ESP32 + LAN8720
dobo
Thanks for the clarification.
radzik_r
As klew mentioned, the solution is good at the entrance gate or garage, where someone may not have Wifi coverage.
adik300i
Thanks! Its a great solution for an electrical switchboard made of metal, no need for external antennas etc.
How to define the other GPIOs with your software?
Is it possible to add such function to the gui generic? :P
elmaya
adik300i wrote: Thu Jan 20, 2022 8:07 pm Thanks! Its a great solution for an electrical switchboard made of metal, no need for external antennas etc.
GPIOs are defined the same as with WiFi.
I guess so, you'll have to ask in the appropriate section.
viewforum.php?f=88
jaku2k
Hello,
is this solution compatible with ESP32 S3?
If yes, how should it be connected?
Regards,
Jakub
elmaya
ESP32-S3 does not support Ethernet MAC.
Currently, only ESP32 provides such support
jaku2k
Alright, thank you for the answer.
jaku2k
Explain me one more thing, please.
On the schematic there are TX and RX pins doubled. Does it mean that LAN8720 uses 2 I2C buses?
Regards,
Jakub
elmaya
jaku2k wrote: Sun May 15, 2022 10:52 am Explain me one more thing, please.
Regards,
Jakub
Not at all.
the connection between ESP32 and LAN is: RMII (Reduced Media Independent Interface).
https://en.wikipedia.org/wiki/Media-ind ... rface#RMII
jaku2k
elmaya wrote: Sun May 15, 2022 11:23 am Not at all.
Thank you for the anwser. I read that entry and - if I understand correctly - there is still one free I2C bus left on the ESP.
Am I right?
Jakub
