ffffd40:  00000000 00000000 3fff1c1c 00000000
3ffffd50:  3ffefb70 3fff1c40 3fff1c1c 4021249a
3ffffd60:  40223f30 00000000 00001388 40216d77
3ffffd70:  00000000 00000000 3fff4d2c 00000000
3ffffd80:  3ffefb70 3ffefb70 3ffefa70 402126d4
3ffffd90:  3ffefb70 00000001 3ffefa70 4020cca3
3ffffda0:  00000000 00000000 00000001 401001a8
3ffffdb0:  000b000f 00000000 3ffefa70 00000000
3ffffdc0:  3ffefb70 00000001 3ffefa70 00000000
3ffffdd0:  3ffefb70 00000001 3ffefa70 40212a00
3ffffde0:  00000000 000b000f 00000000 00000000
3ffffdf0:  73646e6f 00000000 00000000 000b000f
3ffffe00:  00000000 00000000 3ffefa70 4020c47c
3ffffe10:  3ffe8c11 3ffe861b 3ffffed8 4020aeb2
3ffffe20:  3ffefd0c 3ffe8c48 3ffefa70 3ffe861b
3ffffe30:  3ffe86a9 3ffe8c48 3ffefa70 402084e1
3ffffe40:  00000000 002b002f 00000000 3ffe8974
3ffffe50:  3ffe8970 3ffe897b 3ffe8980 00000030
3ffffe60:  00000000 00000000 00000001 401001a8
3ffffe70:  40100578 00000010 3fff2f80 000003f0
3ffffe80:  0000001f 3ffefd14 00000000 4021a724
3ffffe90:  00000000 00000000 00000000 00000001
3ffffea0:  00000001 3ffe8cb7 00000000 00000000
3ffffeb0:  00000000 00000001 00000001 3ffe85e8
3ffffec0:  00000000 00000000 00000000 00000001
3ffffed0:  00000001 3ffe8c9a 3ffe8c8f 3ffe8c84
3ffffee0:  3fff327c 00000005 00000001 3ffe8c48
3ffffef0:  3ffe8c7f 3ffe8c76 3fff1ea4 00000005
3fffff00:  00000001 3ffe8c48 3ffe8d44 3ffe8c64
3fffff10:  3fff315c 00000033 00000001 3ffe8c48
3fffff20:  3ffe98df 3ffe8c5e 3fff3224 00000051
3fffff30:  00000001 3ffe8c48 3ffe9717 3ffe8c51
3fffff40:  3fff31cc 00000051 00000001 3ffe8c48
3fffff50:  3fff313c 3fff3158 3fff3158 00000000
3fffff60:  00f42400 83bfeac8 4010051d 00000000
3fffff70:  00000000 3ffe8c11 0000000a 4021f65c
3fffff80:  00000000 00000000 00000001 3fff10c4
3fffff90:  3ffefd0c 3ffe86fc 00000000 4020881d
3fffffa0:  3fffdad0 00000000 3fff10b0 4021f77c
3fffffb0:  feefeffe feefeffe 3ffe873c 40100f79
<<<stack<<<
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v0008d530
~ld
⸮⸮Term_Step: 0.50
Term_Hist: 1.00
Reading section: 0
wgrane do nodemcu
elmaya
endrju761@gmail.com wrote: Wed Apr 13, 2022 8:57 pm I have uploaded a thermostat with a rotary encoder.
After the boocie, it does not broadcast the network, d5 10s is the thermostat.
Later:
Reading section: 0
*wm:[2] Enabling AP
Exception (3):
>>>stack>>>
ctx: cont
<<<stack<<<
tail 4
chksum 0xcc
tail 4
chksum 0xc9
csum 0xc9
v0008d530
~ld
⸮⸮Term_Step: 0.50
Term_Hist: 1.00
Reading section: 0
uploaded to nodemcu
read my post from 17 Mar 2022, 17:22 https://en-forum.supla.org/viewtopic.ph ... 79#p120679
endrju761@gmail.com
I try it before.In boardmanager 2.74 no Littlefs.h
after install blynk i have littlefs.h
now it works...:)
thx :)
one request ..
Im looking something like "pool controler termostat" 2xds18b20 with oled.
when 1 ds is more 5 celsius like 2 relay on. When themperature are same relay off.
T1=T2+5 relay off or ... T1=T2+histereze relay off .
something like https://pool-controller.lector.dev/ with oled.
anyway big thanks
jemar
Hello
I apologize in advance for any incomplete sentences.
I downloaded to ESP soft everything works best, but it keeps showing me the E5 error several times, I entered the correct svr data and passwords, but I do not want to communicate.
TheQuiet
Hello, I need help. After completing the configuration, the display oled error E13, sometimes E10. What do these codes mean? What am I doing wrong?
zzrr
elmaya wrote: Sun Apr 03, 2022 1:31 pm
Gpio 12 "D6":
Gpio 14 "D5":
Gpio 13 "D7":
Hi,
Could you please provide the source code for the same, but with regulation at least 0.5C. Super with 0.1C.
Thank you
Dawid84
Can 2 DS sensors be connected?
Dawid
morhan
hello, can you give this file as bin? I have nodemc. And I can't compile. Can you give me the file for the flash tool? thanks
https://en-forum.supla.org/viewtopic.ph ... 45#p119645
Post Reply
